Old 01-19-2006, 04:06 PM   #1
angrychickens
angrychickens's Avatar
angrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the roughangrychickens is a jewel in the rough
Send a message via AIM to angrychickens
yet another power window amp question
does the 96 nissan 240sx se have a power window amplifier, or is my motor busted www.courtesyparts.com says 1995-1998 has it but i think they are wrong since i cant find it in my own car. also anyone have an idea on the price of the whole motor.
angrychickens is offline   Reply With Quote
Old 01-19-2006, 06:53 PM   #2
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
i havent popped off a 96-98 door panel off to see for sure.. but from what i was told by russ... they dont have an external one.... but the 95 do...-96-98 have diffrent plugs.. also...
u can crack open the amplifer to see if a circuit on the board is burned.. a friend of mine soldered the circuit .. to make a complete connection.. thats how i got mines fixed.. to figure out whats wrong ur window mechanisms ur gonna have to test each one out... by that i mean manually..
mines was narrowed down to a faulty switch, which brought down the whole window system to gettin replaced...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 01-19-2006, 07:11 PM   #3
projectRDM
projectRDM's Avatar
89-95 uses an external amplifier, 96-98 it's built in to the switch, part of the redesign to make it last longer.
Plugs are different for 95 and 96-98, but you can swap the entire door harness to use a newer model switch in a 95, you'll just need to pin it for the OE alarm.
Motor retails at about $360. You can use a passenger side motor on the driver side but you have to notch the sheetmetal in the door to clear the casing on the motor, it's apparent what it needs when you try to fit it.
FORMERLY R240NA
Old 01-20-2006, 12:31 AM   #4
angrychickens
at this point im sure its the motor and not the power window switch, because i just bought the whole switch new, replaced it, only to find my window still wouldnt go down.
im also not willing to spend 350+ on a new window motor so i either find one in a junk yard or my window will never go down again
Old 10-23-2011, 09:27 PM   #5
Spaz555
Spaz555 is an unknown quantity at this point
Anybody you ask will be clueless. I have a 1994 240 SX - SE (convertible). My drivers side window wouldn't go down. The electrical tech computer at the local body shop said the problem was the window power amplifier in the drivers side door,,,,but nobody could find it !! The key,,,, it was located behind the back seats next to the power relays for the convertible top ( you'll have to take the seats out to access the electrical harness )
Spaz555 is offline   Reply With Quote
Old 10-23-2011, 09:28 PM   #6
Spaz555
try behind the rear seats, next to the relay switches for the convertible top,,,,,that's where mine was
Old 04-11-2018, 06:50 PM   #7
Manie
Manie can only hope to improve
Is it the same for a 92 convertable
Manie is offline   Reply With Quote
