Old 05-03-2021, 12:05 AM   #1
Corbic
Corbic's Avatar
Compatible Fuel Pump Hats? S13
Anyone know what if any other fuel tank top hats work in an S13 tank?
Q45, J30, etc?
Old 05-14-2021, 09:55 AM   #2
Corbic
Corbic's Avatar
Nothing? Come'On Guys!
I need to fix my fuel float since it's stuck.
Old 05-14-2021, 02:58 PM   #3
PoorMans180SX
PoorMans180SX's Avatar
This looks pretty close?
https://www.ebay.com/itm/FUEL-GAUGE-....m46890.l49286
Old 05-14-2021, 05:16 PM   #4
Corbic
Corbic's Avatar
Originally Posted by PoorMans180SX View Post
I saw that, but that is for a carb truck with inline pump.
Old 05-14-2021, 10:26 PM   #5
1990 sr hatch
1990 sr hatch's Avatar
1990 sr hatch is an unknown quantity at this point
Im sure you could swap over the potentiometer/fuel level sensor, from that datsun pickup sending unit. And swap it to your existing fuel sending unit.
1990 sr hatch is offline   Reply With Quote
Old 05-15-2021, 06:18 AM   #6
burnsauto
burnsauto's Avatar
There a reason you don't want to get an s13 one? Are you trying to do this on the cheap?
Old 05-16-2021, 11:39 PM   #7
Corbic
Corbic's Avatar
A new S13 one is $500 and people want +$200 for used ones in worse condition then mine.
I ended up pulling a J30's pump and snagging the float off it for $5.
Got it swapped over, just need to soder.
Old 05-17-2021, 10:04 PM   #8
slider2828
slider2828's Avatar
http://www.radiumauto.com/Fuel-Pump-...san-P1998.aspx OR something like this
Turn and Burn!
Old 05-18-2021, 06:36 AM   #9
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
Originally Posted by slider2828 View Post
WOW
That is pretty awesome
lok is offline   Reply With Quote
Old 05-18-2021, 09:59 AM   #10
burnsauto
burnsauto's Avatar
Originally Posted by lok View Post
WOW
it is, but to anyone interested, just remember it does not come with a new float mechanism for the fuel gauge. That needs to be used from the original oem assembly. Other then that, it's the sneaky pete of in tank fuel systems. Very nice that they give you the option of using AN fittings, or traditional rubber fuel line.
Old 05-18-2021, 10:55 AM   #11
slider2828
slider2828's Avatar
I just saw this on sammits channel. I wish they had a float integration.
But truthfully, I've ridden motorcycles for awhile now, never relied on fuel gauge. Just mileage.....
Turn and Burn!
Old 05-28-2021, 10:25 AM   #12
TheRealSy90
TheRealSy90's Avatar
I saw a guy recently use a D21 pickup and trim the vertical tubes shorter.
Such a good signature.
Old 05-29-2021, 10:02 PM   #13
jr_ss
I was going to mention D21. Some modification required, but should fit like factory.
