Old 04-30-2013, 03:54 PM   #241
240low
240low is an unknown quantity at this point
cool, thanks for the info.. how much power is that producing?
240low is offline   Reply With Quote
Old 04-30-2013, 04:29 PM   #242
mmmS13
mmmS13 is an unknown quantity at this point
Never dyno'd but I'd say around 330-340whp. If I keep the car I will dyno it for sure.
S13 stock block Ka-T 16psi Enthalpy tuned
*SOLD*
mmmS13 is offline   Reply With Quote
Old 06-01-2013, 08:39 PM   #243
Sil#2
Sil#2 is an unknown quantity at this point
First Dyno. Seem right?
1997 Stock internals.
10psi.
JGS kit - AGP/Turbonetics .50 trim T3/T04E
Log manifold
JGS400 Wastegate
KA24(D)E downpipe and wg pipe set
550cc injectors
Z32 MAF
Enthalpy Tune - 93 octane
3" fmic
3" exhaust.
218 hp - Does that sound right? They said this Australian Dyno is similar to a Mustang Dyno.
Sil#2 is offline   Reply With Quote
Old 07-12-2013, 08:13 AM   #244
unclewolf82
unclewolf82 is an unknown quantity at this point
350++ hp
im building a 93 ka24de from the bottom up. i'm shooting for an hp range of 350 - 400. i've got eagle rods, wilco pistons with a .20 over bore, bc stage 2 cams, bc valves, bc valve springs & retainers, excessice fuel rail, excessive cast intake, excessive SR oil pan. what size turbo should i be looking for along with injectors and fuel pump?
unclewolf82 is offline   Reply With Quote
Old 07-12-2013, 09:24 AM   #245
josh_schul
josh_schul is an unknown quantity at this point
You sound like you have spent a good bit of money on the parts you already have... so if you are going to continue the trend. I think a perfect setup would be a Dual BB Precision 5858 turbo(id run Vband if you can too since you didnt mention your turbo manifold), Precision 880cc or larger injectors , Aeromotive Stealth Fuel Pump. You have a promising sounding build sir!
And id also like to just like to say you should consider getting rid of the bc cams for kelford stage 3 instead.... you wont be disappointed.
josh_schul is offline   Reply With Quote
Old 07-12-2013, 07:08 PM   #246
unclewolf82
i thought about kelford stage 3 cams but this car will also be serving as a daily driver.
Posted from Zilvia.net App for Android
Old 07-12-2013, 07:48 PM   #247
Bambi
Bambi's Avatar
Bambi is an unknown quantity at this point
Does it matter if you are to keep the butterflies, EGR, emissions, etc. ?
How difficult is to get good at drifting?
Originally Posted by Frank_Jaeger View Post
It's impossible because I tried once. Took out 4 telephone polls and a girl scout concession stand. All the thin mints and samoas couldn't even be salvaged.
Bambi is offline   Reply With Quote
Old 07-13-2013, 02:48 PM   #248
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
oh wow nice tread. good info for me
Old 09-05-2013, 11:42 AM   #249
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
10psi.
Log manifold
JGS400 Wastegate
550cc injectors
Z32 MAF
3" fmic
3" exhaust.
That seems low to me, even for that boost level on a turbo that size.
Frank_Jaeger is offline   Reply With Quote
Old 09-25-2013, 08:58 AM   #250
SolTNtuz
SolTNtuz's Avatar
SolTNtuz is an unknown quantity at this point
Pre tune new KA24DET question.
Still kind of new here hope right thread.
Just finished putting a new KA24DET in a 89 240sx.
I have the boost set at zero and the waste gate open and still the stock injectors ( 600cc are ready when motor is broken in and boost is set and heading to tune shop ). My question... The motor has a very rough idle and when I approach a stop the motor stalls. Less than 1 hr and 15 Km on the motor and not over 3000 rpm yet. Does the ECU need to be set up differently? The timing is set to stock specs and not sure what else to do.
