Old 08-19-2007, 02:44 PM   #1
BC240
BC240's Avatar
BC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enough
s14 thermostat replacement
Im about to replace my tstat, i searched and didnt find anything helpful.. Could I do this without removing my fan etc,.? I can see the housing.. what should I take off? thanks
BC240 is offline   Reply With Quote
Old 08-19-2007, 03:01 PM   #2
itsmeviet
itsmeviet is an unknown quantity at this point
Just remove that housing, take out old thermo, pop in new thermo, and put some liquid gasket around the housing and bolt it up.
itsmeviet is offline   Reply With Quote
Old 08-19-2007, 03:34 PM   #3
IGSDann
IGSDann's Avatar
IGSDann is an unknown quantity at this point
Also cleanup the surfaces before you put on more gasket. Use a digrinder with a 3M abrasive pad or if you don't have that just some medium grit sandpaper.
Pushing 14.7 PSI of all natural boost!!!
IGSDann is offline   Reply With Quote
Old 08-19-2007, 04:07 PM   #4
nissantfsx
nissantfsx's Avatar
nissantfsx is an unknown quantity at this point
Send a message via AIM to nissantfsx
for s13, there is enough room to change the tstat without taking other things out of the way. s14...should be about the same...i think...
nissantfsx is offline   Reply With Quote
Old 08-19-2007, 04:34 PM   #5
BC240
BC240's Avatar
Took me just over an hour.. I didnt remove anything but the intake and a few hoses. The bottom bolt on housing was a bitch. How long should I let the gasket dry for before filling up with fluids/driving.
Old 08-19-2007, 06:16 PM   #6
projectRDM
projectRDM's Avatar
An hour or so at most.
FORMERLY R240NA
Old 08-19-2007, 06:50 PM   #7
BC240
BC240's Avatar
done, fluids in.. ill start it up and purge all the air out. thanks guys
Old 08-20-2007, 09:49 AM   #8
BC240
BC240's Avatar
Update, I drove to work today under mixed city/highway conditions which takes about 15 mins. Im running maybe 8 -10% cooler and also when I popped my hood I noticed my Rad or Fan(?) is making a fairly loud noise.. like a fridge cooling itself, which ive never heard before. hopefully that makes sense.
anything to be concerned about here?
Old 09-01-2014, 02:54 PM   #9
Alex_23
Alex_23's Avatar
Alex_23 is an unknown quantity at this point
Old post but im having same problem ^ this guy ontop probably got a winter stat , im going to replace mine very soon
Alex_23 is offline   Reply With Quote
