Old 11-10-2012, 12:08 PM   #1
Trickygreek
Trickygreek is an unknown quantity at this point
91' Veilside Promo 300zx TwinTurbo
Hi everyone, I am brand new to the forum, and own a 1991 300ZX Twin Turbo, right hand drive, manual 5sp transmission, 2+2, 67,xxxkms on original VG30DETT motor, has T-Top roof, PW, PL, PS, AC, HICAS, running on 15/40 royal purple synthetic oil and K&N oil filter (changed out every 1500kms)
Overhaul done at 50,000kms includes:
- Timing Belt
- Power steering belt
- A/C Belt
- Alternator belt
- New intake plenum gaskets
- Half moon seals
- New hoses (coolant hoses, fuel lines, air lines, PCV lines, Vacc lines)
- New knock sensor wiring
- New knock sensor and Knock sensor relocated
- Throttle body gaskets
- IAA gaskets
- Valve cover gaskets
- Fuel filter
- Timing belt tensioner
- Crankshaft seal
- Crankshaft oil seal
- VTC springs
- VTC cover plate o-rings
- Thermostat
- Water pump
- A/C belt
- Catalytic converter overheat temp sensor
- O2 sensor
Power Mods:
- Dual Selin Cold Air Intakes
- x2 Selin Mass flow air sensor
- Greddy 3 row front mount intercooler
- Veilside custom hard pipe kit (Polished Chrome/blue&black couplers)
- Aftermarket Wastegate (not sure of the brand or size were put on in Japan.)
- Throttle body coolant bypass
- Nismo Short shifter
- Steel braided brake lines
- Steel braided fuel lines
- Selin MAF translator
- APEXI AVC-R Manual Boost controller 1st Gen
- HKS type 1 turbo timer
- Brand new Yokohama Tires Rear: 275/35 r18 95w, Front: 245/35 r18 95w
- Carbon canisters removed
- Dual to single exit exhaust system conversion
- 5zigen border 304 max Exhaust System 5" tip (Very RARE). Race only muffler certified by JASMA in Japan
- Stage 3 clutch
- Lightweight Flywheel
- Z1motorsports chrome bolt engine dress up kit
Suspension/Brakes:
- New Nissan Brake Pads
- Slotted Rotors
- New Rotors
- Steel Braided Brake Lines
- Sitting On Tein Flex adjustable Coilovers
Exterior:
- VeilSide CI Rear Bumper 2+2
- VeilSide CI Rear wing spoiler 2+2
- VeilSide CI Side skirts 2+2
- VeilSide CI Half Bumper 2+2
- Veilside CI Front bumper 2+2
- VeilSide Andrew Evolution V Rims
- VeilSide Evolution Lightweight hood 2+2
- VeilSide Evolution Rear Badge
- VeilSide Combat 300zx Evolution Decals (One on each door & 1 going down the hood)
- OEM Smoked front bumper signal lights
- Rear Hatch Tint
- Custom Gold Paint Job
- Foglights deleted and replaced with Powertrix carbon fiber air ducts
Interior:
- Black Nismo Shift Knob
- HKS Type 1 Turbo Timer
- APEXI AVC-R Boost Controller
- Kenwood Deck
- JL Audio 10" Sub /w Custom Sub Box
- XD300/1 JL Audio Amp
- Basswork BSAK4 Silver Series 4 Gauge Amplifier Installation Kit
- MOMO "Team" Steering Wheel
- Sparco racing Alcantara Seats
- Sparco Seat base's 400 series
- Sparco Side Mounts
- Custom 320km/h VeilSide co. Speedo Gauge (Rare)
- Custom Tan Leather Interior
- Custom Tan Cloth/Suede Interior
Thats basically the whole layout of my 300zx. The car was sitting at VeilSides original shop and this 300zx IS the original VeilSide promotional car used to advertise the 300zx Body kit that my car has on right now, many people like it many people don't, I chose to keep the kit as is as it is rare and a piece of Z32 history. The car has no problems at all. Here is a list of mods I am going to do and things I am buying this winter and going to install next summer:
- 6 point Sparco harness
- 4 point Sparco harness
- Sparco harness bar
- A/M gauges: Air/Fuel, boost, volts, water temp, oil pressure, exhaust temp
- A better deck, most likely a flip out touch screen
- ConceptZperformance test pipes and downpipes
- Going to be removing the single exit bordermax exhaust and installing dual HKS Super Dragger II exhaust, so Il be changing the exhaust back to true dual.
- Sand blasting the rims/restoring them
- Bigger brakes
- 550cc injectors or 740cc injectors
- Paint touch up,
- Restore sparco seat leather
This is a quick list of what I'm doing, most likely going to have a lot more but this is a good start. I highly doubt I will be doing turbos or anything bigger than full bolt ons. I may be even missing a couple things out of my current mod list.
Here are some pictures (They are a little old, Il have to update them a little later.)
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Trickygreek is offline   Reply With Quote
300zx, turbo, veilside, vg30dett, z32
