Old 01-26-2015, 07:31 PM   #5731
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Originally Posted by skateny115 View Post
Stainless transfers heat faster than 30 percent faster than mild so heat affected zone would be worse on stainless if you linger. There is a alot of good info about travel speed
Yea when I did the stainless my travel speed was pretty fast and I was pulse like 33ppm so the heat affected zone was narrower, honestly I have no more then tops 30 hours on my machine if that, I'm still learning torch angel and getting familiar with what the puddle is doing but its fun I see myself getting better with my time, in the beginning I was frustrated just trying to get the coordination and get steady but its getting easier with time.
Old 01-26-2015, 07:32 PM   #5732
skateny115
skateny115 is an unknown quantity at this point
I love tig have been in since i have started keep up the good work
skateny115 is offline   Reply With Quote
Old 01-26-2015, 07:38 PM   #5733
Sforteen
Sforteen is an unknown quantity at this point
I weld stainless as little as possible, i don't like working with it. Sucks to cut, expensive and needs to be back purged. My exhaust is made out of 4inch aluminum.
Sforteen is offline   Reply With Quote
Old 01-26-2015, 07:41 PM   #5734
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
That's cool I like it to I just wanna get good enough to make pretty welds like I see throughout this thread, this is an awesome thread to by the way!
These were my very very first welds I did on my machine
Old 01-27-2015, 06:57 PM   #5735
McRussellPants
Super hot and you need to back purge
pls waste money back purging mild intercooler piping.
looks like your torch hand is shakey or your holding it too far away. get a thick glove and choke up on the torch to keep the electrode closer.
@mcrussellpants
McRussellPants is offline   Reply With Quote
Old 01-27-2015, 07:16 PM   #5736
zenki 95
zenki 95's Avatar
zenki 95 is an unknown quantity at this point
What tungstens do you guys prefer. I seem to like the e3 purple rod for aluminum. Seems its a good well rounder and can be used for alot of material. I just cant seem to dial in my stainless with red or purple tungsten. Its probably because my argon was set too high at that time. Will run some beads tomorrow and see what happens.
zenki time! "Cant buy weed and pussy with disney dollars"
zenki 95 is offline   Reply With Quote
Old 01-27-2015, 08:39 PM   #5737
ka-titties
ka-titties is an unknown quantity at this point
i use grey on everything
ka-titties is offline   Reply With Quote
Old 01-27-2015, 08:45 PM   #5738
McRussellPants
Tungsten doesn't seem to make a huge difference on inverter machines. I use anything but green no problem.
Old 02-01-2015, 01:44 PM   #5739
fearlessKouki
fearlessKouki is an unknown quantity at this point
Just picked up Hobart auto arc 130, hoping to learn welding and do some restoring on my s14. Would it good idea to mig weld the exhaust?
fearlessKouki is offline   Reply With Quote
Old 03-03-2015, 11:04 PM   #5740
jimchipperfield
jimchipperfield is an unknown quantity at this point
Originally Posted by UNISA JECS View Post
autopartswarehouse
Great job mate we all get better for the sake of being car enthusiasts. keep it up
jimchipperfield is offline   Reply With Quote
Old 03-04-2015, 09:05 AM   #5741
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
This is a repair I did on my exhaust system to eliminate an exhaust clamp that shouldn't have been there (but that's another story) and this is stainless steel and the other 2 pipes are GTi-R compressor outlet pipes made of mild steel
Old 03-30-2015, 11:59 PM   #5742
McRussellPants
Old 03-31-2015, 08:22 AM   #5743
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Nice work. That fuel pump bracket is so sick.
Old 03-31-2015, 07:18 PM   #5744
TurboTiger
TurboTiger is an unknown quantity at this point
Damn, so much win in this thread. Some of the work you guys are putting out is nothing short of amazing!
TurboTiger is offline   Reply With Quote
Old 04-08-2015, 08:46 PM   #5745
mkomar24
mkomar24 has made poor choicesmkomar24 has made poor choicesmkomar24 has made poor choicesmkomar24 has made poor choicesmkomar24 has made poor choicesmkomar24 has made poor choices
Some stuff I have made recently;
Cage in an S14 with full interior put back in.
Rear radiator ducting for my 1JZ track beater;
F1000 chassis, 4130 chromoly, all TIG;
A trailer to haul all my drift toys;
mkomar24 is offline   Reply With Quote
Old 04-08-2015, 08:51 PM   #5746
mkomar24
and some more stuff;
A new table for my drillpress, machined on my endmill;
Another S13 cage;
I copied this trailer latch pin on my lathe and made a ring out of stainless filler rod;
I made an adapter for brembos to a 300zx front spindle from a billet of T6 aluminum and used helicoils in the threaded holes to accept factory bolts;
Old 04-08-2015, 08:55 PM   #5747
mkomar24
And these are my two drift toys, I decided to copy the green S13 in the back and then leave out all the crap that isnt needed. The Coyote was the result, a 1100 pound 250hp monster with zero chassis flex. That is probably my biggest single fab project to date...
Old 04-08-2015, 08:57 PM   #5748
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Is that road legal?
Old 04-08-2015, 09:01 PM   #5749
mkomar24
Simple bash bar ^
Building another Coyote with a 1JZ and 5 inches wider;
Miata with an SR20DET, had to make a custom oil pan, driveshaft, trans adapter, etc...
Turbo setup for an LS1 with exit out the fender;
Old 04-08-2015, 09:03 PM   #5750
mkomar24
Made a steering bushing for S13;
More F1000;
Old 04-09-2015, 03:33 AM   #5751
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Jeez Fabgod!!!!
Old 04-09-2015, 06:34 AM   #5752
unwtdhero
unwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-known
im sure others will want to know as well....how much does it cost for you to build a coyote? for some one....
unwtdhero is offline   Reply With Quote
Old 04-09-2015, 08:55 AM   #5753
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Yes. For someone...
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 04-09-2015, 10:26 AM   #5754
mkomar24
I build them with a 1JZ ready to run and drive for about $20k but just a frame by itself it about $7k and you bolt up all your own accessories.
Old 04-09-2015, 10:34 AM   #5755
mkomar24
https://www.youtube.com/watch?v=dkPZZ0BVynA
Old 05-11-2015, 05:17 PM   #5756
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Old 05-11-2015, 09:13 PM   #5757
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
Originally Posted by future View Post
Is that road legal?
what he said
feito is offline   Reply With Quote
Old 05-15-2015, 07:44 AM   #5758
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Some custom VQ in S13 Long Tube Headers Chris Fabbed up for his motor swap.
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 05-17-2015, 02:33 PM   #5759
turtle m3th
turtle m3th's Avatar
Trader Rating: (41)
turtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond repute
Feedback Score: 41 reviews
mkomar24 - Your coyote build was super inspirational, and I've began the programming phase of my own tube chassis build. It just makes so much sense. Keep us posted on your progress man!
"cigarettes killed my father, and raped my mother!"
turtle m3th is offline   Reply With Quote
Old 06-07-2015, 07:02 PM   #5760
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
hey where do you guys get alluminum piping for intercoolers? which type ? also for mig welding aluminum what wire do you guys recommend?
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
