11-27-2010, 07:48 PM | #272 |
A short crappy Vid, drive by @ 4psi.
Wish i had a longer stretch of road and more boost and a Tach that worked so i could Rev it all the way. Vids still dont capture the sound of this beast http://www.youtube.com/watch?v=1S0R8bzV9Co YouTube - RB25 S14 Drive By 2
11-27-2010, 09:30 PM | #275 |
Yo I just saw youre an AGE mechanic lol so am I and I'm on Kadena right now. I was reading your thread on weekend duty and SSGT Gilbert said he knows you from another base. haha small world
AEM Series 2 ECU 30-6620 and Chase Bays S14 SR20DET engine harness for sale |
11-27-2010, 09:37 PM | #276 |
haha WTF Gilberts over there!! Thats crazy, yeah AGE is def a small world
11-30-2010, 12:41 PM | #277 |
Awesome build and thanks for taking the time to pin point just about everything. I found the info on the dipstick very usefull as mine just started to split like yours. Its actually cheaper to find a sentra dipstick and do the same mod than buying a r33 rb25det one.
Again thanks and great build. Lee |
11-30-2010, 03:21 PM | #278 | |
No problem man, If you didnt wanna go the route of making one, If you contact Russell @ Nissanparts.cc he can get you a dipstick I ended up ordering one just in case since I couldnt get some one else to measure one for me so i could check mine. But my Measurements came out dead on compared to the OEM one
12-06-2010, 10:09 PM | #279 |
Alright RB guys, Just curious if this is a normal sound or not.
I never noticed it before cuz the FAL are so damn loud and I just recently got a new CTS so the DIF controller works properly now. Does anyone else RB Timing belt sound like this or is my Timing belt too tight? All timing components are Brand new(OEM Nissan) with a Greddy TB I want real answers not, "I think its ok" This is not my engine but sounds similar, Not as loud as this though its faint but noticeable when im standing over the engine and reving. YouTube - RB25 Ill probably upload mine tomorrow, too late to be reving the RB lol
12-06-2010, 10:17 PM | #280 |
never heard that sound before but my belt is on tight.
YouTube - Hires RB20 idle.wmv about 1:00 mark u will hear it as I walk to the front of the motor with the camcorder.
95 240sx RB20 415whp 91 Nx2000 VVL yo |
12-06-2010, 10:23 PM | #281 |
Yours almost sounds like a power steering pump, but looks like you didnt even have a belt on it.
I wanna say its normal and it just the sound of the belt whizzing over the cam gears (my sound) Im just paranoid and like to have second opinions
12-06-2010, 11:54 PM | #283 |
the sound your hearing is normal... to an extent. if it howls really loud and dosent stop then your timing belt is on way too tight.
however if you hear it intermittently like on the video ( i only heard it a few times ) its ok. the belt is made of kevlar and those types of belts will make a howling noise just because they dont stretch like oem belts do. i tightened my tensioner maybe a little less than a 1/4 turn and my belt only howls when the motor gets really hot.
1992 240sx (RB20. 362whp@16psi) |
12-07-2010, 06:31 AM | #284 |
Sweet thats what I figured,
Mines only barely noticeable when you Rev the engine. Thanks eklips
12-09-2010, 06:16 PM | #285 |
So today I was planning to up the boost on the RB, I hooked up some Sunpro gauge I borrowed from a co-worker.
With just a Vac line running to the W/G the RB pushes 5-6psi But when i was dialing in the Greddy MBC the Vac line that I ran caused the Throttle pully to hang up and cause the RPM's to spike and bounce off the Rev Limiter for a good 4 seconds until I shut her down. So pulled over fixed the line, luckily started up fine with no rod knock. But one thing weirded me out, my Engine use to idle at 1100RPM's even when I adjusted the IACV. Now she idles at 900RPM's and I can adjust the IACV better.....wtf So i wonder what happened to allow my RPM's to lower, I hate that shit when when somthing big happens and issues you had before are magically fixed...
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 12-10-2010 at 08:55 AM.. |
12-10-2010, 11:56 PM | #286 |
holy shit, ryguy! remember the days of club240? im out at camp hansen right now. even smaller world.
12-11-2010, 07:26 AM | #287 | |
**The atypical S-chassis enthusiast*** |
01-09-2011, 10:50 PM | #288 |
I guess a little update for those who care
RB's been running great for since the MAFS issue. Took a 800 mile Round trip to AL got around 25-28mpg cruising around 60-70mph I had a few weird instance of having a dead pedal for a split second almost like a bad TPS or no fuel (fuel tank was low) But other than that its been great. I tried upping the boost again with a real boost gauge (Blitz) around .8 Bar it misfires Stock WG is garbage as well though too , I tried wrapping my Coil packs in E-Tape and it helped a little bit, I wanna get some split fire coil packs to alleviate any questions on them. Probably check my Plug gaps as well again
01-10-2011, 07:28 AM | #289 | |
01-13-2011, 01:04 PM | #292 |
One is for the ECCS I believe,(dont have my schematics with me right now) and the other one im not sure of, Depending on Chassis and series RB the Relays vary between 2-3 but once the conversion is complete only one is needed.
01-14-2011, 09:17 AM | #294 |
Just read through the thread and love it! Thank you for an in-depth RB guide. I definitely hope to be able to do this one day.
Btw, if you don't mind me asking, is this SSG Gilbert's first name Benjamin? It's a shot in the dark... had a DS Gilbert once & was wondering. |
01-24-2011, 09:47 PM | #295 | ||
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 01-25-2011 at 01:02 PM.. |
02-06-2011, 11:15 AM | #296 |
I feel Dumb
So I was having an issue with misfire on the RB at anything above .5bar of boost, and ive suspected the spark plugs might have been gapped too small. I know the Coils are weak and I already wrpped them in E-Tape as a quick fix until I can order some splitfires for her So I finally stopped being lazy today but mainly due to my embarrassing loss of a N/A Z32 last night, so I went to work. I checked the plugs and it turns out I never properly gapped the plugs I remember now when i got the plugs I didnt have a gapper so I just put them in there to keep debris from falling in the cylinders. The plugs were gapped at .040mm-.043mm, So closed them down to .031mm turned up the boost a little and BAM no more missfire! Giant noticeable power gain, she rolls out now like a RB should!
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 05-22-2011 at 08:59 AM.. |
02-10-2011, 10:24 PM | #298 |
Nah I like plug an play parts, plus i wanna try and keep it clean lol
02-21-2011, 01:51 PM | #299 |
I need more power.... Decided to slap on the Hyper Gear Turbo
Probably the easiest in car turbo swap Ive done Removal Removed Hyper Gear bolted on Incognito
rb25 install, rb25 rebuild, rb25 s14, rb25 swap |
