#2341 |
yeah but that is more difficult than just dremeling out 2 mm on the coilover shock mount
i think he had to do it that way because their suspension is different on those cars? |
#2342 |
not saying i want to go over -3 but it would be nice to figure our why one side goes out that far and the other only goes out to -1. something is fucked...
#2344 |
![]() Join Date: Sep 2009
Trader Rating: (22)
![]() Feedback Score: 22 reviews
Just finished installing my kouki aero for the moment! excuse the ride height, i just put them on and havent had a chance to adjust it, too busy getting ready for a drift event tomorrow. plus i need a new downpipe, mine actually scrapes at THIS height...
#2345 |
![]() Join Date: Apr 2008
Trader Rating: (161)
![]() Feedback Score: 161 reviews
Bushido what bulbs are you running for the position lights? They look nice.
Rear looks really good IMO, I like it.
180SXオタクだ! |
#2346 |
![]() Join Date: Nov 2005
Olly's blog.
#2349 |
Perfect car is perfect! It pulls off higher offset wheels so well, looks great actually IMO.
Rules: ![]()
enjukuracing.com |
#2352 | |
![]() Join Date: Dec 2006
im at 3.5 with just PBM coils, just enough for my tractor tires to clear the fenders with 7mm spacer
#2353 | |
http://www.leg1t.com |
#2354 | |
![]() Join Date: Feb 2008
![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
I'm on PBM too. There's about 3-4mm left on the camber plate up top that you can't use because the allen bolts hit the shock tower before you can max it.
SPLparts.com * PoweredByMax.net Quote:
#2355 | |
I'm using led replacements for stock 240sx tail lights... 1157? I wanted the position lights to function as blinkers so i could use the kouki signal lights as fogs. what i did was cut off the bulb holder on a spare taillight i had. ![]() then i epoxied it to my dmax position lights. ![]() soldered the wires to the connector and shrinkwrapped. ![]() ![]() led bulbs look like this. ![]() ![]()
#2357 | |
my circuit sport mount keep the engine higher than the drift freaq mounts but not high like nismos so my pan is not hanging but i have no problem with the dmax hood or strut braces or anything.
also my stance GR+ pros have slotted hub brackets for more camber adjustment Quote:
#2359 |
My kouki Cutter.
#2360 | |
i assume you know this but you can move the allen bolts which is what you're supposed to do for max camber either way to achieve more camber than stock on a s13 add s14 lca's and slot the shock mount hole on the coilover |
#2361 | |
![]() ![]() All lights on. ![]() Here is what it looks like when they flash. Last edited by Matej; 05-28-2011 at 05:23 PM.. |
#2362 | |
![]() Join Date: Jun 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
You mean like dremeling a few mm's? any pics?
#2363 |
did the front today fix my camber issues. the bolt on the top spindle hole was somehow bent pushing the coilover out giving me positive camber.
![]() having correct camber in the front left alot of spece to fill in the fender wich is good cause i wanted to run a wider tire anyways. ![]() |
#2364 | |
![]() I've been thinking of getting that PBM kit as well, lights look really good guys. Great fab work on your part Bushido!
180SXオタクだ! |
#2365 |
![]() Join Date: Oct 2010
i had that idea about the turn signals to fogs a while ago,but i haven't even got all my lights hoOked up yet. it looks good!!!! NICE WORK!
#2366 |
![]() Join Date: Mar 2007
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
Thats My Ninja.
We are the same ride height - Perfect! +1 for the 18/18 posse I got some S13 LCA's i'm gonna Put back on so I can get some more Posi back into mine. I hate -5 in the front
z-tERty-2 |
#2370 |
It does. I'm running that. Just have to cut another square out of the plate for accessing the new position of the drain plug for oil changes.
★ Team Rowdy ★ |
