09-05-2018, 02:09 PM | #1 |
FS: S14 Kouki track car - SR20DET, Caged
*SOLD*
$13,200 FIRM - located in CT. --97 240sx SE (zero rust issues and no other issues that would prevent you from tracking it today.) https://youtu.be/Fe-v4BT9uNI Great car that I've owned and built up over the years (long-time owner of the car and IIRC only the 2nd owner after purchasing it stock in FL). Engine/Fuel/Performance: --Same gen SR20DET but w/ S15 turbo (Swap by CIP Motorsports / 240sxMotoring) --Power FC dyno-tuned by Dentsport (Very conservatively to 240hp/260tq at the wheels @15psi on 93 octane) --550 cc injectors --Walbro fuel pump --Recirc BOV --Undersized (lightly) crank pulley --ACT clutch --Z32 MAF with Apex'i intake kit --Koyo radiator --Greddy FMIC --Battery relocation kit, to trunk --Circuit Sports 3" exhaust, w/ test pipe (sounds great, no dB concerns) --VLSD Interior/Safety: --Gutted with a full cage (built by CIP/240sxmotoring). POR15 most of the interior --Driver's side: Sparco Evo seat (newer) on Bride adjustable rail, window and seat nets (not pictured) --Passenger's side: Sparco Evo seat (older) on fixed Planted rail --G-Force Pro 6-point harnesses --Driven steering wheel (removable) --Keyless ignition --Battery kill switch --STRi boost, oil pressure, water temp gauges --No heat or a/c, removed for track use but still have some parts Wheel Tires/Suspension/Exterior: --17x9 Enkei RPF1s --255/40/17 NT01s (life left) --ARP extended wheel studs --NovusTech hub-centric 15mm spacers (front) --Front suspension: (veilside180sx mounts) Bilstein shocks, Ground control camber/caster plates, H&R springs --Rear suspension: Koni yellow shocks, Tein top hats, H&R springs, Cusco RUCAs --Seibon carbon fiber/fiberglass hood w/ locking Aerocatch+ pins Brakes: --Front: Wilwood Forged Superlite calipers, two-piece rotors (w/ BNIB spare rotors & some hardware), Defsport hats & brackets --Rear: Z31 bracket/Altima rotor setup --Hawk HT10s (on the car) and DTC60s (currently off the car) --Stainless brake lines (Please do not PM me about parting anything. If you want a list of available parts, please visit my other older thread to see what's left http://zilvia.net/f/showthread.php?t=645613). All of my extra 240sx parts will be included with the car) I've since removed the vinyl "244"s. The paint is in great condition.
97 240sx se Last edited by 0wn3r; 12-09-2019 at 08:34 PM.. Reason: Spacer size question, a/c heat question, price drop |
09-07-2018, 03:15 PM | #5 |
Come on up and make it yours, haha. [Edit: Tahoe and trailer both SOLD] Thanks guys! I'm hoping someone does not ruin it either.
97 240sx se Last edited by 0wn3r; 02-17-2019 at 11:33 AM.. Reason: Sold Tahoe & Trailer |
09-13-2018, 02:07 PM | #6 |
09-17-2018, 10:21 AM | #7 | |
Hey, thanks! Just got back from a busy weekend away. I don't have a link or ad up yet for the trailer as I was hoping the 240 would sell first (in case someone had delivery issues and needed me to haul it somewhere). It's a 2011 steel open trailer w/ ramps (kind of like the below). $1700
97 240sx se Last edited by 0wn3r; 02-17-2019 at 11:34 AM.. Reason: Sold trailer |
11-20-2018, 08:55 AM | #10 |
[Removed: Tahoe and trailer SOLD]
97 240sx se Last edited by 0wn3r; 02-17-2019 at 11:34 AM.. Reason: Tahoe & Trailer SOLD |
01-16-2019, 11:12 AM | #14 |
Called but no answer.
All PMs replied to! Cheers for 10,000+ views! Head turner
97 240sx se Last edited by 0wn3r; 02-17-2019 at 11:35 AM.. |
02-05-2019, 04:34 PM | #17 |
Thanks! I thought so, seeing as I have at least over $22K into it. Figure it might sell soon now that we're getting closer to track season.
Small price drop!
97 240sx se |
09-08-2019, 07:24 PM | #26 |
PMd back and updated the OP about the heat and a/c removal for others.
Thanks everyone! Lots of interest but no takers yet
97 240sx se |
10-13-2019, 06:54 PM | #28 |
Host the images elsewhere. Photobucket has lowered the resolution of the images to the point of being unviewable and plastered their watermark all over it for safe measure
We should all give PB a big FU and the middle finger. Always pulling some shit...... |
10-14-2019, 07:19 PM | #29 |
Sent PM
You think I could make it back to SoCal if I bought from you in CT and drove back across the country? Also curious about the starter/ignition setup can it be modified to be a lil safer? |
10-15-2019, 05:17 PM | #30 | ||
You can certainly drive across country if you want but I really do not recommend this. I wouldn't find it practical. I'd personally look into having it shipped. What do you mean by safer? Are you talking about adding an external kill switch? Generally speaking, I'm sure you can modify it to your preference or safety requirements for your club/series.
97 240sx se |
