08-21-2012, 06:51 PM | #2491 |
What are your camber settings? Any fender work? How close to the fender/coilover (assuming you are running them)? I'm guessing atleast a roll in the rear? I'm putting 275 NT05's on the rear of mine and I'll be running 245's up front...
08-22-2012, 09:39 AM | #2492 |
I have on my 1989 S13 hatchback, 17x8.5 +38 RPF1 front with 235/40/17 soon to be 255/40/17 fronts and 275/40/17 NT05 reas on 17x9.5 +38 RPF1s, roll and pull. The 275 NT05s have a lot of sidewall (which I wanted and they are pretty wide), but Nittos tend to run a little smaller than other manufacturers. Their section width is listed at around 10.6 inches. I have had them rub on the fender and on the inside fender well, but now they are aligned for autocross and nothing is rubbing. I don't have the alignment settings on me but I can post them later if desired.
I do want to get 17x10 +18 RPF1s but I know that they wouldn't fit on my car without widebody fenders. |
08-22-2012, 03:27 PM | #2493 | |
Yessir on the fender work. What size rims are you putting the 245's on in the front? I have the alignment specs on my photobucket but that site is being janky at the moment. I'll post them later. (EDIT)Alignment specs after alignment complete: Last edited by stockbee; 08-22-2012 at 04:29 PM.. |
08-22-2012, 04:04 PM | #2495 |
Trader Rating: (24)
Feedback Score: 24 reviews
You'll need a ~5mm spacer in front, most likely, to clear the suspension. And a 275/40 will need some work to clear in back. I'd recommend against such a big stagger, anyway (or any stagger).
08-22-2012, 10:54 PM | #2496 | |
What fender work is done? I know one of the guys posted back a few pages was running 18x10 +3x offset and was running very little camber out back fitting some decent meat(275>). I'm not sure what he was running up front though. e1-griego: Stagger this, stagger that. Porsche Turbo's run 235/305 and have zero issues, then again they do have all the weight hanging off the ass end.
08-23-2012, 05:35 AM | #2499 |
Oh don't get me wrong, by no means was I comparing, just using it as an example of how extreme the stagger offset was. You can also use the ZR1s 285/335 stagger offset for the sake of arguing. It is as you said though, it is more so a personal preference. However, I wouldn't suggest going out and trying to make skinnies and slicks "handle".
08-23-2012, 01:34 PM | #2500 | |
Your 265/35/18 is only about 1/2" taller than a 285/30/18 (which is what I run up front on my s14 with pulled stock fenders). So it'll fit obviously. The 265 is more than 1" larger in rolling diameter than the stock s14 size - just make sure you want that much of a difference, as there are some potential cons (wear and tear, etc.) Last edited by mt2forty; 08-23-2012 at 06:39 PM.. |
08-23-2012, 01:42 PM | #2501 |
Front tires don't affect gearing.
08-25-2012, 07:24 AM | #2504 |
Would 265/45/16s fit up front in an s13? They'd be going on 16x9 +0 starion wheels.
'89 240sx-Track monster in progress '03 Grand Prix GTP-pepped up DD. |
08-25-2012, 08:09 AM | #2505 | |
Not under Stock Fenders.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
08-25-2012, 08:38 AM | #2506 |
I'm wondering what's the widest anyone in this thread has gone up front on an s13.
I have 245's up front on 18x9.5, but I want to try 285's up front. I have -2.5 camber up front and +8 deg of caster. It looks like I'll need to tub it a bit for full lock also. I don't care about fender modding. I have flares to put on, and eventually will pit wide fenders once I can decide on the tire combo. There has to be somebody running a 275+ up front... |
08-25-2012, 04:03 PM | #2507 | |
08-25-2012, 11:19 PM | #2509 |
im running 265's up front and 335' rears, 265's are the widest i could see anyone putting up front on an s13 unless your running crazy negitive offsets....mine are 18x10 +0 in front, i have full lock clearance (barely)
08-26-2012, 09:52 AM | #2510 | |
since no one makes 245/45 street tires anymore, i'd suggest either 225/50s all around if you aren't crazy low, or f-225/45 r-225/50 stagger for extra front steering/lowness clearance.
08-28-2012, 04:29 AM | #2514 | |
I believe I asked this before but for the life of me can't remember nor find it.
Wheel Size and Camber? IIRC Rear is 9+17 Correct? Fenders just rolled no pull?
08-28-2012, 04:45 PM | #2517 | |
Max rubber, not Max stretch retard...
08-28-2012, 04:47 PM | #2518 | |
Trader Rating: (163)
Feedback Score: 163 reviews
08-29-2012, 12:01 AM | #2519 |
any side pics?
08-29-2012, 05:23 AM | #2520 |
Just bought 9.5 +20 18s all around for my s14. I understand no matter what I will need to roll the front (backs done) and maybe little pull out back. I want to run a square set up and the issue is that 235 40s (easy fit set up) run 10% larger outer diameter than stock while my much preferred 245 35s (unsure of clearance) only run 7%. Does anyone know I can fit the 245s and whats needed?
