12-03-2012, 06:10 PM | #1 |
Ka24e or ka24de swap
Just like the title says, wanna buy a full swap, harness, engine, 5 speed trans, and all the sensors etc. let me know what you got and i wanna do local so cal pickup unless you can manage a good shipping price.
12-04-2012, 08:53 AM | #4 |
12-04-2012, 08:54 AM | #5 |
12-05-2012, 04:15 PM | #7 |
here is my description on my ka
Engine specs - unknown mileage but since i owned the car i put 18,xxx miles -oil change with 10w40 semi synthetic high milage oil every three months -headgasket done by previous owner -oil pan gasket done by previous owner -new radiator and hoses -new thermostat -new starter -new oil pump -new water pump -new timing chain -new fan clutch -new coolant temp sender sensor -replaced the maf and iac sensor -new starter -new radiator cap -new spark plugs, wires, and distributer cap -new o2 sensor -gutted cat with megan racing m-oe exhaust Tranny -oem excedy clutch -2nd gear synchro grinds when down shifting at high rpms -rest of the gears shift like butter engine does not leak will include harnesses and ecu only problem is that the engine is still in the car, i do not have the tools or equipent to pull out the tranny or engine. if you want to buy the ka setup, u will have to figure out a way to transport the engine, and to bring your own equipment to pull it out
