Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Group Buys
Group Buys Dedicated Forum for Group Buys.
Old 07-20-2009, 12:10 PM   #1
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
Thumbs up Godspeed Suspension GB Page!! Coil, LCA, Camber, Toe, Tension, Sway and MORE!!!
GODSPEED Suspension Page!!
Full line of Godspeed Suspension for S13 & S14 IN STOCK!!!
Ready to Ship and Pick Up!!!
GODSPEED Type-RS, Coil-Over Dampers is the perfect enhancement to your track or street car. Featuring 16 Levels of damper force adjustment, full-height adjustment.
The damper can easily adjusted by turning the knob at the top of the damper. Turning the knob can simply change your daily driving or track day needs. The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can easily raise your car to oem height or lower your car for track performance.
The quality and durability of the GODSPEED Racing Damper kits are made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. we stand by our product with 1 YEAR warranty. (from date purchase. Must be installed by professional tuning shop)
89-94 240SX (WILL FIT 180SX ALSO ) S13 TYPE-RS coilover suspension damper (16WAY Damper Adjustable)
NISSAN 240SX S14 95-98 TYPE-RS SUSPENSION COILOVER (16WAY Damper Adjustable)
Features:
- Spring Rates: 8kg Front and 6kg Rear
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height .5" - 3.5"
- 16 Levels of Adjustable Damper
- Single-Cylinder Design
-1 Year limited Warranty
GODSPEED Type-SS w/ Pillowball Upper Mount and Dual Height Adjustments is an high end performance coilover setup designed for everything from daily driving to track competitions. This coilover exhibits superior handling characteristics with the added performance of solid (non rubber) type pillowball upper mounts for an ultra responsive suspension package. Coilovers will come ready to install w/o having to reuse stock OEM rubber mounts. This GODSPEED suspension coilover kit offers superior handling, adjustability, and customizability for all your high performance driving needs. .
NISSAN 240SX S13 89-94 TYPE-SS SUSPENSION COILOVER
89-94 240SX (WILL FIT 180SX ALSO ) S13 TYPE-SS coilover suspension damper
NISSAN 240SX S14 95-98 TYPE-SS SUSPENSION COILOVER
Features:
NISSAN S13 240SX 180SX 89-94 FRONT SWAY BAR
Front 30.05mm (Solid)
Solid Bushing (use Stock Backet)
LIFE TIME WARRANTY!!
NISSAN 240SX S13 89-94 REAR SWAY BAR
Rear 28.3mm (Solid)
NISSAN 240SX S13 89-94 Adjustable Rear Toe Arm
Up to 3 degree
Also Fit 300ZX Non-turbo and R32 Skyline
NISSAN 240SX S13 89-94 REAR CAMBER ADJUSTER
NISSAN 240SX S13 S14 89-98 PILLOW TENSION RODS
NISSAN 240SX S13 S14 FRONT & REAR LOWER CONTROL ARM
89-94 Nissan 240sx (S13)
89-94 Nissan 180sx (j-spec version)
95-98 Nissan 240sx (s14)
NISSAN 89-94 S13 95-98 S14 90-96 300ZX TRACTION RODS
NISSAN 240SX S14 95-98 FRONT SWAY BAR
Front 30.32mm
NISSAN 240SX S14 95-98 REAR SWAY BAR
Rear 28.16MM
NISSAN 240SX S14 95-98 ADJUSTABLE TOE ARM
Also Fit R33 and R34 Skyline
NISSAN 240SX S14 95-98 REAR CAMBER ADJUSTER
NISSAN 240SX 89-94 GODSPEED CROSS BAR (hb only)
NISSAN 240SX 89-94 6 POINT ROLL CAGE Fit Coupe and Fastback !!(also Fit moon roof but headline and A & B pillar plastic panel need to remove!!)
PM or CALL US FOR THE BEST PRICING!!!(Tell Us You from Zilvia.net For Better Discount)
We are S13/S14 Specialist, if you cant find what you need check out our website GodSpeed Project - Intercooler, Turbo Kits, Turbo Manifold, Body Kit or give us a call if you have any question!!
