03-07-2016, 03:14 PM | #1 |
Trader Rating: (29)
Feedback Score: 29 reviews
Enjuku Racing - Tomei Oil Pans - In Stock
TOMEI Oversized Oil Pan - Nissan SR20DET
http://www.enjukuracing.com/products...n-sr20det.html Tomei began operations in 1968 as a race car tuner in Japan. Over the last 40 years Japan has emerged as one of the leaders in automotive research, racing, and culture. Tomei products have been utilized in nearly every motor sport imaginable. Tomei’s racing heritage means their research and design team have first hand knowledge of the extreme demands racing puts on an engine. Using only the highest quality materials means that Tomei’s products can handle the intense strain and heat a purpose built engine will experience whether it be on the street or the track. Tomei’s attention to detail is second to none. All of their products are thoroughly researched and engineered to achieve optimal efficiency. Because of even miniscule differences in measurements can cause catastrophic engine failure, all Tomei products fall within strict tolerances. Tomei machines all of their engine components to enhance airflow and ensure proper fitment and seal. Tomei's large capacity oil pan prevents oil starvation under extreme driving conditions for your SR20DET Engine. Intense G forces of both vertical and horizontal direction can cause oil to slush around that can lead to oil circulation problems and engine oil starvation. Tomei's large capacity oil pan fixes that problem with integrated baffle plates to secure oil slushing and provides adequate oil circulation within your motor. The oil pan also allows an oil capacity gain of 600cc to make sure your motor gets the oil it needs. probably one of the most high quality and most reliable oil pans on the market today. Oil Pan Also come pre-tapped for an oil temperature sensor, thread size M16 P1.5**
Office: 352-241-8399 / 1-888-SR20DET (772-0338) YouTube.com/c/EnjukuRacingParts http://www.enjukuracing.com [email protected] |
