Old 03-11-2011, 04:56 PM   #1
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Talking multi after market guage setup question
can i or is it safe to use the accessory signal as the power signal for all my after market gauges. i see no point into tapping into numerous signals ie power sources...but if i have to, then i have to
S-Nation S13 is offline   Reply With Quote
Old 03-11-2011, 09:44 PM   #2
bardabe
bardabe's Avatar
it's fine just make sure you stick a fuse in there just in case something where to happen to all that wire clutter, a small 7.5A should be fine.
Review Thread
bardabe is offline   Reply With Quote
Old 03-12-2011, 08:13 AM   #3
S-Nation S13
Trader Rating: (92)
Thumbs up
..ok so what your saying is ground all the grounds, to one point. then bundle up all the power sources together (for the gauges) and befor i connect all of them to the source, put a inline fuse 7.5a...correct, if so i have a left over inline fuse holder for a 15a circuit. i should be good...thanks for the help bro
Old 03-12-2011, 09:31 AM   #4
herbieS13
herbieS13's Avatar
herbieS13 is an unknown quantity at this point
Send a message via AIM to herbieS13
you can put all the grounds at 1 point depending on how many there are but it wouldnt hurt to have more than 1 ground point just to be safe
herbieS13 is offline   Reply With Quote
Old 03-12-2011, 09:58 AM   #5
Bryants95240sx
Bryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the rough
i would really recommend using a relay, pull a power source wire that's a larger gauge wire use the power source as your "trigger" wire. i would not power all your gauges off that one wire.
Bryants95240sx is offline   Reply With Quote
Old 03-12-2011, 12:22 PM   #6
chiboy002
chiboy002 is an unknown quantity at this point
i wouldn't power multiple gauges from the same wire, you can ground to the same point but don't pull from the same.
street dancer.
GLEAM
Old 03-12-2011, 12:58 PM   #7
usajdm
usajdm's Avatar
usajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond repute
Originally Posted by bryants95240sx View Post
i would really recommend using a relay, pull a power source wire that's a larger gauge wire use the power source as your "trigger" wire. I would not power all your gauges off that one wire.
yes!
What the hell is "BALLER" or "GANGSTER" status, about a 240sx?
usajdm is offline   Reply With Quote
Old 03-12-2011, 01:49 PM   #8
chiboy002
not to thread jack but if i were to wire two gauges to the gauge cluster, would i need a fuse or would the gauge cluster fuse be ok
street dancer.
GLEAM
Old 03-12-2011, 02:28 PM   #9
Bryants95240sx
any time i had anything extra over oem i would put a fuse in.
aftermarket, gauges, s13, s14, setup