We also have other GB on the forum, so please check them out!!!
Ken @ Fatboy Garage Motorsport
11135 Rush St Unit B
South El Monte CA 91733
626-442-3988
Fatboy Garage is offline
Old 07-21-2009, 07:17 AM   #2
S13HERTZ
S13HERTZ's Avatar
S13HERTZ is an unknown quantity at this point
Send a message via AIM to S13HERTZ
I need to know the price for the front and rear sway bars and rs suspension for a 1989 240sx shipped to 11743 thnxx
S13HERTZ is offline
Old 07-21-2009, 11:20 AM   #3
jayrawr
jayrawr's Avatar
jayrawr has a reputation beyond reputejayrawr has a reputation beyond reputejayrawr has a reputation beyond reputejayrawr has a reputation beyond reputejayrawr has a reputation beyond reputejayrawr has a reputation beyond reputejayrawr has a reputation beyond reputejayrawr has a reputation beyond reputejayrawr has a reputation beyond reputejayrawr has a reputation beyond reputejayrawr has a reputation beyond repute
Send a message via AIM to jayrawr
pm sent. i need some pieces of the cage.. they're lost.. somewhere. MIA. haha
jayrawr is offline
Old 07-21-2009, 12:47 PM   #4
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
I'd like to know the price of s13 toe rods shipped to 43220
Please and Thanks!
slothonaleash is offline
Old 07-21-2009, 05:36 PM   #5
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
what hard wear do you use
rat240 is offline
Old 07-21-2009, 06:07 PM   #6
smellslikecurry
smellslikecurry's Avatar
Trader Rating: (33)
smellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfection
Feedback Score: 33 reviews
what are the specs/material on the cage...
how much for the cross bar shippedd to 11566
smellslikecurry is offline
Old 07-21-2009, 06:21 PM   #7
jdanger
jdanger's Avatar
jdanger is an unknown quantity at this point
price fo coilovers for s13 shipped to 93701
jdanger is offline
Old 07-21-2009, 09:50 PM   #8
180sxdrifter
180sxdrifter's Avatar
180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light
shipped to NY 11432 pls thanks
Instagram @ikigai.no.jinsei
180sxdrifter is offline
Old 07-21-2009, 11:59 PM   #9
FREDDYS13
FREDDYS13's Avatar
FREDDYS13 is on a distinguished road
coils picked up pm me with price
FREDDYS13 is offline
Old 07-22-2009, 02:32 AM   #10
1trkmnd
1trkmnd is an unknown quantity at this point
s13 coilovers shipped to 94124 please? thanks
1trkmnd is offline
Old 07-22-2009, 03:39 AM   #11
k0uki
Trader Rating: (47)
k0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfection
Feedback Score: 47 reviews
front and rear sway bar for s13 fastback shipped to 95121
k0uki is offline
Old 07-22-2009, 04:13 PM   #12
smellslikecurry
Trader Rating: (33)
what do you mean give you an offer haha
is this a gb?
ill give you $10 bucks for it haha
no really
post specs of the cage
Old 07-22-2009, 04:21 PM   #13
rat240
Trader Rating: (87)
look it up on ebay
rat240 is offline
Old 07-22-2009, 04:24 PM   #14
rat240
Trader Rating: (87)
DESCRIPTION : NISSAN 89-94 240SX (HB ONLY) godspeed 6 point anti-roll-cage
(PROFESSIONAL INSTALLATION ONLY!!)
