Old 11-09-2010, 09:05 AM   #1
Lazarey
Lazarey is an unknown quantity at this point
Question Lightweight flywheel from a mpg standpoint
Considering putting a lightweight flywheel on my strictly DD S14 when I put in a new clutch. I know it's odd but I actually enjoy tracking the gas mileage on it. Over 34 fill ups, I have averaged 28.7 mpg. I was wondering how a lightweight flywheel would affect that. On one hand, it would take less effort for the engine to spin up, but the rpms would fall faster which in my mind could make the engine have to use more gas to catch it before it stalls.
I know there are much smarter people than myself on here, so I thought I'd ask your opinions.
Lazarey is offline   Reply With Quote
Old 11-09-2010, 09:40 AM   #2
Sileighty_85
Sileighty_85's Avatar
It should help since your lighting the rotational mass that the engine has to turn.
Frees up power and engergy the engine has to use to rotate it.
I put a Lightweight flywheel on my RB25 and man i can notice a difference as far as revs go especially when it falls back to idle.
Not to sure on the gas mileage yet seeing that i just got the engine running last friday
The way i kinda see it:
Think about throwing a 10lb weight and and a 20lb weight in the air, which is gonna require less energy and force to throw and catch?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-09-2010, 10:10 AM   #3
Lazarey
I agree with you on all of that, just wondering if the engine has to use more fuel to catch the engine as it rapidly spins down and if so, how much more...
Old 11-09-2010, 10:27 AM   #4
Hywarp161
Hywarp161's Avatar
Hywarp161 is an unknown quantity at this point
when i installed a lightweight flywheel in my wife's tiburon she averaged an extra 100 miles to a tank of gas. But if i drive it goes the other way lol. The motor is doing less work to generate the same amount of horsepower.
Hywarp161 is offline   Reply With Quote
Old 11-09-2010, 10:42 AM   #5
Sileighty_85
Nah should you less, even though the engine will decel faster it shouldnt have to use as much engery to catch it since it lighter
後輪駆動車1番
1986 SR86 - 200ish
Old 11-09-2010, 11:06 AM   #6
S14DB
AFC #1
S14DB's Avatar
It should get better hwy mileage cause there is less rotational mass. You may loose some city millage if you do a lot of stop and go. You loose some stored tq(potential energy) in the flywheel for launch. So, it takes a little more gas to get going.
A "street" lightweight will be heavy enough to not take to much gas on the launch. But, still get benefits on cruise. The gains will outweigh the losses.
A "race" weight will be undesirable on launch.
flywheel, lightweight flywheel, mpg, s14
