11-26-2013, 08:43 PM | #1 |
testing waters: Type X hatch for trade
Nick
philly 2672067462 price:10k new pic Car was just painted. And before i pull the motor out for no reason and do a bunch of other stuff to it. Id like to test waters...See what i could get to trade. Other wise i will Just drift it all next season..i do not need a daily driver so dont offer me dumb stuff. Lemme know what youve got. Otherwise motor comes out, bay getting painted red and RHD. engine bay is white. Jams are all red. The car has sidemarkers on it now in the front. and ignore the blue tape. Cars im interested in is Something RHD, Or a track car. Or something with a weird swap. even unfinished stuff. I dont care. just no junk. My horrible pics dont do the car justice. [img] When i bought it not to long ago: and a single cam was in it. GOOD: Paint less then 2 weeks old Car has been fully undercoated, wheel wells, frame rails, etc, not cheap advanced auto shit subframe dropped resprayed gloss black. No rust at all Had brake line area rust, but fixed You will not find a spec of rust on the car. New OEM parts: Front bumper and all accessories DOHC throttle cable Front lower control arms Tie rod bellows S14 diff bushings New injector orings Oil cap gasket Master cylinder clutch master cylinder Clutch pedal Clutch slave Drive shaft center bearing wiper cowl plastics headlight plastics clutch fan setup tons more Engine Mods: Freshly Rebuilt SR20DET Type X Blacktop(all new gaskets as well)motor has about 7k miles so far. Greddy intercooler kit Greddy Intake manifold Aeromotive Adjustable FPR Stainless steel fuel lines GT2871R ISIS Turbo elbow Trust Down pipe Trust test pipe Blast pipes Greddy suction intake kit Halman boost controller Walboro 255 fuel pump ISIS cold pipe nismo motor mounts nismo trans mount ISIS radiator Some other shit im forgetting Trans/drivetrain: Spec stage 3 clutch Stock flywheel Welded diff(just got done, no funky noises) Interior: Greddy 60mm boost guage(electronic) Bride Low max gradiaton seat 180sx Type x gradiation floor mats 180sx JDM manual seat belt conversion and all interior plastics are from a type x except door panels and dash..(car was gutted when purchased) Pink Godzilla White sparkle steering wheel NRG quick release works bell hub 180sx Cluster full LED conversion red needles too Newer carpet Exterior: 180sx type x (kouki) front bumper 180sx type x skirts 180sx type x valances 180sx type x spoiler Kouki tails dmax side markers dmax front posistion lights type x turn signals(lower) Shaved rear sidemarkers for the cool jdmness Suspension/steering mods: OEM Nissan FLCA (this month) Nismo steering rack bushings ISIS high pressure p/s line Tien Super drift coilovers Powered by max Tension rods Powered by max Ruca Powered by max Toe arms Powered by max Subframe collars Tien S14 tie rods inner Tien S14 tie rods Outer PBM rack spacers Fresh Alignment Hubs/Braking: Ichiba 5 lug conversion Rear ISIS PRO Front hubs Extended front studs 300zx Calipers all around Hawk HPS pads all around Project MU ebrake shoes Z32 ebrake cables stainless steel brake lines Ichiba front spacers 25mm wheels: Square G33 17x9 +15
just cause your cars crappy, doesnt make it a missile Last edited by Driftpretty; 11-28-2013 at 07:56 PM.. |
11-26-2013, 08:58 PM | #3 | |
The car needed a respray it was 5 different colors white. and the lower body line was shaved...every panel possible was replaced with clean panels and the car now has the lower body line all around. no more useless bondo..
just cause your cars crappy, doesnt make it a missile |
11-28-2013, 07:55 PM | #8 | |
took her out today for a bit.
11-28-2013, 09:22 PM | #11 |
Yeah i still have it. Started to fix it. only in two pieces now.. I went off course once Slowly fixing it then ill paint it to match.
11-28-2013, 10:32 PM | #12 |
12-14-2013, 05:24 AM | #15 |
Ill trade you my red hatch that you did the sr swap on. Its got a newer sr and just the usual bolt ons. it was also hit on the pass 1/4 panel. Ill give you cash ontop if your interested
