03-14-2018, 09:43 AM | #1 |
Diff removal
Ok so this is a noob mistake. I removed the subframe without disconnecting diff/axles/driveshaft or 5 lug hubs. I figured it would be easier if the subframe was on the ground. The problem is diff is spinning now since there is no ebrake applied. How can I remove the axles/diff/drive shaft/5 lug hub? Any way to make the diff not spin?
03-14-2018, 10:00 AM | #3 |
Put two nuts with bolts on the driveshaft flange of the diff and have a buddy hold a pry bar between them to stop spinning while you loosen everything.
