09-17-2012, 09:14 AM | #4591 | |
If you extend the control arm and the tie rod the same amount, bumpsteer should actually be less, since the CA/TR ratio is closer to 1:1. Please correct me if I'm wrong. I think you're thinking TC rod. The tie rod pickup will move outward the same amount as the LBJ.
09-17-2012, 11:54 PM | #4592 |
LCA's back, sand blasted and hit with satin black.
Installed them tonight, but it was too dark for decent pics. Crazy toe out! I'm pretty sure my PBM v.1 inners are too short, probably go miker's route and add on some threads to outers. |
09-19-2012, 01:14 AM | #4594 |
I was wondering what extending the front lower control arm length by 30mm does at 100mm bump and droop at -3 degrees camber so I did a Susprog calc and here are the changes:
Camber decreasing improves by 0.03 degrees Anti dive decreases 3.1% |
09-19-2012, 02:51 AM | #4595 |
We're just finalizing the designs of the different steering arms that we're making for our billet aluminium knuckles but the question that I have is who actually wants zero ackerman? The DW knuckles from our measurements actually have more toe at full lock than the standard position and they're popular.
Talk to us. Tell us what you want, and then we'll make it Here's a quick simulation that we put together: GKTECH - Using technology to get more angle out of your S chassis | Facebook |
09-19-2012, 09:59 AM | #4596 |
With 15mm front spacers + S14 LCA mod.
17x9 +12 before.. dunno after, probably -20 something ish. Video: https://www.facebook.com/v/10151245662273939 |
09-19-2012, 11:41 AM | #4597 |
Hi, I need little help to choose new inner and outer tie rods.
I installed today Godspeed spacer which adding 2.2cm traveling to the steering rack, But the problem came when I tried to recenter the rack. I reach to maximum of the rod screwing before the wheels are at straight position(OEM rods), So now I have to purchase new and more screwing adjustable/shorter rods. Which are recommended? |
09-19-2012, 01:22 PM | #4598 | |
it has been mentioned a few times that some ackerman is good. i use dw geomaster and iam pretty happy with them. I only use my car on the track and i tend too adjust the toe at the track depending on how it feels its a bit of a minefield when you factor in the different caster settings, ride heights and steering rack positions, that different people run Im guessing there are very few people out there who know exactly what they want and alot of peeps will probably adjust alignment to suit. the best option is probably to get fink and a track and do real testing with different settings and see what he thinks
[SIGPIC][/SIGPIC] |
09-19-2012, 01:23 PM | #4599 | |
10mm is an example, you can go a little further if needed
[SIGPIC][/SIGPIC] |
09-19-2012, 01:30 PM | #4600 | |
09-19-2012, 01:43 PM | #4601 |
09-19-2012, 03:01 PM | #4602 | |
Now there are a few people telling me they need zero ackerman. We'll cater for anything if there's enough interest. I'll get a test pair of steering arms machined up. Easy enough |
09-20-2012, 01:16 AM | #4605 |
Yes he was over here driving for driftworks. He took some Geomasters back with him. But at the time Dw said it was for his practice car. So maybe he liked them a lot i have no idea :/
[SIGPIC][/SIGPIC] |
09-20-2012, 01:31 AM | #4606 | |
Another thing to consider, would be the use they are intended for. I don't compete or battle anyone. I care most about trying crazy entries and sliding backwards. I think I would want different settings if I was trying to follow on someones door
[SIGPIC][/SIGPIC] |
09-20-2012, 06:22 AM | #4610 |
Our kit gives a true 0 ackerman if desired. It has fully adjustable ackerman set-up.
