12-20-2010, 09:26 PM | #1 |
bigger turbo
well guys going to get the rb25 and i was looking to upgrade the turbo soon down the road i was looking at this by another member pointed me to this holset hx35. How do you like that over the garret gt3076r or what ever turbo you are using currently
12-20-2010, 09:39 PM | #2 |
borg warner turbos have a much better responce rate over the garret line, hands down. more power and if the center cartrage goes bad, its a fraction of the cost to repair it. i would go with a s362 or precision 6262. both great turbos making much better numbers than garrets and more reliable.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE! 10.79 @ 124 MPH WITH A 1.48 60' |
12-20-2010, 10:07 PM | #3 |
Man w/ CTSV & a Car Seat
HX40 would be better, should be good enough to get you close to 600hp and not laggy at all. I've ridden in a couple cars out here with them on RB25s and they're definitely a cheap alternate to any turbos out there. Can be had from E-bay off some dodge trucks for less than $200. Rebuild kits are dirt cheap for them...
Here's my buddy's old RWD R32 with an HX40 turbo, 19cm housings... Just be careful tho, his shit was snapping stock axles at around 600hp range... |
12-20-2010, 10:09 PM | #4 |
well i getting the rb25 leave the turbo on for a bit till i save up. and how do you know that whereda40at. Is there a place that talking about them. I want to learn more before i ask question and get flamed
12-24-2010, 09:16 AM | #6 | |
Go fast shit RB25 (stock bottom end) RB25 5 speed w/OS Geiken undamppered tripple plate clutch HKS 264 in/ex cams with matching cam gears Tomei valve springs Tomei headgasket (stock 9:1 compression) ARP Headstuds RB26 oil pump RB26 individual throttle bodies and surge tank using port matched adapter to RB25 head 100mm intake piping 80mm intercooler piping (ebay special) 4'' (4 core?) intercooler (ebay special) Full exhaust with RSR catback RB26 D-jetro Power FC with boost control kit Stec top mount stainless manifold Twin Stec 50mm wastegates heavily ported Holset HX40 turbo with 19cm ex housing :headbang: Fuel Stuff 2 walbro pumps out back Aeromotive FPR Tomei fuel rail -6 stainless fuel lines and fittings Z32 fuel filter Shitty ass no name 850cc-860cc injectors (free, so yeah) |
