Old 07-16-2018, 06:09 AM   #1
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
SR/KA Neutral switch - normally open?
Talkin' Sr or KA manual trans.
Is the neutral switch the same as the reverse/5th gear switch?
I was under the assumption the neutral switch went to ground when in neutral, so ECU would see ground at that terminal when in neutral. I just assumed this for whatever reason.
But my trusty multimeter tells me that ain't true. The switch is normally open, meaning open in neutral and closed in gear.
I can't trust that the switch I have in that spot is correct, it 'could' be a reverse switch for all I know...unless they are all the same?
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 07-16-2018, 07:46 AM   #2
onehundredoctane
onehundredoctane's Avatar
That's backwards. . . the only way that it could work is if the neutral safety switch was closed when in neutral, to complete that circuit and allow 12v to go to the starter.
Old 07-16-2018, 08:06 AM   #3
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
The neutral switch has nothing to do with the starter interlock. That comes from a switch on the clutch pedal, or park/neutral sensor in an auto trans.
Old 07-16-2018, 10:04 AM   #4
KoukiMonsta
I am NOT describing the switch on the clutch pedal.
It COULD work either way, it depends how the ECU functions - which is the whole point of my question. I do not know how it functions.
@UpshiftEngineering
Old 07-16-2018, 11:56 AM   #5
LoSt180
LoSt180's Avatar
Trader Rating: (18)
The ECM detects the park/neutral position when continuity with ground exists.
When the gear position is in neutral, the PNP switch is "ON".
In electrical terms, the switch "closes" the circuit when in neutral, and "opens" the circuit in any other position.
Here's the circuit diagram for the neutral position switch. Drawing is the same for all S-chassis manuals I have on hand.
The KA 5th position and reverse switches function the same way.
Old 07-16-2018, 02:06 PM   #6
KoukiMonsta
The thing is, using a multimeter and probing the leads, this is not true.
In neutral I have zero, open, continuity. In gear I have continuity.
I think I am going to remove the switch, PITA to get to tho..and confirm my sanity as to whether is is NO or NC.
It's bee a long time since I had a tranny open, but I am not visioning how this would work - unless the switch is normally closed. I don't see any way the switch could be depressed in any shifter position other than neutral.
@UpshiftEngineering
Old 07-17-2018, 07:42 AM   #7
onehundredoctane
I know it's not "advised". . . but you can bypass it so the car will start regardless.
Several cars I've owned were this way since they were originally autos.
Old 07-18-2018, 05:33 AM   #8
KoukiMonsta
this switch, located on the rear end of the transmission, has nothing at all to do with that.
This is strictly input the the ECU.
I am wiring the car from scratch, and it sure as shit doesn't have the clutch interlock switch.
@UpshiftEngineering
