Old 04-25-2009, 07:28 AM   #331
eh?
eh? is an unknown quantity at this point
Originally Posted by ProjNightshade View Post
thanks, but I need 100% certainty before I start workin on this. anyone else have anything?
RB25 VSS will work with s14 speedo.
eh? is offline   Reply With Quote
Old 04-25-2009, 05:34 PM   #332
8gti9
8gti9's Avatar
8gti9 is an unknown quantity at this point
is the rb25det s1 same as the rb25det s2 wiring into a '91 s13?
8gti9 is offline   Reply With Quote
Old 04-26-2009, 04:30 PM   #333
ProjNightshade
ProjNightshade will become famous soon enoughProjNightshade will become famous soon enoughProjNightshade will become famous soon enoughProjNightshade will become famous soon enough
thanks for the help. now what about the tach? haha.
Originally Posted by iwishiwas-all* View Post
Unfortunately for you, this is not Darwin vs Christ.
ProjNightshade is offline   Reply With Quote
Old 04-27-2009, 05:23 PM   #334
eh?
There is a screw behind the tach that will adjust the RPM reading. You will need another reference for actual RPM though.
Old 04-27-2009, 09:52 PM   #335
ProjNightshade
ok cool. thanks!
Old 04-29-2009, 12:01 AM   #336
dtowngoalie
dtowngoalie is an unknown quantity at this point
Anybody know the difference between a cefiro rb20det and a skyline rb20det
dtowngoalie is offline   Reply With Quote
Old 04-30-2009, 02:42 PM   #337
soon2bs13
soon2bs13's Avatar
soon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-known
Send a message via AIM to soon2bs13
Nissan Cefiro - Wikipedia, the free encyclopedia
neg repping is cool!!
soon2bs13 is offline   Reply With Quote
Old 05-25-2009, 05:56 PM   #338
skyvia25
skyvia25's Avatar
skyvia25 is an unknown quantity at this point
any one knows how to install the water tube into a gredy style intake manifold. my came seperated and it looks like its brass or copper. i took it to get it welded but the guy said he could n do it, i heard that u could just push it in with a rubber mallet, but min is to loose and it just goes in any ideas tnx..
skyvia25 is offline   Reply With Quote
Old 06-03-2009, 12:08 PM   #339
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
coat it with a bunch of red high temp sealant and push it in, or go to your local home depot and get a peiece of tube that fits better and also coat it with sealant to prevent leaks
ANVIL is offline   Reply With Quote
Old 06-15-2009, 01:52 PM   #340
Skyn
Skyn's Avatar
Skyn is an unknown quantity at this point
im putting an rb20 in an S14
any suggestions on what i can pick off my Ka stuff and use with RB
and also which trans can go on it besides an rb one and suggestions on mounts or is this gonna be almost direct
Skyn is offline   Reply With Quote
Old 06-17-2009, 12:40 PM   #341
eh?
I'm pretty sure people have been using the stock KA xmember with RB mounts and you can use the stock driveshaft. You can use the KA radiator also. Only the RB bell housing will work so you can't use another tranny (unless you swapped the bell housing)
Old 06-29-2009, 05:46 PM   #342
soon2bs13
soon2bs13's Avatar
okay guys... my 240sx project is nearly completed. the major thing left to do is get it painted and figure out the wiring for the tach/speedometer.
anyone have a link that will help explain how to wire up the transmission to get the speedo/tach working? Am I just going to have to get an aftermarket Tach? I tried searching, but could not find what I was looking for. Maybe someone who has seen a thread before can point me in the right direction.
thanks!
Old 06-30-2009, 05:57 PM   #343
maztamekanik
maztamekanik is an unknown quantity at this point
1990 rb26dett turbos
i need to no what kind of turbos my motor has if anyone can help id appreciate that
maztamekanik is offline   Reply With Quote
Old 07-01-2009, 10:29 AM   #344
bardabe
bardabe's Avatar
post pictures
Review Thread
bardabe is offline   Reply With Quote
Old 07-03-2009, 12:29 AM   #345
soon2bs13
soon2bs13's Avatar
thanks!
? anyone ?
Old 07-08-2009, 12:52 PM   #346
eh?
? anyone ?
See "lower harness prep"
RBforums - wiring
For the dash
LS Automotive - LS Products
Old 08-22-2009, 02:08 PM   #347
myrbsrgig
myrbsrgig is an unknown quantity at this point
Originally Posted by drift freaq View Post
well, my info is not false for a RB25 install. You did a 26 there are some differences in the installs. Since you feel your info is so ass kicking and superior share it. Instead of playing P.M. me in private, and playing it like your so superior.Almost sounds like a exercise in your ego. I am not saying it is but it comes off that way. If not I apologize in advance.
oh ya and for everyone. These installs have a number of ways to be done, depending on if you utilize a R33 GTST crossmember with the stock RB engine brackets, (which is what we do) or not.
