03-21-2013, 08:29 PM | #5161 |
03-23-2013, 10:45 PM | #5163 | |
Does anyone know the differences between the s13 and s14 nismo power brace? I attempted to install my power brace on my s14 today and NONE of the holes would line up and I highly doubt I am doing it wrong. Can anyone tell me measurements between the mounting points or obvious differences to see if I was sent the wrong type? I would like to double check before I call up the company and order a new power brace. Thanks!
03-24-2013, 04:53 PM | #5168 |
Here's what the new 45mm RCA Cor Integration knuckle looks like, I'll add it to the first page.
On another note, Wisefab is supposed to be coming out with the rear kit for S-chassis soon.
03-25-2013, 03:43 AM | #5169 |
They are, their rear upright looks like a work of art and much lighter than the oem upright with some sweet features, I'd buy one just for the cool appearence if I weren't converting to double-a-arm
The welding on Cor integration knuckle is seriously sweet. |
03-25-2013, 10:19 AM | #5170 |
Im having a problem after installing MA knuckles this weekend. Driver side would be touching the tension rod while passenger side had 2" clearance. Also, pass. side tie rod adjustment was extended all the way, so could not shift the clearance one side to the other.
Rack is centered, extended LCAs are within 1/8" of each other and BJ to TR pickups are within 1mm. Anyone experienced something like this, or have any idea of whats going on? |
03-25-2013, 10:23 AM | #5171 | |
03-31-2013, 11:14 PM | #5176 | |
Does anybody know the Ackerman difference on those Cor integration knuckles "chuckles". |
03-31-2013, 11:36 PM | #5178 | |
there isn't any more threads for me to tread onto though.... chopping it off won't help will it? i would have to chop off pieces off the inner and outer in that case.. ? |
04-01-2013, 12:21 AM | #5180 | |
i did that method where you count the turns. it's weird... turning to one side, i get 2.5 full turns turn to the other, i get 2.3 turns.. almost a full 2.5 but not all the way. |
04-01-2013, 12:27 AM | #5181 |
if you're using s14 inners you have to cut some threads off. I had too. make sure you thread on a nut first so that way you can fix the cut threads by backing the nut off.
04-01-2013, 12:34 AM | #5182 | |
even if i cut off some of the inners out, i have no room left to thread it onto. the outers are touching the nut, which is pushed back all the way as far as possible. |
04-02-2013, 05:05 PM | #5184 | |
Tried purchasing Moog Z32 inners which are shorter but they only had about 10-15mm of thread engagement after centering the rack and getting the wheels straight. I could have probably run a slip on spacer on the drivers side for more thread engagement but I felt it still wasn't enough. Noticed the s14 TEIN inners have a few extra threads so we ended up having to order those and chop them where the threads go into the large rack spacer as well as where the outers screw into the inners. Wasted some money/time but at least it works now. |
04-07-2013, 08:20 PM | #5185 |
Question on tie rod length w/ knuckles
I am planning on ordering the Abercrombie knuckles with 20-25mm extended LCAs. I currently run TEIN inners/outer with pbm rack spacer. If I orger the GKteck High Tensile Offset Spacers pictures below, that will move my rods forward like the relocated rack. My question is theoretically.. the gktech spacers are like 18mm + 7mm PBM inner spacers = 25mm.. So will I still need longer tie rods/ends or would going this route eliminate the need for the extended ones? Thanks
☆ Panda Pirates ☆ |
04-08-2013, 01:02 AM | #5187 | |
I ran these with z33 tie rods(short as balls) + SPL outers. I still think you should be fine. They add quite a bit of length. |
04-08-2013, 02:14 AM | #5188 |
I just ran into the same problem. Two choices:
A. Buy z32 tie rods B. Extend your FLCA or get some aftermarket flca. I am running drop knuckles with 45mm correction, Offset Rack Spacers, PSM eccentric rack bushings, Battle Version Offset Tension Rods. I am planning on getting the FLCA extended about a inch and a half to two inches. Also want to notch the FLCA where the tie rod outer would hit the FLCA. Also haven't decided if I wanted to run a 17x8 or 17x9 up front with about 0 offset. Trying to get at least 60 degrees. After that I don't really know where to go to try to get more angle out of this setup. This is how it sits now. (Not aligned, Stock s14 FLCA)
04-08-2013, 06:54 AM | #5189 | |
The only way I can see you getting more angle (not that you're really going to need it; but if you're really after it) is to get Cor Integration's curved tension rods and front sway bar. Unless you want to change your entire setup.
04-08-2013, 06:59 AM | #5190 | |
☆ Panda Pirates ☆ |
