12-06-2017, 09:45 PM | #1 |
trans crossmember question..
whats up everyone ! Just picked up a 1995 240 with a 2000 model year sr20 blacktop / 6 speed swap! Love the car and seems to have been put together very well... i did notice something that will bug me and have not found the answer searching around yet... I am guessing they used the original 5 speed cross member since only 2 of the 4 mounting bolts are being used.. The back half of the mount is basically hanging there in mid air... This swap has been completed for a very long time (14 years to be exact) and guessing never posed an issue... But i would like to know what factory or aftermarket cross member is the correct one to use? thanks everyone !
12-07-2017, 12:00 PM | #3 | |
Car is right at 285 whp, engine /trans only have 10k on them and the trans is perfect .. Do not plan on higher hp levels or drag racing the car so I would hope it would hold up for a bit... Anyone else? |
12-07-2017, 07:19 PM | #4 |
12-07-2017, 07:29 PM | #5 | |
thank u! will take a look |
12-07-2017, 08:19 PM | #6 | |
GM2 (SW/AW)
So to shed some actual light here, one of the first 10 S13's I bought had this situation.
But 1 of the bolts on each side wouldn't line up. I drove that car daily for nearly 10 years with 2 tranny mount bolts only. It was a 420HP KA-t. I've also acquired shells with giant bolts mounted into the cabin because the tranny mount holes shifted.
KA-T for life! Current for sale advertisement |
12-07-2017, 09:07 PM | #7 | |
So would you recommend finding the proper crossmember or leave it alone? |
12-11-2017, 01:26 PM | #8 | ||
GM2 (SW/AW)
From a safety standpoint? Yes. Can you imagine the devastation of your transmission dropping on the interstate? Every time you enter a gear you're shifting stress onto a different set of teeth. If you miss those teeth you're adding instant acute stress which causes jerking etc. Did I drive with only 2 bolts in mine for a long time, ripping gears? yes. Would I recommend it? Obviously no. The risk to the car and your life is too great. The auto cross member if I recall correctly, would only allow 2 bolts on either side to be mounted. From what he's describing, both front bolts are mounted.
12-11-2017, 05:47 PM | #9 |
12-11-2017, 05:51 PM | #10 | |
12-14-2017, 07:27 PM | #15 | |
C's made one, but are pretty rare. I've been eyeballing these from Australia on eBay, but never looked into actual feedback https://www.ebay.com/itm/CUBE-Speed-...NaCj8t&vxp=mtr |