-40mm seamless carbon steel , prebent tubing
-bolt on design with bolts & mounting plate
-comes in silver color
Our roll bars and cages meet or exceed the safety requirements for most off road track. This will reduces the body roll by 40% or more. Perfect for hard corner tracks /drifting. Our bars and cages have been designed to easily install and provide maximum protection. The fit in your vehicle allows quick and easy entry and most importantly, quick exiting, while conforming closely to your interior for a clean, unobtrusive look and feel. All of our bars and cages are certified MIG welded and precision jig notched, providing you with the maximum strength and best fit available. Every roll bar or cage has been designed to fit ??specific car models so only minor ??modifications are necessary for the instal??lation. Most applications are a true bolt-in and require NO WELDING.
rat240 is offline
Old 07-22-2009, 04:26 PM   #15
smellslikecurry
Trader Rating: (33)
Originally Posted by rat240 View Post
look it up on ebay
i dont want the cage
im just asking to make it easier for potential buyers
pretty sure this cage is more form over function...just dont want people getting screwed out of their money when they find out it doesnt meet their tracks standards.
edit...thanks for the info
Old 07-22-2009, 05:02 PM   #16
Fatboy Garage
well....do you have this cage on your car?if not than how you know is not going to work? there alot of drift event here in CA(maybe other state) that require cage, and I'm pretty sure alot of people doesn't want to weld a cage inside the car, so we are offering a bolt-on one.
but thanks for you input tho.
Thanks
Ken,S
Old 07-22-2009, 05:04 PM   #17
Fatboy Garage
is this a gb?
no really
$10 I can give you a sticker lol
Old 07-22-2009, 05:10 PM   #18
smellslikecurry
Trader Rating: (33)
im serious about the cage
tracks have certain safety guidelines thats why i was asking
as for the hb bar...im still waiting on the price??
Old 07-22-2009, 05:28 PM   #19
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
do you only sell the cross bar with all those crazy parts?
What if you just want the "X"
http://bhworld.wordpress.com/
Brian is offline
Old 07-22-2009, 07:11 PM   #20
ChiSleepyEyes
ChiSleepyEyes's Avatar
ChiSleepyEyes is an unknown quantity at this point
Send a message via AIM to ChiSleepyEyes
pricing on coils for 91 s13 coupe shipped to 60415
ChiSleepyEyes is offline
Old 07-24-2009, 03:31 PM   #21
Fatboy Garage
We got more S14 Type RS come In today !!!!!
BUMP BUMP BUPM
Old 07-26-2009, 04:35 PM   #22
loosesocksdiff
loosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of light
price on an s14 ruca?
loosesocksdiff is offline
Old 07-26-2009, 08:47 PM   #23
FusionR240sx
FusionR240sx's Avatar
FusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond repute
Send a message via AIM to FusionR240sx
s14 rucas shipped to 60018
Originally Posted by Wreckless35 View Post
still be flush dropped on KYB AGX struts & s-tech springs
WUT?
FusionR240sx is offline
Old 07-27-2009, 01:12 AM   #24
513drifts13
513drifts13 is an unknown quantity at this point
pm price of cage shipped to 45040
513drifts13 is offline
Old 07-27-2009, 02:42 PM   #25
Fatboy Garage
New Update!!!
the Cage will Fit Fastback,Coupe and Moon Roof!!!
(Moon roof model need to remove Headline,A B pillar Panel(plastic piece) )
Thanks
Ken,S
Old 07-28-2009, 04:11 PM   #26
driven_
driven_'s Avatar
driven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to behold
S14 coils to 53218
Find me on MR2oc!
driven_ is offline
Old 07-28-2009, 06:09 PM   #27
rastaman
rastaman is an unknown quantity at this point
s14 front and rear sway bay ship to 32907
also toe and camber parts
rastaman is offline
Old 07-30-2009, 06:41 PM   #28
titangts
titangts is an unknown quantity at this point
Pm what the best price i could get if i bought, the rear and front sway bar kit,rear toe arms, pillow tension rods, and traction rods at once
to 28214, thanks! Godspeed for the MF win!!!
Car is 92 s13
titangts is offline
Old 07-30-2009, 09:19 PM   #29
msd
msd is an unknown quantity at this point
Price of s13 roll cage shipped to 71118 please.
msd is offline
Old 07-30-2009, 11:49 PM   #30
xdumbxguyx
xdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to behold
price for a cage picked up
xdumbxguyx is offline
