02-06-2013, 07:24 PM | #35 |
UPDATE:
picked up some more metal to mount the fuel cell all welded up and solid as FUUU still have some trimming and such to do welded up the widebody section then got some more goodies. the color is from a TVR and we threw in a shit ton of flake unfortunately we had some reactions with the paint so we had to stop. but when its done it will have a few coats of purple and clear as well i redropped the subframe and will be starting the undercoating and POR15 friday
02-07-2013, 11:52 AM | #38 |
Damn, looks good, a couple things though...
1) Thought this was gonna be a Beams swap... which would have gnarly to say the least. 2) You really like purple, allot. Other than that, looks really good, what kind of power are you shooting for with this setup?
* S14SR22 * 9.0 c/r * GT3071R * |
02-07-2013, 07:46 PM | #39 |
Haha hell no! Gotta stay nissan motor. Yeah purple is my favorite color. Honestly not sure on power levels. Probably around 500ish. But going to keep it on wastegate 14psi until I learn the car. Then crank it up later on
02-09-2013, 06:01 PM | #40 |
UPDATE: started undercoating the whole car with POR15 and 3m rubber spray
and my buddies shop puppy pit bull says hello! my painter is coming back monday night to finish the engine bay. then its motor time
02-12-2013, 06:48 PM | #42 |
thanks dude! i work at Midwest Street Performance aka MSP Tuned. i traded the fd straight up for the slammed E36 M3 clone i had
UPDATE: finally got the paint issue sorted out! going back tomorrow to wetsand and buff it. it came out pretty damn good. it messes with your eyes, its different shades of purple and depends how you look at it then we picked up the shop evo from storage because its new MSP turbo came in!
02-13-2013, 12:24 PM | #43 | |
02-14-2013, 06:52 PM | #45 |
yes just for strength, since i didnt buy lower control arms yet i figured this would do for now. ill probably do an angle kit and such next winter
02-14-2013, 07:39 PM | #46 |
UPDATE: engine PRON, fitted the front subframe. just have to find where i put the bolts for the clutch/flywheel so i can put the trans on then drop the car on the motor.
trying to get the sparkle in the powedercoat to show
02-16-2013, 12:53 AM | #47 |
UPDATE: buffed out the paint and got the motor in
i decided to leave the motor on the stand and drop the car down as to not scratch the paint. if anyone decided to do this, i had to pull the turbo and throttle body off. then i started assembling things. got the radiator and the intercooler installed tomorrow ill hopefully be tackling the trans... if i can find my flyhwheel bolts.
02-16-2013, 03:00 AM | #48 |
Wow, nice progress, Just been lurking on this one for a little bit. How is that hi-mount held in place, if you happen to have pictures? In my opinion, that white valve cover kinda throws off the engine bay tho. Maybe a wrinkle black might look a smidge better, but what do I know, my bay is still bare metal with old paint in places I'm too lazy to sand down. Overall, it's a nice project, very very nice.
in any situation....thou shalt blaze |
02-16-2013, 10:17 AM | #49 | |
02-18-2013, 01:28 PM | #53 |
I really haven't a clue. At least 400. Closest set up I could find to mine with a dyno sheet out down 550. I'm not too concerned about power. It will just be a safe set up.
02-18-2013, 10:18 PM | #55 |
Update: bolted on the subframe and diff. Then cleaned up the stance coilivers
Also started pressing out the rear hub bushings Starting to look like a car again!
02-24-2013, 12:13 PM | #58 |
Update: coated all my control arms and knuckles in POR15
Finally got a throw out bearing since I lost all three of mine... So I can pop the trans on and then all I need are bolts for the rear arms
02-25-2013, 06:14 PM | #60 |
It's 2k primer. Yes it's out of a can it like $16 a can. I used 3 cans. It's easy to paint over. That's why it's so expensive. The reactions we had we due to too much activator in the basecoat
