Old 08-24-2001, 03:48 PM   #1
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
I'm looking into the Whiteline adj. swaybars for my S13.  I figure I'll just get a rear one b/c I like a loose car better than a tight one.  Are they a good choice?  And is it wise to just get the rear?
LanceS13 is offline   Reply With Quote
Old 08-25-2001, 02:08 AM   #2
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
I would recommend the whiteline bars although just getting the rear will caust for to much understeer and cause the front to spin more easily. Save some $ and get the front too then play with the adjustment to get the perfect level of oversteer or understeer that you like.
West is offline   Reply With Quote
Old 08-25-2001, 10:34 AM   #3
LanceS13
AutoX Junkie
You've been awake too long Mark...j/k:cheesy:. No, I'm sure a thicker rear bar will cause oversteer, not understeer...the rear wheels should brake loose first.  My question is will it be too much oversteer?
(Edited by LanceS13 at 2:39 pm on Aug. 25, 2001)
Old 08-25-2001, 08:06 PM   #4
West
OMNOMNOMNOM
West's Avatar
pretty damb sure it will make the front lose traction first, and yes I am always up to late <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 08-25-2001, 08:50 PM   #5
LanceS13
AutoX Junkie
Well...I'm gonna stand my ground on this one. I'm an ex-Honda owner (cars known to push b/c of their FWD configuration), which gives me a pretty good background on neutralizing a tight car. For example, a 'Teg GS-R has an 18mm rear bar, but the ITR has a 22mm rear bar to take care of the understeering problem. Check these out if you still don't believe me.
<a href="http://www.240sx.org/faq/articles/suspension_anti.htm" target='_blank'>http://www.240sx.org/faq/articles/suspension_anti.htm</a>
<a href="http://www.turnfast.com/tech_handling/handling_tuningtable.lasso" target='_blank'>http://www.turnfast.com/tech_handling/handling_tuningtable.lasso</a>
I know it will alleviate the 240's tightness, but will it make it oversteer uncontrollably/unpredictably?
(Edited by LanceS13 at 10:42 pm on Aug. 25, 2001)
Old 08-26-2001, 12:47 AM   #6
LanceS13
AutoX Junkie
Ok...can someone tell me what the stock sway bar diameters are? Are they hollow or solid? &nbsp;If they're solid and I know how much I'll be increasing the bar diameter, I can get an at least a vague idea of what the car will do with which bar where.
(Edited by LanceS13 at 1:50 am on Aug. 26, 2001)
