Old 11-29-2008, 09:48 AM   #31
CmR333
CmR333's Avatar
CmR333 is an unknown quantity at this point
Originally Posted by smelly240 View Post
1. if you gotta ask HOW - you arent capable.
2. if ur asking how much it costs... you arent capable.
3. if someone else has to fabricate it - u might as well get ikeya (its better anyway)
D. If you can make it yourself, you wouldnt ask those types of questions.
5. gsxr bodies need more materials, either way its a bitch.
gtir setups actually went up in price. they're going for 250 without a rail/inj and 300+ with rail and inj. they wont accept normal inj apparently - you have to machine the fuel rail.
i ask that question because im new to the sr20 not because i dont know what the hell im doing, your wrong for assuming that about me. I have built my entire car by myself with almost all my parts being made by me. i havent shopped for either one so i figured i would ask.
CmR333 is offline   Reply With Quote
Old 11-29-2008, 10:36 AM   #32
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Sure open wheel race cars use plenums on their ITBs. They've got more money in their ITB/R&D/Intake set ups then anyone on this forum has in their entire car.
For the amount of time/money/hassle it would take to make an ITB set up work more efficiently then a large throttle bodied greddy intake manifold it just wouldn't be worth it unless you know exactly what you're doing and have all of the tools to conceptualize the plenum design before actually making one (ie computer program + know-how to use it).
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 11-29-2008, 05:02 PM   #33
4sfed180
4sfed180's Avatar
4sfed180 can only hope to improve
Send a message via AIM to 4sfed180
making an itb setup work is not hard. having machining equipment, a super flow 600 flow bench, serdi head machine, and an engine dyno doesnt hurt either though
they hardest part of an itb setup is tuning it. most likely you will not be able to run your stock ecu and maf. well you can but i would rather go with a nice standalone like electromotive. high resolution and very strong ignition as well as tons of ecu functions to play with.
this is my current project since the ITB's on my sr20 are done.
i got a set of toyota atlantic 4age TRD itb's. they come in pair of two. im doing this for my 1jz-gte head. i got the whole itb setup for 75 bucks
i did all the measurements and already made the adapter flange drawing in Pro-E.
the amount of R&D work that goes into actual racing engines is insane and let not talk about the cost. the only solution is to do it yourself. there are plenty of engineering and non engineering book you can find on fluid flow.
you can get really technical with it and pick up Sengel's books on thermo, heat transfer, and fluids. or you can pick up an old school book called "practical gas flow"
both have helped me greatly to understand how to port heads and why it is done in certain areas. after doing some light math i can see what they are talking about. finally the work is backed up testing on a flow bench.
for me being a 23 year old college student i can afford to buy bolt on itb setups but i have some time on my hands and access to tools to learn to do it myself.
btw the gti-r setup uses regular top feed low impedance injectors. they are 444cc stock and are yellow. they are the same type injector as the RB-series engines(not sure of fuel flow rating on the rb injectors though)
I build air pumps!
4sfed180 is offline   Reply With Quote
Old 12-19-2014, 01:12 PM   #34
Drakkar
Drakkar is an unknown quantity at this point
Just came across this and thought I would add this product to this thread. I have no experience with it but am currently exploring intake options.
Cheers!
http://rc-turbo.com/products/product_detail.php?ID=354
Drakkar is offline   Reply With Quote
Old 12-19-2014, 01:31 PM   #35
Scott@FontanaNissan
Scott@FontanaNissan's Avatar
Scott@FontanaNissan is an unknown quantity at this point
Send a message via AIM to Scott@FontanaNissan
GTiR and RB26 actually use the same exact injectors, so whatever is plug and play for a GTR is also plug and play for a GTiR
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected]
Scott's Personal Website/Blog: http://www.scottandkerryann.com
Scott@FontanaNissan is offline   Reply With Quote
