01-13-2011, 06:10 AM | #2341 | ||
Second, are you talking about not shortening the knuckle or possibly extending it's length right?
01-13-2011, 06:26 AM | #2342 |
01-13-2011, 07:10 AM | #2343 |
I don't see anything special about those knuckles to be honest. That's cool that you're trying them out though.
Oh and everyone can stop getting a boner over the fact that saito runs them, JZX knuckles are the simplest things in the world because the steering arm comes off. There are only so many ways to skin a cat (or modify a knuckle).
01-13-2011, 07:24 AM | #2344 |
So I was thinking, and in my morning stooper I came up with the question: Is there anyway to modify the rear suspension so there is not a significant change in camber under compression?
Off the bat I think a much higher spring rate would obviously make the rear suspension compress less, but I wasn't sure if there was anything going on with the rear geometry that could be tweaked.
Instagram - SJKnoop |
01-13-2011, 07:52 AM | #2345 |
^ that'd be interesting to find out.
just first initial thoughts,... id think that'd go into the mounting point of the coils to the shocktower. pushing it out to a more parallel stance, so when they did compress, it would be more of a straight up and down instead of the slight angle. dnt know if the trouble would be worth it.....lol
cONtRol FReAkS |
01-13-2011, 08:44 AM | #2346 |
Google Translate, lol... $25,000 yen is only $301 US. Not bad. Are they just painted a silver color or are they actually aluminum? That would be sweet.
HEY MAN!! Price S13・S14・S15、シルビア・180SX用 S13 · S14 · S15, 180SX Shiruhi for Asia & ブルブル防止ナックル S anti-knuckle dollars off valve 価格 中古下取り \25,000(税込) Trade-owned \ 25,000 (tax included) 開発コンセプト シルビア系にある、 逆間接を防止しつつ、切れ角アップ 、若干のクイック感、アッカーマンアングルを見直し、ドリフト中のコントロール性を重視。 System in Asia & Shiruhi, while preventing reverse indirect,゚Affu turning angle, a slight feeling of quick, review Akkamananku dollars, s emphasis on default controls in the lift. 3UP三上氏と製作。 Mr. Mikami 3UP production. 効果 従来の加工ナックルと違い、上級者はもちろん、初・中級者でも低中速サーキット、高速サーキットとコースを 問わず違和感なく使用出来る様、ノーマルのハンドリングやフィーリングを損なわない様な仕上がりになって いる。 Unlike conventional processing knuckle, as well as advanced, low-medium speed circuit at the first intermediate, different courses can be used seamlessly with any high-speed circuit, such as to impair the finish lever on normal link Ya Firinku s The.
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
01-13-2011, 10:49 AM | #2347 | |
Might have this backwards, but the more equal the 2 control ams are the less camber will gain as the car rolls.
01-13-2011, 11:05 AM | #2348 | |
Might as well convert to a custom double wishbone if you're going to start splitting hairs. Or a solid axle. :ghey: Shock position doesn't have much to do with the way the suspension compresses in the rear.
01-13-2011, 11:34 AM | #2349 | |
Having the car roll 5º and the camber gain 7º(fake numbers) you'd have negative camber on the loaded wheel. It's not a cut and dry answer of "camber gain is good". It, like everything else with suspension, needs to be tuned. Someone mentioned shorter RLCA's. This will reduce camber gain but if you have a car with a lot of travel it could also do other undesirable effects to the suspension. But, for 95% of coilover'd cars it won't matter because the susp doesn't move far enough to really exploit the downside of shortening an LCA.
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all |
01-13-2011, 12:20 PM | #2350 | |
Now if your car is dumped on the ground (tucking to rim on 18's) and without subframe risers, you might have a problem because the control arms are in a very "steep" part of the camber gain curve. The only way to fix this without modifying a whole bunch of things is to raise your car or get drop knuckles. Or crank your subframe way up in the chassis.
01-13-2011, 12:42 PM | #2351 | |
R.I.P. Aya, always love
Trader Rating: (215)
Feedback Score: 215 reviews
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
01-13-2011, 12:50 PM | #2352 | |
But with shortened RLCA's you'll get even less camber gain. Since the car doesn't roll much to begin with it's not a HUGE downside. That's why I mentioned tuning. If someone was to modify their RLCA's for less camber gain their should do it empirically and evaluate the results based upon different RLCA lengths and other alignment settings. A good way to start would be to measure temperature gradients across the tire or tire wear(for a drift car). People need to understand that you can't just "cut 1/2" off of the RLCA" and it will magically make the car a grip machine. Ultimately, what I'm saying is that 240's have too much camber gain when significantly lowered. Even with stiff coilovers there is enough movement there to really gain a lot of negative camber. A quick reference would be watching one of those Option videos where they have a camera focused on the rear wheel. It's pretty obvious that the wheel toes out and gains camber(pretty bad for a drift car) on the cars they test.