We have just won the Prodrift championship in Ireland with our kit. In the last round the car equipped with our kit was able to defeat the visiting Need for Speed driver Fredrick Asboo in his new 86 with 2jz and last years FD champion Dia Yoshihara in a Altezza with 2jz also. Having the correct geometry dose help in drifting and we understand it properly. We have now released the Type 3 Knuckle which is over 40% lighter. |
09-20-2012, 07:02 AM | #4611 |
I like how you say "if desired"
Are you willing to share your thoughts on ackerman? I love playing around with stuff, but without some kind of guidance on what to expect from different settings, i find the level of adjustment daunting. Ive learnt to use my geomasters and adjust toe ect to get what i want. Iam 100% i would find the gktech to be same story for me because they are very similar regarding steering geometry, rc correction and general fitment of the part. Iam running a custom front crossmember, so I have 80mm rc correction. Yours have alot more than 45mm correction yes? All my questions are genuine 'out of interest' questions. I love the product! cant decide if its for me though!
[SIGPIC][/SIGPIC] |
09-20-2012, 07:28 AM | #4612 | |
Toe should not really be adjusted to increase or decrease Ackerman. It should be set to make the car stable in a straight line for acceleration and braking. I don't see how you could move the pick-up point for the inner wishbone and tension rod up by 80mm as they would be in the middle of the chassis leg. Did you also move the steering rack up by 80mm ? Out kits have a huge sweet spot where they will work and produce excellent results. This is because most of the interesting geometry is machined into the knuckles. If you examine this photo would will see how the car just wants to drift on lock. Look at the 2 wheels and the contact patches on the ground. Out knuckles have 100+ roll centre correction meaning that we can run without sway bar without massive front springs. |
09-20-2012, 07:29 AM | #4613 |
for my s13 I think i might go with Cor Chuckles 42mm corrections, i forget how much ackerman he said he has in them, not alot but not zero, her said it felt weird with zero. They also have some rad angle parts ( Curved Tension rod, and custom sway bar)
https://vimeo.com/47847866# Justin also runs them |
09-20-2012, 12:07 PM | #4614 | |
Nothing has been calculated, i just drive it and then adjust a few things for my preference. The rear subframe has had the same treatment also with geomasters. I know its not as fancy as you guys can produce. I do it for fun and purely so i can keep my car slammed but have relatively good handling on the road and track I also agree with your comments on ackerman. But iam also on the band wagon that zero is a bit weird. I made my own rc corrected knuckles years ago that were kinda zero ackerman and really shonky. They had different ackerman side for side which was really messed up but still loads of fun The reason for altering my toe to tune the feel on lock is purely a compromise because i bought secondhand geomasters and i try my best too make best of what i have. I would have to save or sell one of my cars too change anything at the moment, unless i can make it myself lol The pictures above were to backup what gktech said above. They measured geomasters and figured they had alot of ackerman. BUT they are popular in a few countries. Could just be jumping on the geomaster bandwagon though i guess. I managed to find a pic of my shonky homebrews lol. i swapped the lower arms side for side so that i had more clearance for lock
[SIGPIC][/SIGPIC] |
09-20-2012, 12:19 PM | #4615 |
pic of shonky hubs on the lock
and geomasters on the lock this pic shows fuck all really I think a small amount of scrub from the front end is ok. people drifted fine on stock knuckles for years
[SIGPIC][/SIGPIC] |
09-20-2012, 12:25 PM | #4616 |
The diver feed back we get from out kit with close to or Zero ackerman is that is't awesome and the feel of what the car is doing is transmitted through the wheel. Also the drivers report that at big lock the control of the car is very sharp and transition can be made very quick.
I understand that the cost is always an issue. We are focused on making the best kit we can. The cost relative to the design and manufacturing time means that until we sell 100+ kits we will be making a loss. We do it for the love of making quality products. Robbie |
09-20-2012, 12:45 PM | #4617 | |
thanks for your input on ackerman, its good to hear others experiences and also amazing to see all these badass products being made by alot of different people. id be interested to see some video of your kit in action, especially wild entries
[SIGPIC][/SIGPIC] |
09-20-2012, 12:45 PM | #4618 | |
Trader Rating: (82)
Feedback Score: 82 reviews
NEED Bolt kits for your car? |
09-20-2012, 01:07 PM | #4619 | |
I have a few dealers lined up for LA. Please e-mail [email protected] me and we will get you a quote asap. |
09-20-2012, 03:24 PM | #4620 | |
