03-23-2005, 09:05 PM | #1 |
s14 rhd conversion in s13 differ from last thread!
ok i got an s13, my friend has a jdm s14 front clip, can i swap my front suspension off my s13 onto the s14 once its on the car, so i dont have to go find two 5 lug wheels? how will all that work out? what needs to be done to make this conversion work? any ideas thanx i would really like to buy it from him since i dealt with him before and i havent been able to find a good s13 fornt clip that i can go and pick up like this one.
03-24-2005, 12:31 AM | #2 | |
In short, I'm just really confused.
03-24-2005, 11:46 AM | #3 |
i dunno what i am tryin to say, i just know that s14 has 5 lug, and if i replacethe front end steering rack etc. not weld the whole thing to my s13 rear just replace the fire walls. i will have a rhd with 5 lug i dont want 5 lug i wanna keep 4 lug. so thats what i am tryin to figure out what i need to do to keep 4 lug
03-24-2005, 12:44 PM | #4 | |
- ok, first, WHY would you want to ditch your 5 lug for 4? - WHY do you want do go RHD? Is it going to be streeted or a carpet queen? - Replace just the firewall.... what? THere's a lot more involved than that - are you saying all S14's have 5 lug, or the particular clip you're looking at? - when you say "suspension" how much are u talking about? coils/dampers or all the control arms and knuckles, etc too? - if you're just welding the firewall how is the suspension involved at all? I'm really confused too... |
03-27-2005, 08:11 AM | #6 |
ok, he knows he has to change the rack over (im doing this same conversion), but there is no point in just "cutting and welding the firewall" thats a structural part of the car and not in your best intrest to mess with. The difference between your firewall and that of the clip are the mounting tabs for dash board supports and the holes for the heater lines. Everything else will route through the existing holes. The tabs need to be marked on your firewall where they need to go, cut off the clip and one by one welded on to your firewall. This is the hardest part of the conversion. The rest is literally bolt on. As far as the 5 lug goes, just change it out with your 4 lug front hubs. Simple. 1 cotter key, and a 30mm nut. Then ship your 5 lug hubs over to me for reviving this thread.
03-27-2005, 10:11 AM | #7 | |
To make a car RHD you would only need the steering rack, column, pedals, and firewall, nothing underneath will be touched, meaning you will NOT swap the crossmember, suspension, hubs, spindles, anything, it will all remain the same. Grafting an S14 firewall into an S13 is going to be near imposible due to the differences in the chassis and the line up points and the changes between the mounting points for the column. So basically you're about as educated as a tree stump.
03-27-2005, 10:48 PM | #9 |
[QUOTE=R240NA]You are the stupidest person alive. Ever. You don't cut a car in half and weld it back together, especially two completely different cars. The finished job will be about as rigid as a piece of 4x12 sheetrock.
To make a car RHD you would only need the steering rack, column, pedals, and firewall, nothing underneath will be touched, meaning you will NOT swap the crossmember, suspension, hubs, spindles, anything, it will all remain the same. i have to agree you are a genius , but maybe your a newb. I hear you can cut a car in half , but you gotta put it back together with electrical tape , thats the only thing strong enough to hold. now as far as your 5-lug thing goes just take the s14 spindles and brakes and your good to go. AND DONT EVER CUT A CAR IN HALF , thats just makes you a wanna be, if you want JDM RHD you import a JDM pimp mobile you dont make one . 180sx`s dont have power seatbelts , they dont have those red running lights by the bumper , and most important they were NEVER USDM!! |
