Old 08-17-2015, 12:02 PM   #1
itsjustdaphne
itsjustdaphne's Avatar
itsjustdaphne is a well-known jackass
KAAZ 2-Way & (3) S15 SR20 Coilpacks
One of my S15 SR20 Coilpacks melted, so I upgraded all of 4. I have these 3 if anyone needs them. $: Make an offer.
KAAZ 2-Way Diff in S15 housing. 6 bolt axle stubs. It locks hard, works flawless, will include 1 bottle of Ford Friction Modifier with purchase. I change the fluid every month. $: 800 OBO.
Purchase will NOT include the front PBM bushings, they are just in the picture.
@ddaapphh | @spectuned
itsjustdaphne is offline   Reply With Quote
Old 08-18-2015, 06:32 PM   #2
itsjustdaphne
bumppppppppppp
Old 08-20-2015, 10:26 PM   #3
itsjustdaphne
No one?
msglngth
Old 08-22-2015, 02:15 PM   #4
180sxs13
180sxs13 is an unknown quantity at this point
Do you know the milage for the lsd ?
Was is installed professionally?
Sent from my SM-G928C using Tapatalk
180sxs13 is offline   Reply With Quote
Old 08-22-2015, 02:26 PM   #5
Def
FYI, thats a Cusco RS lsd. It is a 1 way/2 way setup (can be used as either).
Great LSD, I love mine.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 08-22-2015, 09:22 PM   #6
itsjustdaphne
Previous owner told me it was a Kaaz so I went with that because of the setup. I'll do more research though. Thanks
Old 08-23-2015, 07:52 AM   #7
Def
I'm 100% sure it's a Cusco RS. The springs visible between the two halves and the 3 lines away from the ring gear give it away (and the empty cam slot that's 1 way).
It's a more expensive diff than a KAAZ, and much more tuneable.
DEFSPORT
Old 08-23-2015, 08:43 AM   #8
itsjustdaphne
Thanks for the information, I'm convinced it's a Cusco as well. Pretty cool. How can it be used as a one way instead though?
Old 08-23-2015, 10:18 AM   #9
Def
You take apart the diff, and put the cam/cross on the 1 way ramps (what you pictured there - notice there is no cam/cross in it).
The good thing about a Cusco RS is the coil springs keep the preload very consistent with wear vs. a cone spring like a KAAZ, Tomei, Nismo etc. use.
DEFSPORT
Old 09-04-2015, 09:54 AM   #10
itsjustdaphne
Diff is solddd
