Old 06-10-2016, 09:35 AM   #811
adey
adey's Avatar
adey is an unknown quantity at this point
Am looking to do some replacements and polishing on some of my wheels.
Anyone know what kind of tool/wrench/socket is used to take the wheel apart? Specifically for:
1) Advan SA3:
2) SSR Agle Minerva:
front-
rear-
(I think same as current SSRs:
Thanks!!
adey is offline   Reply With Quote
Old 06-10-2016, 10:05 AM   #812
adey
adey's Avatar
Originally Posted by red240 View Post
Still looking for Volk lips for my GTCs
I just bought a pair of GT-Cs and was told by VR Wheels that they can't be turned into 3-pieces, since the bolts are too far apart... which would cause the rims to leak air from the seam, between the bolts.
Not sure if silicone/sealant alone would be enough to prevent air leakage, but I imagine welding would.
Interested to hear/see if anyone has done this - they say they have, but have yet to see pics or details on how it was done!
Old 06-10-2016, 10:31 AM   #813
theStig880
theStig880's Avatar
theStig880 is on a distinguished road
1) Advan SA3:
Thanks!!
I've never done any Advans but they look similar to Works hardware which I've always just used a multipoint box end wrench on the outer bolts and just a socket on the inside. No special tools needed.
The Minerva's are a female triple square. You can use a Torx bit to loosen them if you are careful. Torx's are much easier to find but not an exact fit.
Follow me on Instagram or don't @cason880
theStig880 is offline   Reply With Quote
Old 06-10-2016, 10:41 AM   #814
adey
adey's Avatar
You're a saint.
Do you know the size of the internal (female) triple squares on the minervas?
From what I've read, it looks like work wheels use a male 8mm (or 5/16) triple square - can anyone confirm that's the same size for the rear of the minervas and the front of the Advans?
Thanks!!
Edit: also, will spline drive sockets work on male triple square hex bolts?
My understanding is that the spline drive has 60 degree angles on each of the 12 teeth compared to the XZN/triple square's 90 degree angles, also on 12 teeth.
Old 06-10-2016, 06:36 PM   #815
theStig880
theStig880's Avatar
VrWheels is typically pretty knowledgeable and I'd put a lot of weight behind their opinion. That said, I'd still ask some other company's their opinion because I have definitely seen relipped GTC's. Silicone should keep them sealed if done correctly but if you're really scared it wouldnt be impossible to have them rewelded and siliconed on top (although I think thats overkill).
You're a saint.
Thanks!!
I havent worked on Minvera's so I dont know offhand but I'm fairly confident they are 8mm internal threads but the bolt itself is an m7x24.5. Its the more standard triple square wheel bolt size but is a weird bolt otherwise.
Also, a spline drive should work fine but I've alway used torx or an actual triple square bit for those bolts. They're relatively low torque so as long as they arent rusted and close fit, they wont strip the bolts.
Old 06-11-2016, 07:06 PM   #816
red240
red240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the rough
My rears are 3 piece from the factory according to Volk when I ordered them, they are 18x11 +19 now,the fronts are 2 piece, 17x9 +20 I need both of them re lipped
Just looked at them and the rears are 3 piece for sure, fronts are not
red240 is offline   Reply With Quote
Old 06-12-2016, 05:49 AM   #817
adey
adey's Avatar
Very interesting. Could you share some pics of your rear GTCs? I have GT-Ps as well, and in 18*10+12 they are also one-piece. (Will take a look again when I take the tires off)
Also, let us know how the re-lipping goes, especially for the two piece GTC.
Old 06-14-2016, 05:29 AM   #818
red240
I'll get some pic's and post them, haven't found anyone who has lips to fit this bolt pattern yet though
Old 06-15-2016, 11:11 AM   #819
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
Is there a WheelFlip rep here on Zilvia? I've tried calling multiple times and sent an email a couple weeks ago, and I still haven't heard from them.
I'd like to buy new BBS RS lips, 4" measured to the bead seat, 4.5" measured to the outer lip edge. Generally this would be considered a 4" lip, IIRC. Their site lists various lip sizes up to 6.5", but it doesn't explicitly state how the lip dimensions are measured.
I just want to confirm with them which lip size I should order before I poop money away.
Picture because everyone likes pictures
jaysgottaredtop is offline   Reply With Quote
Old 06-15-2016, 11:22 AM   #820
theStig880
theStig880's Avatar
All lips regardless of manufacturer should measure from the flat edge that mounts to the face to the edge of where the bead of the tire seals. There should be a half inch seam that extends past the measured part that holds the bead on. Basically a 4" lip would be about 4.5" total width but only 4" more of tire mountable area.
Wheelflip is also notoriously hard to get ahold of. Vrwheels stocks 4" BBs lips and three piece should get any size. I think memory fab also sells BBS but I'm not sure.
Old 06-15-2016, 11:43 AM   #821
jaysgottaredtop
^ Right. That's how I've always measured lips, and that's how I ordered some other lips/barrels from VR Wheels.
But WheelFlip doesn't explicitly confirm that on their site, and I'm hesitant to spend hundreds without both parties being on the same page.
