07-22-2008, 08:17 PM | #1 |
Steel Bodied coilovers
Does anyone know of a list of which coilovers are steel bodied and which are aluminum?? I need to find a set of steel bodied coils....at least the fronts need to be steel. Thanks!
07-23-2008, 04:38 AM | #2 | |
Go to the manufacturer's site.
It usually says. Or just take a magnet to it.
07-23-2008, 08:30 AM | #4 |
Older Style Cusco's are steel not sure about them now
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
07-23-2008, 10:32 AM | #6 |
Now you see why I am confused...everyone has a different take and I can't find out from most adds etc... I am looking at Cusco, but I heard that some of their newer coils are Aluminum??? Thank you for the help so far though.
Anyone else know?
07-23-2008, 11:06 AM | #9 |
Steel bends rather than breaks, therefore an impact on it does not mean instant death typically.
www.nissanroadracing.com |
07-23-2008, 11:07 AM | #11 |
any coilover made by BC is aluninum, as well as tein.
That covers (off the top of my head) -megans -a'pex -hks -greddy Other companies that use aluminum bodied coilovers are: k*Bee buddy club zeal power by max (someone double check me on that)d anyone know about koni's
07-23-2008, 11:12 AM | #12 | |
The majority of companies use steel shocks/struts with aluminum lower and upper mounts. That goes for pretty much all of the manufacturers you have listed there.
Koni's are all steel with the exception of the 2817, in which the lower mount is steel. KW is the only company I know of using stainless currently. Quote:
07-23-2008, 11:08 AM | #13 |
I believe stance( gr+/gr+pro) usese Steel prolly stainless
b/c their higher up set is aluminium and cost like 1700 bucks but i could be wrong.... some one dc it for me
07-23-2008, 11:11 AM | #14 |
Steel can be welded to a spindle!! I am looking to cut the stock spindle set up on my Y33 and welding the coil onto it rather than doing a full S-Chassis front suspension swap.
also, I was told that Megan Track's were Steel??
07-23-2008, 11:20 AM | #15 |
Trader Rating: (29)
Feedback Score: 29 reviews
iirc, Brian Harte has some custom steel Zeals... I could be wrong though. i Don't even remember where I heard that from
@adrianfromthecastle |
07-23-2008, 05:19 PM | #19 |
I have Tanabe sustec pro S-OC2 's which are all steel. Thier perfect for dd but if your building a full on track/drift car you might want something a little stiffer. http://www.tanabe-usa.com/coilovers/s-ocII.asp
07-23-2008, 05:29 PM | #20 |
Mine are steel pistons with aluminum mounts(footwerks).
Extra Made Garage Follow us on Twitter: http://twitter.com/emf_distrib 1-888-240-8517 Distributor for Footwerks suspension. email at [email protected] www.footwerksusa.com |
07-23-2008, 05:50 PM | #21 |
The main merit to aluminum bodied coilovers is weight savings. Aluminum bodied coilovers are extremely light.
I think Zeal only uses aluminum for the bodies when it's not a strut type suspension. Aluminum would be a bit too brittle for type of loads that strut type suspensions experience. I heard they have the option of being aluminum bodied, however it's only offered for non-strut type suspensions. For an S-chassis, the fronts will be steel (and inverted) and the rears will be aluminum. Last edited by kawaiid; 10-31-2008 at 03:54 PM.. |
07-23-2008, 05:58 PM | #22 | |
The reason Brian has steel front Zeals on his S14 is because the Zeals came with his car (when he bought it) The Zeals from the previous owner was purchased a while back obviously, so at that time, I guess they were allowing aluminum for all around (front + rear) Then at a drifting event (I think Cali Speedway back in the day), he snapped the fronts, which he then got replaced and serviced back to proper spec by Endless USA On a side note, KBee's are not aluminum, except for maybe the upper mounts
A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan Advertiser's Specials! Read / Give Feedback! Please Rate Us! |
07-23-2008, 06:00 PM | #23 |
ZEAL is 170% quality and in my opinion, THE best you can get.
I have had them on my car for years and love them. I'm just bummed I can't swap them right onto a S13!!!
http://bhworld.wordpress.com/ |
