Old 06-21-2018, 01:03 PM   #1
owned by pandas
owned by pandas's Avatar
owned by pandas is an unknown quantity at this point
Full Blacktop Sr20det turn key swap for sale(lots of parts)
*****Motor is still in the car but can have it sll out in a matter of hours. Youre welcome to come and see it run.*****
Contact info:
Phone: 404-207-6106
Asking 4k
Engine:
Sr20det black top swap
Apexi power fc stand alone
AEM wide band
Assorted other guages(oil pressure, oil temp, coolant temp, boost)
550 cc injectors
50 trim Top mount turbo
Precision external wastegate with dump tube
Isr blast pipe
Full 3 inch exhaust
Z32 maf with wiring specialty maf harness and connector
Circuit sport catch can
Circuit sport coolant over flow
Moroso powersteering resivour
Aeromotive Fuel pressure regulator
Moroso high capacity oil pan
Moroso oil filter relocation kit
Rocker arm stoppers
Walbro 255 fuel pump
Poly motor mounts
Freddy intake manifold
Power steering
Dual electric fans with aluminum radiator
Short shifter
Front mount with intercooler piping
Will also include the transmission and driveshaft.
You can come see it run before i pull it!
owned by pandas is offline   Reply With Quote
Old 06-21-2018, 06:51 PM   #2
AscendaShogun
AscendaShogun's Avatar
AscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the rough
S13.4 / 5 valve cover?
What was the original ECU code?
What year chassis did this come out of / what chassis?
Sent from my iPhone using Tapatalk Pro
SuperRadDriftyFranz
'88 S13 Silvia
Originally Posted by LockOn! View Post
decrepit teenage shitsleds
Originally Posted by LoSt180 View Post
"Cut my springs, car is bouncy, will a camber kit help?"
AscendaShogun is offline   Reply With Quote
Old 06-22-2018, 11:24 AM   #3
owned by pandas
The vc conversion doesnt come with the swap, I will replace it with a oem S13 vc.
The original ecu code is e6.
I have no clue what year the motor came out of, it was purchased from a guy that never finished his project.
Old 06-22-2018, 02:23 PM   #4
jscherf92
jscherf92 is an unknown quantity at this point
Any interest in parting anything out? I'm in marietta and sick of my exhaust.
jscherf92 is offline   Reply With Quote