01-13-2011, 02:46 PM | #2353 | |||
Shinji put it to me like this: "many company make knuckle, then test for one type of track, and one type of tire, but we tested on both big track and small track, good grip tire and shit tire, etc". You won't notice anything drastically different with these knuckles by looking at the design as it's pretty simple and standard, but the difference comes in the fine tuning that was performed in the development of these knuckles. I'm not trying to say that HeyMan! is the only company to really develop knuckles or anything, but they were definitely one of the first to start modifying knuckles. Quote:
Yes, JZX knuckles are super simple. One piece of straight, flat metal w/ 2 bolt holes! lol Quote:
Oh, and to the person who asked if they were aluminum or painted, they are painted.
01-13-2011, 03:20 PM | #2354 | |
I ideally want function and form. In order to fit my wheels out back with -1.5 camber I am going to have to make some significant changes to my fenders already and I don't want to make these drastic changes and have only half of my tires being worn still. Currently, I guess I have around -2.5 and am wearing just about half of the tire when I drift. Looking at my car from the rear when its sitting still the camber looks normal, it looks like I have very little. I saw this picture and realized I'm gaining a significant amount of neg camber under load:
01-13-2011, 03:58 PM | #2355 | |||
Or you could raise your car or run a different wheel, but that kind of defeats the purpose eh? haha. It's all a compromise.
01-13-2011, 04:16 PM | #2356 |
95KA-Turbo, We shortened the LCA's on my buddies S13 and his car wears the tires way more evenly now. And the car is WAY faster mid drift. Also, the car sits really really low to the ground.
01-13-2011, 05:14 PM | #2357 |
The funny thing is all you did was run less static camber.
Actually decreasing negative camber gain would mean changing pickup points on the subframe so as to change the arc of the control arm.
01-13-2011, 05:20 PM | #2358 |
Shortening the LCA does affect static camber. But, don't forget that it also makes the arc radius of the LCA smaller, therefore it will "pull in" a lot sooner as the suspension compresses.
01-13-2011, 05:45 PM | #2359 |
Actually it doesn't really do much. It's the same as lengthening your RUCA. Sooooo...
Like I said. It will help you 95KA in the fact that it will decrease your wheel base, making your wheels sink a little and meaning you won't have to go to town on your fender so much. Not sure if that's what you're looking for though.
01-13-2011, 05:57 PM | #2360 |
I made my front lca a lot shorter. Had to do this so i can run my camber plates to a max to reduce binding on the lca bearing cup. I have to redo my control arms and use a higher misalignment bearing now. I can barely get full lock on stock knuckles before it starts binding =(.
I'm gonna use the bearing SOsideways showed 2 pages back, but i still cant find the bearing cup for in in the catalog of UB machine.
Nothing says racecar like a stock car with no interior. |
01-13-2011, 07:17 PM | #2361 |
Shortening the LCA is a great idea I hadn't thought of. I am fine with the wheels being slightly more sunk and running less camber. I have to do fender work regardless, so it'll just mean a little less work. Not to mention the roll center mod I've already done makes the wheels poke more then they should, so maybe it'll even it out.
01-13-2011, 07:48 PM | #2362 | |
I'm speaking from experience. Having done the mod to an S13 and seeing favorable results in both tire wear and grip during drift.
01-13-2011, 08:11 PM | #2363 | |
And if you're not running crazy sized wheels like 95KA, it will work just fine.
01-13-2011, 09:01 PM | #2364 |
I was worried the driftworks knuckles + HICAS rack would be too much and make the car feel twitchy.
mmdb seemed pretty happy with the quicksteer on his driftworks knuckles w/ stock rack and I needed some extra money to help pay for them anyway so I sold the HICAS. |
01-13-2011, 09:09 PM | #2365 | |
I might add living in Socal I have a few extra options as well. Oh and I do not think the driftworks knuckles are the be all end all.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html Last edited by drift freaq; 01-13-2011 at 09:41 PM.. |
01-13-2011, 10:31 PM | #2366 |
Trader Rating: (106)
Feedback Score: 106 reviews
I think you guys are focusing on the wrong arm to reduce rear camber gain. It's the trac arm that's SUPER short, the ruca is decently long. With that arm so short as the suspension compresses it gains massive camber and toe. I'm not saying that lengthening that ruca wouldn't be useful, but I doubt it would be as big of a difference. Shortening the LCA would accomplish the same goal, but I don't think that narrowing the rear track is anything that I would personally want to do.
01-14-2011, 06:51 AM | #2367 | |
Sorry if I sound like a dick in the above posts guys, I didn't mean to. I was just assuming people (in general) knew information they probably don't, and now that I go back and read them, they sound kinda mean, , hahaha.
01-14-2011, 08:11 AM | #2368 |
aint nothing mean about learning people some knowledge!
cONtRol FReAkS |
01-14-2011, 08:41 AM | #2369 |
I just got my Driftworks knuckles in yesterday. I will try to do a decent writeup in the coming weeks. Out of the box everything seems solid, but Ill go more in depth when I put them on.
If anyone wanted these, you should have jumped on the 10% off they had. |
