Advertiser Announcements and Feedback This is where vendors can make announcements about upcoming promotions, events, items, etc. Vendors may also create threads here for the purpose of market research or other customer feedback. |
09-14-2010, 12:52 PM | #32 | |
Thanks for the support guys.
We're getting pictures of the completed PS kits this week. Brake lines, Brake Booster deletes, and Clutch lines are in stock. Quote:
"Does it matter if you are not running stock brakes" Good question! With this setup the master cylinder size is based more upon weight of the car. The master cylinder we use on most 240 sized cars is a 7/8's. We've used 7/8's on a EVO7 rally car with 4 piston Brembo's and it was completely sufficient. We're ALMOST done with KA stuff and then moving on to SR We're about 2 weeks out on completion of the KA harnesses. SR is about 4 or 5 weeks out, and RB 25/26 will be done by the end of the year. |
09-14-2010, 02:38 PM | #33 | |
Balancing adequate line pressure, comfortable pedal stroke and volume displacement with such a wide range of caliper sizes out there, a single size bore may not be ideal for every possible application. |
09-14-2010, 04:34 PM | #34 | |
Just to give you guys more knowledge, we installed a 1 inch master cylinder on our booster delete kit and 300zx brakes onto a S13. Its hard to explain it but the pedal was significantly harder to press, and required a lot more leg pressure to get the car to stop. Overkill. We haven't tested it but, I am sure that a full weight EVO or STI (No ABS) would make that extra bore size usable, without giving you leg pains. Just trying to make an example that bigger isn't better in this case.
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 |
09-14-2010, 05:42 PM | #35 |
Trader Rating: (115)
Feedback Score: 115 reviews
This is very tempting, but there is no way I would purchase it without trying it first. If anyone in Norcal buys a kit and lets me drive it I'll definitely write a review.
09-15-2010, 12:15 PM | #36 | |
09-16-2010, 02:06 PM | #37 |
i have a 240 with a 2JZ swap if you wanted to get your hands on i could get some prices for shipping it down there. no current wiring has been done and the car is a shell at this point.
09-18-2010, 01:36 PM | #38 | |
Replied to all PMs
PM me, our zipcode is 35173
09-19-2010, 08:08 PM | #40 |
Are you going to have the harness go right through the firewall like stock or is it going to have a connector right outside the firewall as I have seen some companies do?
09-19-2010, 08:43 PM | #41 | ||
09-23-2010, 01:31 PM | #43 |
Thanks for the support guys, replied to all PMs.
Also, some pictures of our pending KA24 harness
09-23-2010, 02:50 PM | #44 |
Bandwagon.
aww man, that looks sexy,
arent the single and dual cam wire harnesses different? |
11-06-2010, 03:43 PM | #47 |
Yes. We wont be making Single cam harnesses sorry.
11-06-2010, 03:44 PM | #48 |
Doing a few final tests and R&D will be complete. Expect to see and thread on here and a new store item for the LS1 harness in a week.
I looked back and couldn't find it. Can you send it again? Sorry about that.
12-15-2010, 10:06 AM | #51 |
http://zilvia.net/f/electronics/3575...e-harness.html
http://zilvia.net/f/advertiser-annou...-december.html
