#22141 | |
Here's the best pics I could find when my engine was apart, if that helps. ![]() ![]() |
#22142 |
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
Just wondering .. have any of you guys had experience with converting your SR to delete the ignition chip? And use smart coils from a VQ? I have heard LS coils / R8 coils .. but not so much on VQ.
Sent from my iPhone using Tapatalk |
#22143 |
![]() Join Date: Nov 2015
![]() ![]() Feedback Score: 6 reviews
I suppose so long as everything is tight and the gauge is reading that itll be fine. Whenever the engine gets pulled ill most likely have a closer look. Who knows, maybe the threads are fcked
Skurr ![]() |
#22144 | |
It's a pretty strait forward upgrade. And the S15 & VQ coil pin out is the same, I have a write up somewhere. |
#22145 | |
Trader Rating: (92)
I seen some online vids, I’m just curious on how much Hp/Boost the VQ coils can handle. Wouldn’t mind supplying that write up? Sent from my iPhone using Tapatalk |
#22147 | |
It's not really a write up, but post #22 in this thread has pictures and wiring info: https://r.tapatalk.com/shareLink?url...2&share_type=t |
#22148 |
![]() Join Date: Jan 2010
well I went ahead and ordered them and they look sweet for what I paid, the heim is nice and tight and it looks like they made the arm with very low cars in mind (a big selling point for me). going to install in a month or so when I have everything else. just in case anyone finds this searching down the road.
#22149 |
Small stupid question... But first watch this video:
Okay now hear me out... EJ20 Z32. Did I make anyone vomit? lol SR Z32's are popping up more and more. 400lbs weight reduction over the VG30 right there. FWIH, the EJ20 is lighter than the SR and from the look of things last time I checked, these engines are cheaper than SRs too (which have been on the rise). I've seen complete WRX engine for under $900 without the transmission, which is fine because the VG trans should be stronger anyways (if it could actually work). Should be better weight distribution too. Complete pie in the sky idea but was curious if I'm the only person interested in it.
"Simplicity is the key to brilliance." - Bruce Lee |
#22150 |
So, what is your question? People have swapped EJ20s in plenty of chassis. the biggest hurdle ive seen with the swap is width in the bay/shock towers due to it being a pancake powerplant.
the big upside about these power plants (other than weight) is lower COG. although keep in mind, every powerplant has their own Achilles heel. in stock form, the EJ20 has a turbo hanging over a cylinder that can put increased wear on it(I believe cylinder #3), and the intake manifold is facing the firewall. lets also not forget to mention open deck, im not sure if all are, but I definitely know some are open deck block. currently working on one with my roommate and have learned a bunch about these little motors over the last year or so. they are sooo small when you get all of the auxiliary crap off of it and just down to the bare block/head |
#22151 | |
AFC #1
![]() Join Date: Oct 2003
#22152 | ||
Edit: Shit. the VH is 29 inches wide. The EJ is 32 inches wide. Tight fit city. Sounds like a no go. Did that dinky little MR2 Spyder really have more bay space than a Z32?!? hmmm...
#22153 |
as stated above, the biggest hurdle is the width. its not necessarily a 'bad' idea if you can get it to fit. although im sure a lot of people would be dismissive of it as its outside the norm. ive also discovered a lot of people are somewhat dismissive or ignorant when it comes to subarus in general (certain Subaru owners don't help themselves in this situation).
also, you cant really compare a mr2 bay to a z32. mr2 is RR layout, where as the z32 is a FR type layout. the blocks aren't even facing the same way. apples to oranges. |
#22154 |
You are right. Maybe I'll just toy around with the idea of an EJ20 SW20 instead.
I wish the video had a shot of the engine in that MR2 Spyder's bay. If he had to cut out the firewall between the engine bay and the trunk, then I'm not interested.
#22155 | |
AFC #1
#22158 |
https://m.youtube.com/watch?v=gUn9CywHLd8
I saw this video on Instagram, then found it on YouTube. Can anyone explain what the hell is happening? |
#22159 |
I'm not sure what you're getting at... I'm investigating water leaks for a daily driven car. I have my door cards off and with the windows closed, water seeps into the inside of the door from the outside. Since its like that for both sides, I'm looking for clarification if that's how it's supposed to be.
Sent from my SPH-L720T using Tapatalk
Skurr ![]() |
#22160 | |
You probably need a new seal, door aligned, or window aligned. Had my passenger window misaligned for a bit, drove through one of those gas stop no touch car washes, and my buddy got a shower when teh water sprayed through the top seal. I didn't know whether to laugh becuase he got a bit soaked, or cry because my seat got wet 😅😅😅😅💀
#22161 | |
Skurr ![]() |
#22162 | |
If water is coming in along the top of the window, then you'll need to check the rubber seals or adjust windows. |
#22163 | |
Is that plastic trim Im talking about called the belt moulding?
Skurr ![]() |
#22164 | |
#22165 |
![]() Join Date: Jan 2013
Didn't know where else to ask this and just wanted you guys opinion. Ive always loved the R33 wheels but unfotunately they only made them as 17's and I really only like to run 17/18 on my car.
However I saw this purple car on instagram with M-Parallels on his car. Do you guys think the R33 wheels up front and the M-Parallels on the back would match up well or no? The Bmw wheels would need to be re-drilled to 5x114.3 as they come 5x120. The M-Parallels dont really concave like the R33. ![]()
Instagram: Nismo_Lk |
#22166 |
I would venture to say that with the two different wheels being on the same car and so close to each other, it may look okay at a quick glance or possibly rolling. but I can guarantee you if you are nit picky about the details like some are, you will see the differences in the wheels and that is the first thing you will always see when you look at your car in that hypothetical state (such as the concavity issue you mentioned). it would drive me up the wall.
I do wish that r33 wheels did come in 18x9 as well. :/ |
#22167 | |
Still needed to address the CEL illumination issue. |
#22170 |
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
Hi I have a 1990 240sx s13 should I have power to both sides on all the injectors when the key is off?