Main reason I'm specifically asking about WheelFlip here is because 16x4" BBS lips from WF are $180 each versus $200 each from VR. Any VR rep here wanting to price match? lol
Old 06-16-2016, 06:41 PM   #822
Lil_D
Lil_D is an unknown quantity at this point
i just finished sealing my blitz. got the lips and barrels from wheel flip
@lild415
Lil_D is offline   Reply With Quote
Old 06-17-2016, 12:58 PM   #823
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Nice bro! What size are those b03's?
https://instagram.com/e_lemonation/: @e_lemonation
Old 06-17-2016, 03:07 PM   #824
Lil_D
18x11 -12ish.
@lild415
Old 06-17-2016, 03:16 PM   #825
Mister.E
Mister.E's Avatar
Trader Rating: (53)
6" lips then?
Old 06-17-2016, 04:49 PM   #826
Lil_D
6" lips then?
7 inch lips and 4 inch inner barrels
@lild415
Old 06-17-2016, 08:55 PM   #827
jaysgottaredtop
7 and 4... Wouldn't that put you into the -30s if not deeper?
Looks sweeeeeeet either way.
Old 06-17-2016, 08:57 PM   #828
DomChan
DomChan is making a name for him/her selfDomChan is making a name for him/her self
Dependent on disk type... but yeah 11J -12 sounds conservative for those lip sizes! Lookin' good Derek
VS-KF
18x10 -7
18x11.5 -12
Courtesy of @chamorroboy86 (Instagram app username). 5" and 6.5" outer lips respectively.
DomChan is offline   Reply With Quote
Old 06-17-2016, 09:38 PM   #829
Mister.E
Mister.E's Avatar
Trader Rating: (53)
It's the way that the faces are designed on the blitz wheels.
Old 06-18-2016, 07:54 AM   #830
Tearlessj
Tearlessj's Avatar
I think i've read it somewhere but wanted to make sure. Does the SSR vienna courage use a standard 40 hole lip? Here's a photo I found of the back of the face.
Nagasaki Motors
Tearlessj is offline   Reply With Quote
Old 06-19-2016, 10:19 AM   #831
red240
So here are the GTC pic's, Front and Rear, You can see that the rear is three piece, not sure if they are welded, I ordered these new 12 years ago, but now that I widened the body more I have spacers, might just sell these and get something else if I can't widen them
Rear
Front
Old 06-19-2016, 11:09 AM   #832
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
SSR uses a slighly smaller bore size than standard and Work on there 40 hole lips
Sumslapper is offline   Reply With Quote
Old 06-19-2016, 08:44 PM   #833
Mister.E
Mister.E's Avatar
Trader Rating: (53)
SSR is M7, Work is M8. We wanted to get gold hardware for my friend's SP1's and the holes had to be bored out because they didn't have M7 hardware in gold.
Old 06-19-2016, 10:48 PM   #834
Sumslapper
Sumslapper's Avatar
I was talking about the center bore of the lip where the face drops in, not the bolt size. Standard lips are wider so there will be play between the face and lip. Work wheels is slightly bigger than SSR, but smaller than standard. Yes, SSR uses smaller hardware on some sets using M6 and M7 hardware. Work uses M7.
Old 06-20-2016, 08:06 AM   #835
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Oh ok, that's what you are trying to say. Same thing happened with my Blitz 03's. I wanted to use the lips from my VS-XX's to rebuild them but it was a no go.
Old 06-20-2016, 10:39 AM   #836
xhjhj
xhjhj is an unknown quantity at this point
here comes a completely useless post but there is a picture of a BWM z3 with the stock rear wheel widened and that was dope as hell and i feel like it had the info about him getting the wheels widened as i think they are 1 piece
xhjhj is offline   Reply With Quote
Old 06-26-2016, 09:36 PM   #837
OMFGeofffff
OMFGeofffff's Avatar
OMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really nice
Not sure if this is the appropriate thread for this. Does this look repairable? Debating if I should try fixing it or just relipping them.
OMFGeofffff is offline   Reply With Quote
Old 06-27-2016, 07:19 AM   #838
jsu1012
jsu1012's Avatar
jsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to behold
SSR Minerva's
SL disc 18x9 +37
rechromed faces, new barrels, new lips. 24kt gold hardware. I also scored a mint set of minerva center caps from someone off here.
18x9.5, -12 | 5 inch lips
18x11, -5 | 6 inch lips
@streetstyle_jay
jsu1012 is offline   Reply With Quote
Old 06-27-2016, 08:04 PM   #839
Stiveno
Stiveno's Avatar
Stiveno is on a distinguished road
Is it bent? if you are just talking about the rash yes you should be able to sand and polish that out but it probably isnt going to look good as new. Not sure about bends but ive seen some pretty fucked wheels been refinished to look new.
Here's a pair of weds I polished refinished, If you don't have equipment and value your time you might be better off just buying a new lip.
Stiveno is offline   Reply With Quote
Old 07-25-2016, 03:50 PM   #840
TheBlackHand
TheBlackHand's Avatar
TheBlackHand is an unknown quantity at this point
Tearlessj.....SSR Vienna Courage uses a 39 hole lip and inner barrel with M6 hardware. I'm currently rebuilding a set and just ordered 6'' lips from threepiece. Here's a pic of the barrel.
TheBlackHand is offline   Reply With Quote