Thanks for any help.
SolTNtuz is offline   Reply With Quote
Old 10-17-2013, 01:06 PM   #251
wsmiteh
wsmiteh's Avatar
wsmiteh is an unknown quantity at this point
Valve cover compatibility?
Want to do some work on a ka24de valve cover (polish, paint, w.e.). Do any other vehices with KA's have the same valve cover as a 97 240sx? Of course I cant an s14 at pick and pull but thought I could potentially find a cover for the same engine! I know s13 ones are different, but I was thinking SUV's and shit....
wsmiteh is offline   Reply With Quote
Old 10-30-2013, 11:43 AM   #252
Ikera
Ikera's Avatar
Ikera is an unknown quantity at this point
how much power can a stock Exedy Clutch hold?
I think I'm making about ~210WHP/TQ and about ~240HP/TQ at the crank
Max HP and TQ numbers were about the same
I'm planning to replace the clutch with a Bran new OEM Exedy but not sure if I should be upgrading
Ikera is offline   Reply With Quote
Old 11-06-2013, 08:33 AM   #253
motteramm
motteramm's Avatar
motteramm is an unknown quantity at this point
You need to upgrade to at least a Stage 2. The stock clutch will slip under any boost. I have a spec stage 2 in my car and I love it. Pedal feel is great.
"I have no cupholder"
motteramm is offline   Reply With Quote
Old 11-06-2013, 04:58 PM   #254
Ikera
Ikera's Avatar
thanks, I'll probably try to do a White Bunny Clutch swap
Old 11-14-2013, 06:25 AM   #255
JoeyTheKid
JoeyTheKid is an unknown quantity at this point
As far as main bearings go, should I just take the numbers off the block and the crank and order OEM with the varying grades? Or would I be better off getting ACL or Clevites and just plastigaging them to assure oil clearance is within spec?
JoeyTheKid is offline   Reply With Quote
Old 12-14-2013, 01:35 PM   #256
josh_schul
http://www.camshaftshop.com/products...ctid=988#specs
You retain a stock like idle. and they are good for 400 WHP + ... I need them.
Old 12-17-2013, 10:20 AM   #257
bigdnno98
bigdnno98 is an unknown quantity at this point
Kelford cams are the best I've run. I ran Kelford 272s in my 600HP EVO. Lumpy idle can be tuned out some for ease of DD. I personally loved the lope and it did not affect my DD ability.
bigdnno98 is offline   Reply With Quote
Old 01-04-2014, 04:50 PM   #258
pinedamatthew482
pinedamatthew482 is an unknown quantity at this point
ka or sr
Originally Posted by Jeff240sx View Post
Same as the SR sticky. Post up stuff here.
When I get back from class I'll add my information here. For now, all you people with FMU and otherwise stock fuel setup, go boost. I don't want you to disgrace or defame the KA anymore than it has been.
-Jeff
hey every i have save up about 1500 and i know i could get an sr but im not sure if i should build the ka im looking for the less expensive and less problemactic build
pinedamatthew482 is offline   Reply With Quote
Old 01-16-2014, 10:18 AM   #259
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
couple questions for you awesome people. z31 turbo? hard to make work? i know its a t3 but ive read some are water-cooled etc and the elbow on it 6bolt(i think)? anyone make downpipe specifically for this? will a external waste gate be needed or what? (had the turbo for a day cause he was moving and never got to check) basically, what would what would be needed to make this work as i can get a pretty much mint one for free? this is my first plan that im leaning towards as the turbo is free. also. if im shooting for 275whp is a stock motor okay? up to how much hp? also. my next plan would be a t25 with normal: 370 injectors, fmic, z32 maf, enthalpy tuned ecu (for both setups actually) yada yada yall know the drill. but heres my next question. if i, for example, use an isis sr20 elbow will the isis sr20 downpipe fit the chassis well even if it is a ka? of course id upgrade the clutch and put in a high flow cat if not a test pipe. glad i found this sticky since tax return season is around the corner. thanks in advance fellas.
vJilly is offline   Reply With Quote
Old 02-19-2014, 01:22 PM   #260
ShimiBoi
ShimiBoi's Avatar
ShimiBoi is an unknown quantity at this point
Anyone try adding a gallon of e85 to a tank of 91? If so, any results (ie. Performance or fuel economy difference)? Just a thought. Thanks!
