#211 |
![]() Join Date: Jul 2005
And even with tubs you can get some inner rubbing at full lock (especially with modded knuckles). For street driving this isn't as much of an issue because you can drive around super slow through different road environments, but if you intend to do a track day just go with a narrower wheel and a slightly wider, grippier tire.
![]() Instagram - SJKnoop |
#212 | |
![]() Join Date: Sep 2003
#213 |
#214 | |
Man w/ CTSV & a Car Seat
I was running 18x10 +18 up front on my Topline Aragosta with no spacers. It cleared fine and I still had 1-2mm to clear the springs/collars. But if BC is anything similar to MRs (which I think they're the same exact thing just rebadged), I was running 17x10 +12 FN01s and I had to run 8mm to clear those. MRs struts are fatties. Just for reference, 17x10 +12 with 8mm spacers (effectively +4) up front with 235/40-17 on Megan Racing Coilovers ![]() and 18x10 +18 w/ 225/40-18 on Topline Aragostas. ![]() |
#215 |
If i need to ask in the random question thread i will, but this is pretty much a fitment question
Does anyone know the specs of the wheels on this vehicle? http://farm5.static.flickr.com/4073/...6ce06b51_z.jpg |
#216 |
I'm sure I already know the answer to this question..
But over most of the bumps in the road, my rears are rubbing. Happens all the time. Is the only way to remedy this solution to pull/roll the rears out some more? And smaller tire? I am gonna swap out my 235/40 for a 225/40 in the rear and was thinking that it would help, but I haven't gotten around to doing it yet. |
#217 |
![]() Join Date: Jul 2009
![]() Feedback Score: 17 reviews
More camber, more pull, or smaller tire. Easiest and and less costly way is rolling/pull unless you dont have a heat gun which should be that expensive anyways.
http://thatistupid.tumblr.com/ |
#218 | |
#219 | |
#220 |
Bwaaaa?! I am heart broken! I guess maybe you forgot to mention that on your Rimtuck listing...
Well, I'll glad you told me now, before I actually tried to do it and came back here posting, trying to figure out why its not working! lol But if that 10mm spacer was needed to clear the coilovers and not to keep the tire from rubbing on the inner fender, then my plan of 17x10+20 with Megan extended brackets may still work. But you brought up a great point about pushing the boundaries of the stock body. If being able to post 17x10+20 with 235/40's up front under stock fenders and no spacers is that damn important to me, I just may be fucking up at life... Forum accolades and hard parking for pics make ppl think up silly shit sometimes... No offense to anybody. |
#222 |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
okay got some numbers so help me out guys. I think I sort of got it not too sure yet.
1. http://zilvia.net/f/chat/166563-maxi...ml#post4247532 2. http://zilvia.net/f/chat/166563-maxi...ml#post4248528 anyone else wants to take a shot? when I measured with the 3" I added it to the side wall height. Is that right? Or am I supposed to add it to the side of the actual sidewall?
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
#223 |
Wait, what the hell are you trying to do? You're linking a whole page so I'm not comprehending what you're even trying to fit in.
Post up wheels size with offset, tire sizes you're planning on running and what chassis. |
#224 | |
#225 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
Thinking about pulling my S14 quarter panels by an inch or so to help get rid of the -4* of camber I have with my 17x10j+18 wheels. Would I be able to tuck after I pull the quarters, without having to run useless camber again?
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#226 |
![]() Join Date: May 2003
Trying to run 18x9.5+14 up front on an s13 with oem Silvia fenders. I am aware that I will have to break out the BFH and go to work on the wheel wells but I am trying to run as much tire up front as possible (235/40 direzza star specs). The car will not be super low as it still has to be functional and I'm willing to run as much as 4 degrees of camber up front if I can get it with slotted lower mounts and maxed camber plates. Coil overs are a custom ground control/Koni setup. What would be the optimal tire size and how beefy are the star specs? Would 225/40 be a better option? Rears are 18x10+20 and I'm planning on 235/40 or 255/35 Star specs. Fenders and susp arms are stock for now but I plan on a roll and mild pull. Thoughts on which size would be best?
**The atypical S-chassis enthusiast*** Last edited by kouki-gymkhana; 09-18-2011 at 03:29 PM.. |
#227 |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
There's no real measurement for cause and effect with pull & camber so you would really just have to eyeball it. Theoretically though, yes, pulls relieve some of that negative camber business.
