Old 07-03-2009, 08:57 PM   #1
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
Spark plug ceramic cracked and piece fell down cylinder
I had a problem with a compression tester adapter that got stuck. So i accidently tightened a spark plug into the adapter causing it to crush and a piece of ceramic from the tip where the electrode is, fell through the adapter and into the cylinder. Just wondering if a little piece of ceramic would do anything if it fell into a cylinder. Could it possibly damage anything? Id assume no because its a relatively small fragment.
SilviaSR20DET is offline   Reply With Quote
Old 07-03-2009, 09:55 PM   #2
ho1ywars
ho1ywars's Avatar
ho1ywars is an unknown quantity at this point
could score the cylinder wall. id take a peice of brake line and duck tape it up to a shop vac and try to vac out the cylinder as best as possible dude. cant hurt.. and is about all you can do.
ho1ywars is offline   Reply With Quote
Old 07-03-2009, 10:02 PM   #3
jamg
jamg is an unknown quantity at this point
try turning your car upside down, it might fall out.
jamg is offline   Reply With Quote
Old 07-04-2009, 02:22 AM   #4
SilviaSR20DET
Okay ill give it a shot and hopefully i can find the fragments. Do you suggest i take off the valve cover to gain more access to the cylinder?
Old 07-04-2009, 02:27 AM   #5
waterboy
waterboy's Avatar
waterboy can only hope to improve
how would taking off your valve cover get you access to the cylinder,you would have to take the head off for that, rotate the engine so the piston is at tdc then vac that shit out
waterboy is offline   Reply With Quote
Old 07-04-2009, 03:16 AM   #6
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
have you ever taken a little piece of ceramic from a spark plug and thrown it at a car window? the whole thing shatters.
Ceramic is very sharp. If i were you, which i'm glad i'm not right now, I would pull off the whole head and get in there and remove every dang piece of ceramic in there. because you WILL do major damage to your internall engine parts.
play it safe, take that whole thing apart. this way you fix it right the first time, and you won't have to buy a new motor...
or you can mickey mouse it, and get mickey mouse results
handinpants is offline   Reply With Quote
Old 07-04-2009, 05:19 AM   #7
GSXRJJordan
GSXRJJordan's Avatar
^^^ Haha, WILL do MAJOR damage!!!!11!1one!!!
Depending on how big it is, it could find it's way to the cylinder wall. By all means, try to vacuum or spray it out with compressed air. Most likely it'll find it's way out on the first exhaust stroke, but why take the chance?
Old 07-04-2009, 09:06 AM   #8
SilviaSR20DET
Did the whole vacuum thing and it worked great! it sucked out a bigger piece and some little ones and spent some time sucking around the piston so nonetheless i think its all out now. Thank you for the idea, i wouldn't have thought about it. I used a clear silicone hose instead and worked phenomenal cause i could see all the pieces being sucked out of the cylinder.
Old 07-04-2009, 01:43 PM   #9
skyvia686
skyvia686's Avatar
skyvia686 is an unknown quantity at this point
i would take the extra precaution and take the head off. (not that its that easy to do for us nissan guys with timing chains lol but it could score the cyl as ho1ywars above said... and once that happens not too pretty.
skyvia686 is offline   Reply With Quote
Old 07-04-2009, 03:12 PM   #10
SilviaSR20DET
I think all the pieces are gone and do not want to take the head off its just too much work and time for me to do it. From what i saw there 3 pieces two small ceramics and one large chunk that cracked and i sucked them out so im pretty sure im good to go.
