Old 06-01-2011, 05:30 PM   #1
Nibras
Nibras's Avatar
Nibras is an unknown quantity at this point
Send a message via AIM to Nibras
Helppppppppppppphelppppppppppppp
alright so i just finished throwing in this ca18det swap in my s14 . i upgraded the stock turbo to a gt28 turbo , i am noticing when i drive the car , 1-3 gears are fine when i get to 4th gear and hit about 3100 rpm with the throttle fully open nothing happen after that point until i go under the 3100 rpm mark. its usually right before the boost kicks in in those high gears.
and when i get to 5th gear i can not exceede about 2500 rpm .
i am not sure if this would link to a maf problem. or a boost problem .
but i can pretty much red line the car in the first 3 gears and boost no problem.
some input would be nice ! thanks ZILVIA PEEPS.
Nibras is offline   Reply With Quote
Old 06-01-2011, 05:37 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Not too familiar with the CA18, are there 4th gear and 5th gear sensors in the transmission? If so, are those plugged in? Does it feel like a fuel cut when you exceed the rpms?
Old 06-01-2011, 05:41 PM   #3
Nibras
Nibras's Avatar
it feels like everything cuts out, and not slowly its as if the car shut off or something, it only does this once i get to that rpm. the car use to be automatic ka but i converted the harness and rewired it onto the tranny
Old 06-01-2011, 05:49 PM   #4
Sileighty_85
Sileighty_85's Avatar
what MPH are you at at 3,100 in 4th?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-01-2011, 07:49 PM   #5
projectimura
projectimura is an unknown quantity at this point
i think you have a small leak. or your maf is sh*$!
projectimura is offline   Reply With Quote
Old 06-02-2011, 08:49 AM   #6
Nibras
Nibras's Avatar
id say around 45-50
Old 06-02-2011, 08:51 AM   #7
Nibras
Nibras's Avatar
i dont think its the maf cause its the same maf the kid before me had in his s13 and i new him and drove with him and never had this problem ,and as for a leak , its doesnt feel liek aleak problem , once i hit 3100 rpm the pedal becomes completely useless no matter how far i push it it feels like a dead pedal
Old 06-02-2011, 08:51 AM   #8
Edwin562
Edwin562's Avatar
tranny sensors(5th gear) is what popped in my head... check them out...
Old 06-02-2011, 08:53 AM   #9
Purestock240
Purestock240 is an unknown quantity at this point
try and pick up an automatic ecu, i think it disregards all of the gear sensor issues and still runs flawless, maybe someone else has insight on this
Purestock240 is offline   Reply With Quote
Old 06-02-2011, 08:56 AM   #10
Nibras
Nibras's Avatar
what do you want me to check for? they are all there should i try unplugging them and driving without them
Old 06-02-2011, 08:57 AM   #11
Nibras
Nibras's Avatar
oh man it was hard to track thiis 5spd ecu ITself ! ill see if anyone in orlando has one i can just mess with
Old 06-02-2011, 09:03 AM   #12
KiLLeR2001
Trader Rating: (46)
I'd guess something with the tranny sensors or the ECU itself. Double check all the wiring connections in between.
Old 06-02-2011, 09:05 AM   #13
Nibras
Nibras's Avatar
thanks im on it, ill let you know.
Old 06-02-2011, 10:37 AM   #14
cjmirabal1
cjmirabal1's Avatar
cjmirabal1 is an unknown quantity at this point
yeah check ecu out... ive seen some picky motors with similar issues and it was just a simple ecu swap... there picky lil things lol, i cud imagin in a s14 also
what ecu and maf are u running?
cjmirabal1 is offline   Reply With Quote
Old 06-02-2011, 05:33 PM   #15
Nibras
Nibras's Avatar
im running a normal ca18det maf and 5spd ecu
the numbers on the ecu MEC-D016B and number 78 it says its for a MT . so i shouldnt see why theres a problem
Old 06-02-2011, 07:05 PM   #16
cjmirabal1
cjmirabal1's Avatar
Upgrade ur maf...stock maf blows even with stock turbo
Old 06-02-2011, 07:46 PM   #17
Nibras
Nibras's Avatar
you mean to a z32 one. this wouldnt have this much affect on it tho! i test drove the car today and i got it to rev in 4th and 5th but i was redling it in 3rd and switched to 4 and redlined it again and then to 5th then i turned the car around and the car died.
Old 06-02-2011, 08:23 PM   #18
TheRealSy90
TheRealSy90's Avatar
You running a CA18 ecu? Did you re wire the ecu plug?
Old 06-03-2011, 07:17 PM   #19
Nibras
Nibras's Avatar
ya the kid before burnt his wire harness and the ecu so i got it rewired and got a ecu off someone . the ecu is a bit different as the old one was from a silvia and the one i got was from a 180sx ca18det but the motor is the same so i dont see why it would affect it. i figured this problem occurss when i reach a certain speed.
240sx, ca18det, ka24de, s13, s14