#228 |
flip/frsh the two links were to the two posts of detailed specs. here we go:
This is what i got from willitfit.com: old/new Diameter 615mm 606mm Circumference 1932.1mm 1903.8mm Poke 42.6mm 101.6mm Inset 122.6mm 101.6mm Speedo error 0% 1.49% Reading at 30mph 30mph 30.45mph Reading at 60mph 60mph 60.89mph Ride height gain 0mm -4.5mm Arch gap loss 0mm -4.5mm rimnsntires.com old/new Wheel size 15x6.5 ET 40 / 15x8 ET 0 BackSpace 135 mm (5.3'') / 114 mm (4.5'') 21 mm (0.8'') shorter. Rim Lip / 59 mm (2.3'') wider Typical Weight ~ 15 lbs / 7 kg ~ 18 lbs / 8 kg Tires: Tire 1 / Tire 2 Tire size 195/60-15 / 225/50-15 Section width 195 mm (7.7'') / 225 mm (8.9'') Sidewall 117 mm (4.6'') / 113 mm (4.4'') Tire diameter 615 mm (24.2'') / 607 mm (23.9'') 8 mm (1.3%) shorter. Rim sizes 15x5 to 15x7 / 15x6.5 to 15x8.5 Circumference 1931 mm (76'') / 1906 mm (75'') Revs per mile 833.4 / 844.4 Speedometer Assuming that this is OEM tire and speedometer readings are correct >>> When speedometer reads 60mph (96.6km/h) actual speed will be 59.2mph (95.3km/h): 1.3% slower. So how would I go about seeing if I will hit lock to lock and not rub? height wise it looks like a go from both sites just not sure about hitting c/o's, inner fender, etc. can someone help me out please. thanks! acutually it gives to reading from the speedo. well from the two diff sites.... I have a stock s14 with these: ![]() specs 15x6.5 +40 stock tires are 195/60/15 4 LUG. like so but with usdm front: ![]() Well I measured just now and it looks like it will fit... Thats what she said... but I measured on the front most area of the tire and the back most area of the tire as well. I measured again with the wheels turned to full lock I added 3" to the side wall height. Is that right? I'm trying to get this guys, really I am. aslo added the 1010tires.com calculation in here as well. Current Wheel Specs Width: 6.5 inches, Offset: 40mm New Wheel Specs Width: 8 inches, Offset: 0mm Inner Clearance: 21mm MORE (the inside of the wheel to the strut housing) Outer Position: EXTEND an extra 59mm (position of the outside edge of the wheel)
#230 |
So your trying to fit a 15x8 +0 on your S14? What tire size you gonna run? Or is that your question?
Seems like your comparing your previous wheels to the new 15x8 +0 to see if your gonna rub the wheel wells?
#231 |
correct 225/50/15x8 +0 I just don't want to have to pull or roll the fenders. it's stock height >>at the moment<<
From the pic that zoom posted: ![]() That 17x8 +30 did the math with +0 and doesn't look like the above pic in any way... so that's why I am trying to figure out with 15s if it will work (since it's 2" smaller)
#232 | |
#233 |
well I want to make sure I'll be fine now, and later when I go lower. trying to do the research now, and not learn along the way. make sense?
*** only mod I have done are the inner and outer tie rods*** I do have all the other suspension pieces and have a few more to order. remember AT THE MOMENT ![]() i want to do it all at once instead of piece bby piece. I figure thats the best way to do it
#234 | |
PS: if you want shit to fit/flush/line up with the fenders, you're gonna have to roll the fenders atleast. Tires will probably touch the fenders once you lower it so theres not much butts or ifs about it. |
#235 | |
That's why I am asking you experts for help I just want to do this right the first time. not trying to go 16"s-24"s. not looking to slam/mod slam either. Don't want to roll or pull fenders. and i know I can fit lots of sizes under the stock fenders, but we are talking about 0 offset my stock oem wheels were 195/60/15.6.5 +40 I mean I got that height wise they will fit if you look on the willitfit looks like its hitting on the actual suspension components. I see on rims and tires, again, It's shorter. But I don't know how to use the other numbers to figure out how it's going to fit once its on the car. Been going here for years Car Bibles : The Wheel and Tyre Bible Page 4 of 4 put in the numbers there as well. doesn't show the tire width wise.
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict Last edited by hellion240sx; 09-18-2011 at 10:12 PM.. |
#236 |
Trader Rating: (38)
In my defense, I was going by what I found-- the owner of that S14 posted those specs so I went with it. Now that I think about it, the wheels may have had some spacers. But the original offset must have been +30.
0 offset will provide you with a lot of poke. Stock height, lowered height, slammed height, it doesn't matter, the car will have major poke because of that 0 offset. Fitment issues come about with calipers, outer fender clearance, and inner fender clearance. The spoke design, disc design, the ride height, the wheel size, the tire size ALL are components to what fitment is all about. Obviously 15X8 +0 isn't going to need a pull/roll at stock height because well, the car doesn't have to worry about contact with the wheel at all. If you plan on lowering the car an inch or two & there is wheel gap, you'll STILL be fine. No roll/pull will be needed. |
#237 |
I have an S13 on some Tien HE coilovers. I'm looking into getting some wheels and I was looking at something around the area of 17x10 with about a +0 to +15 offset. My goal for the tire set up is grip, I would like to get some sticky tires that will put all my ponies to the ground. I'm thinking the 17x10s will go on all four corners.
What kind of good tire sizes am I looking at for a grip set-up here? And am I looking at any fitment issues with these up front? (It would be preferred if I could fit 300z brakes behind them in the long run) |
#238 |
Trader Rating: (38)
Caliper clearance is dependent on spoke/disc design so you would have to see if the wheels that you plan on purchasing will be able to fit them in there.
As for your tire questions: http://zilvia.net/f/chat/166563-maxi...nt-thread.html --that's where you want to be searching. 0 offset & +15 will not clear coilovers so you would need to have spacers. And with that aggressive size, you will need tubs for the fronts, a roll, and a pull (or overfenders) |
#239 | |
#240 | |
Lowered an inch or two is all I'll probably do anyway.
