Old 07-01-2015, 07:06 PM   #1
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Nissan R200 Final Drive Ring & Pinion Gear Set 3.692 (48:13) Ratio
Nissan Infiniti 240SX 180SX SILVIA SKYLINE 300ZX Q45 R200 Final Drive Ring & Pinion Gear Set 3.692 (48:13) Ratio.
If upgrading from a stock 4.083 ring gear from a 240sx this gear set will give you a higher top speed. Ideal for cars putting down more power that would like to cruise on the highway at lower RPM. This is the same final drive gear ratio as an S15 Nissan Silvia Spec-R.
Comes with LH and RH shims and ring gear bolts.
$240 shipped.
If you have any questions or looking for another gear set ratio please let me know. PM for quickest response.
Old 07-03-2015, 01:47 AM   #2
SR20PWRALTY
SR20PWRALTY is an unknown quantity at this point
What will be needed to put in J30 diff?
SR20PWRALTY is offline   Reply With Quote
Old 07-03-2015, 06:06 AM   #3
KiLLeR2001
Trader Rating: (46)
You will need to swap the pinion washers, spacer, and bearings off of the J30 pinion gear onto this one. Once that is done you press it into the pumpkin. Once ring gear is installed onto a diff, use the shims to position it onto the pinion gear. Always be sure to verify backlash.
Old 07-03-2015, 11:39 AM   #4
KiLLeR2001
Trader Rating: (46)
This has been sold!