We choose this particulare method because it allowed us with our Custom Urethane mounts to move the engine as far back and as low as possible in the S13 chassis.
Yes we did custom power steering lines,it works kick ass too!! I am in the process of finishing up my air, using a RB25 R33 air con compressor and fittings. All we had to do is have the lines extended to my stock lines coming from the firewall.
The only reason I say what I say is because compared to whats on the market our setup is cleaner and looks much more factory.
Ours will be a product not someones back yard job.
my question to u is is it possible to have a rb26 6-speed tranny with the awd in a 93 240...if it is what steps do i need to take in making that happen
myrbsrgig is offline   Reply With Quote
Old 09-06-2009, 12:12 AM   #348
bardabe
bardabe's Avatar
^^^ obviously if you have to ask its something you can't do so either you need lots of $$$ or lots of $$$. intense amount of fab work, and the getrag 6 speed alone will run more than 5K
Review Thread
Old 09-08-2009, 08:05 AM   #349
jacob74
jacob74 is an unknown quantity at this point
Making it AWD will cost lotssss and lots of $$. Just put a rb25 tranny on there. if you reaallly want a 6 speed, thenn..... well, fuck it. what do you need a 6 speed for? 45mph 6th gear pulls?
jacob74 is offline   Reply With Quote
Old 10-06-2009, 11:25 PM   #350
951's 330i
951's 330i is an unknown quantity at this point
Quick, and probably stupid question, but theres no way to fit the downpipe from a company like hks onto our rb's in the s14 chasis right?
951's 330i is offline   Reply With Quote
Old 10-07-2009, 01:18 AM   #351
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
nope . there are no downpipes that would fit straight from factory .
best thing to do is buy a downpipe , cut the flange where it connects to the o2 housing. the rotate the flange you cut a few degrees, then bolt it up to the o2 housing , mark it , the take it off and weld it together.
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 10-07-2009, 12:22 PM   #352
951's 330i
Thanks, i thought so. Anyone have experience with the syko performance elbow that they sell that i guess u can use any sr downpipe with?
Old 10-07-2009, 04:36 PM   #353
eklips3
eklips3's Avatar
syko performance downpipe is o2 housing plus downpipe combo so you dont have to cut, clock and reweld.
if you are just buying an SR downpipe then it goes back to you having to do a little custom work.
Old 10-08-2009, 02:02 AM   #354
951's 330i
Ok thanks
Now i have a other question on a turbo timer i just bought. Which harness do i need to get? Its a hks TT but im not sure on which harness? Do i get the one that says silvia for the sr? Or the one that is meant for the skyline i think? Thanks
Old 10-08-2009, 02:40 AM   #355
GSXRJJordan
GSXRJJordan's Avatar
Ok thanks
Turbo timer should match the car, not the engine. It installs in the ignition harness.
Old 10-08-2009, 03:09 AM   #356
951's 330i
Oh ok i see. So then i would need the one that says silvia s14 on their site right? This one
4103-RN001NISSAN Silvia S14 1993-1998 Turbo ; JDM Specific SR20DET Chassis
Old 10-08-2009, 01:15 PM   #357
Yum-Yum
Yum-Yum's Avatar
Yum-Yum is an unknown quantity at this point
? anyone ?
j30 tach works flawless.
Yum-Yum is offline   Reply With Quote
Old 10-09-2009, 02:05 PM   #358
951's 330i
Ok already made a thread about this. But after installing my turbo timer, the car wouldnt start. Electrics work but no start. Took the turbo timer off(harness) reconnected the starter how it should be and then the car starts again? What could be the problem with? On the starter there are six connections in the plug but on the harness there are only five connections for it. Im really stumped on this one.
Old 10-09-2009, 06:05 PM   #359
johngriff
johngriff's Avatar
Check this out.
Now that the PFC for the RB is discontinued, Haltech has released a direct replacement ecu for the R32/R33 Engines / Cars. You can use the OEM MAF(S) or upgrade to MAP with this ecu, its really your choice.
Here is a link to haltech's site about it:
Platinum Pro R32 / R33 Plug-in - Haltech Engine Management Systems
MSRP Is about $1680
[email protected]
Old 10-14-2009, 11:21 PM   #360
951's 330i
Whats a good, almost direct turbo? See that some people say there are turbos that are direct bolt ons but then right after say will need some fitment issues resolved? I see most people using the HKS GT2530 turbo.
Is this a straight bolt on with this turbo? Is the lag really bad? Or should i look for another turbo instead?
Thanks all
