04-01-2012, 09:14 PM | #61 |
I did this today, running gate off turbo housing. will wait to weld flange when its all in car so i know what angle to put on etc
05-20-2013, 12:23 PM | #64 |
Bringing this back from dead, because I'm getting interested in doing it. Trying too decide if its worth it to extrude hone it as well, while running a stock s14 t28?
That's a ton of cash right now, and I'm not sure it would be worth it. Also, what us the short most reliable wastegate everyone if buying these days?
-Kyle |
08-31-2013, 09:52 PM | #65 |
Where can I buy a brand new factory exhaust manifold? I have the tomei and It may be cracked. I like your setup alot, almost convinced on the gtx.
I'm sick of my internal wastegate. Shits weak. |
09-01-2013, 01:39 AM | #66 | |
Trader Rating: (26)
Feedback Score: 26 reviews
And extrude honing a stock manifold honestly is not worth it. You won't gain much response for the outrageous $500 price. You're better off honing your intake manifold for smoother air flow into your head. External wastegate is the bomb. Had this setup on my 2871 bottom mount setup. Shits on internal gates all day long.
IG/TikTok-ThatS14_Z06guy |
09-01-2013, 06:48 AM | #67 |
Would this setup fit a rhd setup with abs? I wonder if the external wastegate would conflict with the abs pump.
Thanks, -Dave Sent from my SGH-T889 using Tapatalk 2 |
09-01-2013, 10:07 AM | #68 | |
09-01-2013, 10:45 AM | #69 |
Sure it seems expensive, but it is *the best* setup for the bottom mount GT and GTX turbos. The tubular manifolds are not built well enough (outside of a doc race maybe) to withstand the rigors of being in that spot. They really need better support structure to keep from cracking.
I went with the external for that reason as well. It ended up being cheaper than the tubular manifold, and hasn't given me an issue in years of abuse on track and street. |
09-01-2013, 10:53 AM | #70 |
this is definitely great setup but to make the best of it
what turbo elbow will be best to use with welded flapper? Is this bigmouth style, no divider with 3" pipe still good or is this smaller pipe actually better after cutting off and closing that screamer tube Last edited by cured13; 09-02-2013 at 01:04 PM.. |
09-02-2013, 08:05 AM | #72 |
Welded screamer pipes are extremely loud, for those of you who might not know.
If you want your car to yell, "LOOK AT ME" and be super loud every time you floor it, go for it.
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal |
09-02-2013, 08:08 AM | #73 | |
I do have a greddy elbow I could slap on the car or sell if anyone wants it |
09-02-2013, 11:16 AM | #75 |
Trader Rating: (26)
Vband is the way to go. My entire exhaust is V Band from the turbine out. Minus the T3 flange. That's a very annoying place for a vband.
09-04-2013, 04:44 PM | #76 |
got any pics of your setup? how are you liking the GTX? ive got the gt2860rs and thinking of upgrading to the new gtx wheel for faster spool. when do you hit full boost?
09-04-2013, 06:50 PM | #77 |
Trader Rating: (26)
I'm actually on a GTX3076 .82. With no timing thrown at it I'm seeing 20psi at 4200.
I used to have this set up though on my 2871. That wasn't V Banded. Pain in my ass those 5 bolt turbo flanges were. Especially with the PBM flex cobra DP. That set up saw 1 bar at 3400, same timing as my current set up. Waiting to go E85 before we start advancing timing. Should bring spool down a few hundred rpm.
09-05-2013, 10:26 AM | #78 |
Right on sounds good! Thanks for the info! I'm curious to see what the 3076 puts down.
I use my car for mainly drifting and canyon so the quick spool is really nice. I'd like to be spooling around 3000-3200, if possible. I read a guy with a precision hitting like 30psi at 3200 or some shit. |
06-08-2015, 02:24 PM | #80 |
On a setup like this, it should not matter where the wastegate outlet dumps back into the exhaust, correct? As far as AFR goes that is.. I want to plumb mine back in at my downpipe, but I put an aftermarket wideband detector there and want to know if I should put it downstream of that (or if it matters at all). Thanks.
BC
* S14SR22 * 9.0 c/r * GT3071R * |
01-23-2018, 10:18 AM | #87 |
He still does them guys. For some reason Cody isn't able to post in this thread. Just PM him or maybe try to contact through Facebook.
