Old 12-31-2017, 01:58 PM   #1
NathanBerge
NathanBerge is an unknown quantity at this point
sr20det Fuel issue
Hi i have searched every fourm for the answer to this question and found some help but nothing solved it. i just swapped a sr20 into my s13 and am running into a issue with injectors firing. i have constant 12v going to the injectors and if i pull the cas out and manually spin it the injectors will fire perfectly. but after re installing the cas correctly and go to turn over the car the injectors will not fire. any ideas?
NathanBerge is offline   Reply With Quote
