07-18-2008, 09:05 PM | #1 |
swapping exhaust cam to intake side s13 KA
I just installed the 248/248 with the 4 tooth method. however, the car doesnt not turn over.
What i did was, time everything as the stock specs. And put the exhaust cam into the intake side. Move the cam gear 4 teeth counter clockwise from the silver mark on the timing chain. and use wrenge to turn the cam so it will fit on the cam gear. and after that I put everything back together. But the car did crank but didnt crank over. FYI, After we put everything back in, I manually turned the crank pulley for many rounds, and everything felt very smooth, it did not stuck at all.
07-19-2008, 04:14 AM | #2 |
It's your distributor.
http://zilvia.net/f/showthread.php?t=203342 I had the same problem. THOUGHT dist. timing was right, it wasn't keep rotating it a tooth in each direction until you get it.