ShimiBoi is offline   Reply With Quote
Old 05-04-2014, 08:53 PM   #261
JF_OverBoosted
JF_OverBoosted's Avatar
JF_OverBoosted is an unknown quantity at this point
My buddy did 25% E85 & the rest pump gas (91 octane).
He said it pretty much became 94-96 octane.
TUNING is a must though if you decide to blend the two.
JF_OverBoosted is offline   Reply With Quote
Old 06-08-2014, 03:55 PM   #262
joe95s14
joe95s14 is an unknown quantity at this point
so guys yesterday driving my car can it started like the car didnt have enough power to turn the drive shaft its made like a rattling type noise car has an oil leak "bad' but I keep oil in it car rattled and lost power till it died out sounded like battery had lost charge when I tried to start it back up got started but further down the road total y died no lights come on no nothing just rattled the whole time just before im about to tear it apart just want some ideas on what migh have happened
joe95s14 is offline   Reply With Quote
Old 10-15-2014, 03:46 PM   #263
ShimiBoi
ShimiBoi's Avatar
hey guys,
So I've been searching for more information, but have had no luck. Can anyone verify/deny the necessity for re-gapping spark plugs for winter vs. summer in SoCal?
Thanks.
Old 01-26-2015, 01:29 AM   #264
quick_240
quick_240 is an unknown quantity at this point
Hey everyone new to the forum. A year ago I walked into a awesome trade for a built 95 240 with the ka-t set up. Has been great to me up until a couple weeks ago. I had gotten into the throttle hard in third gear when the car started to stutter. It would do it with anything over half throttle, by the time I made it home it was missing at idle and sound very similar to a sti ( much to my dislike). Any ideas of possible causes or remedies?
quick_240 is offline   Reply With Quote
Old 01-26-2015, 04:43 PM   #265
KAT-PWR
KAT-PWR's Avatar
Check your couplers/boost leak test
MAF
Ignition system
MRP Manufacturing
Old 01-26-2015, 05:13 PM   #266
quick_240
Thanks for the tips kat per. I called the nearest speed shop. And they all but confirmed my suspicions of it being a fault aem pencil coil. Two were replaced by previous owner.
Old 02-14-2015, 09:08 PM   #267
EJ435
EJ435 is an unknown quantity at this point
how to post?
Yes I am new, this is my first car site/sign up and kinda confused. to i just click '' post reply''? or is there a way to make my own thread? thank you
EJ435 is offline   Reply With Quote
Old 04-10-2015, 02:10 PM   #268
wiring specialties
wiring specialties's Avatar
wiring specialties is an unknown quantity at this point
We have you covered for your S13 with a KA, either just an engine harness or a "combo" which is the engine and transmission harness together.
http://www.wiringspecialties.com/ka24des13.html
wiring specialties is offline   Reply With Quote
Old 05-06-2015, 05:22 PM   #269
pignose.007
pignose.007's Avatar
pignose.007 is an unknown quantity at this point
Hey guys, I just found a screaming deal on a TD04L-13T off of a WRX with an intercooler. Any clue how bad it'll suck to match up flanges? And can I still run a z32 MAF?
pignose.007 is offline   Reply With Quote
Old 10-25-2015, 03:12 AM   #270
Livid_240sx
Livid_240sx's Avatar
Livid_240sx is an unknown quantity at this point
The flange it the same as a 16g.
'91 s13 (Drift Rocket Under Construction)
2000 civic Si Coupe (Daily)
Livid_240sx is offline   Reply With Quote
