08-05-2018, 09:05 AM | #1 |
S13 diff to s14 issues
Idk if I posted already Tapatalk is hard to navigate?? But I swapped an lsd out off an s13 into my s14 and since then while leaving first slowly making a hard turn I get a gnarly binding noise/feeling. It only happens leaving first on a nearly full lock turn it feels like something is gonna rip off the car. Normal driving at speeds is unaffected. The car is all stock besides some unknown shocks and springs sitting at stock height. Any help is much appreciated.
Sent from my iPhone using Tapatalk |
09-04-2018, 07:33 PM | #2 |
i currently have a 180sx diff in my s14 zenki , which hardware are you using? i know you can get away using the S14 diff bolts with some washers but you need to make sure the diff is ligned up correctly. I did thjis for a few years with no issues. Recently i purchased oem s1`3 hardware to bolt the diff back to the subframe. also check your axels
09-04-2018, 09:23 PM | #3 |
Were both diffs either abs or non-abs? Drive shaft length matters if you used a non ABS driveshaft with an ABS diff it might be a bit screwy due to length differences for example. If you did the opposite I think the DS would be too short
