04-01-2013, 12:57 AM | #1 |
93 MT 240sx ka won't start
So it was a normal day . Drove to the stores went it for 5 mins came out and my car won't start( will turn over) . Battery is new start works fine I'm getting fuel and I'm getting spark. I don't know what it can be , no check engine so idk.
Please help. |
04-01-2013, 01:07 AM | #4 |
Are ur injectors firing? Ya ur getting fuel to the rail but whatabout past the injectors? Also how are u testing for spark?
*edit Also a list of modifications etc could help too |
04-01-2013, 01:14 AM | #5 |
No mods, a stock ka24de
I check all spark plugs by taking them out grounding them and turning over the engine and they all spark a nice blue spark, as for the injectors I don't know but I use the starter fuild it should have turned on for a couple of secouds |
04-01-2013, 01:22 AM | #6 |
So it's not even tryin to start? Also are u just spraying thru the tb? Try having someone hold the gas at wot and spray thru a vac port closer to the intake ports. Its possible the starting fluid isn't gettin to the intake ports. If it works its something to due with the injectors (ecu, wiring, etc)
04-01-2013, 10:00 PM | #11 |
could be a loose wire somewhere.
wiggle around the injector connectors. That happen to my S13 also. 2 mins inside Autozone, and once I came out it wouldn't start. I started tightening all the wires distributor, spark plug wires, and pushing down the injector connectors made it start right up. Just a thought. |
240sx s13 |
