08-30-2009, 07:35 PM | #2161 | |
08-30-2009, 08:48 PM | #2162 | |
Just finished the sheet metal for my trunk. By my count, I used 31 separate pieces of .030" sheet, total of about 16sq ft of material (plus scraps, etc). The skeleton (and wing mount) is made of 20 sections of 3/4" .040" square tubing, totalling about 18ft long.
Not to mention hundreds of pain-in-the-ass welds lol. Pics up later tonight. It's dimensionally close enough to perfect, everything's square/level with where it needs to be. What I like most is that my taillights and trunk lid now are perfectly aligned, and with the skeleton fully boxed by the sheet metal, it's solid. Should be very quiet when I add the sound deadening. Quote:
If you can't find it there, it probably isn't used in industry, and you should choose another type of material/size/etc.
08-30-2009, 09:46 PM | #2163 | |
Air Craft Spruce -- Corona,CA - (951) 372-9555 <----They should have an online catalog as well Shore Metals -- Placentia,CA - (714) 630-1962 |
08-30-2009, 09:52 PM | #2164 |
... and here they are!
Forgot to mention, 'shaved' my antenna. The metal was dimpled quite a bit, so I figured I'd patch it from the top instead of the bottom. ... then grinded... Very nice! So here's the finished trunk: ... pain in the ass ... And the kicker ~ tail light/bumper fitment before: And after: And the bumper's just sitting on the edges of it's support, no zip ties yet! So yeah, bondo and sound deadening tomorrow hopefully.
08-30-2009, 10:03 PM | #2165 | |
08-31-2009, 03:47 AM | #2167 | |
Sound deadening will add over 50lbs for the whole car lol, I truly could care less. Thanks, RB25.
08-31-2009, 11:30 AM | #2168 |
Have a bunch of sets of spare knuckles, so I thought I would try to get some more steering angle. Plus I boxed in a pair of lca's.
Here is the steering arm after I removed .75" the knuckles and lca's before I removed the bump stops The finished product after swaping my hub's, and brake ducts over. |
09-01-2009, 10:27 AM | #2171 |
how did you weld your knuckles? Tig? What rod? Any preheating? How did you let them cool? I have tigged two different sets and i have broken both of them.
09-01-2009, 10:42 AM | #2172 | |
I have personally not released any angle kits because of the same liability, once my Z32 is running again and my track car are good again I will test them. I do not want any liability for anyone wrecking their cars because my welds creaked. Welding Cast is Extremely touchy and not just anyone can do it right. just because it looks pretty docent mean it's strong |
09-01-2009, 02:05 PM | #2173 | |
09-01-2009, 02:29 PM | #2174 |
^^^ yeah If I where you i would do a good chamfer on them to make sure you have absolutely good penetration. it's fairly thick so it will stay hot for a long long time. but if cleaned correctly and with the right filler rod it should be very very strong. might want to contact Parts Shop Max to see if they are willing to share their technique because they are poping cars out the same day. they weld in their angle kits
09-01-2009, 06:06 PM | #2175 | |
And. on the topic of the knuckles. They should be welded with a high nickle rod (like mentioned). Afterward they should be heat treated. They should also only be welded with either TIG or Stick. As they have superior penetration to MIG. If you're gonna wire feed it. It should be a dual-shield flux core weld. |
09-01-2009, 08:03 PM | #2176 |
I have talked to a couple different people they have mentioned putting the knuckles into a bucket of sand. Fill the bucket half full of sand, finish your welding, place the part into the sand, then fill the bucket to the top with sand. Any other ideas as to letting the part cool at a slower rate?
09-01-2009, 08:23 PM | #2177 | |
Trader Rating: (29)
Feedback Score: 29 reviews
The difference with PBM stuff is they do not cut the arm off the knuckle. I am having a tough time with the cutting the knuckle mod. I was going to do this a while back...then my buddy lost a tie rod at Thunderhill and almost did not get the car stopped in time. Pretty scary if the knuckle fails! I think PBM is the way to go! |
09-02-2009, 12:12 AM | #2178 |
On that same note of welding cast iron, Nickel (inconel, hastelloy, ernicrmo-17) is the rod of choice. pre-heat and post-heat are neccesary. pre-heat the work piece untill it can catch a piece of paper on fire (451 f) and post-heat for a couple hours in a kiln or oven. this is done to prevent cracking.
You can tell that the PBM knuckles are mig welded. they dont need to be tig'd because there are not just hacked off and put back together (which i think is not very safe). They weld a seperate piece on thats made out of normal mild steel that is inserted into the original tie rod hole. Dont get me wrong, i think that the mod can be done safely by just cut and weld. But I Wouldn't attempt it without proper welding skills and a jig where you could duplicate the results each time, i.e. the length of the cut and final postion. well thats my .02 haha. Last edited by SANdisk; 09-02-2009 at 06:37 PM.. |
09-04-2009, 09:24 AM | #2180 |
im all the way from australia and WOW THIS IS A GREAT THREAD
spewin i didnt find out about it earlier im going threw a rebuild at the moment and almost every thing on my car is custom made exhaust manifold is made from mild steel steam pipe and this is how it came out after it was coated and some photos of the plenum basically milled the standard inlet manifold all the way down to the flange plate so i could resuse the flange port match the flange plate to the cylinder head ports bolted it up with wat ever bolts i could find laying around just to weld it all together |
09-04-2009, 04:27 PM | #2188 |
I made this manifold its for a ls1 in a FC I reused the shitty engine flange and collector that came with his POS manifolds that did not fit. Reused for it to be cheaper on the costumers part.
09-04-2009, 08:54 PM | #2189 | |
its a sr20V rocker cover/valve cover
whens the rest of the world going to catch up and follow the exhaust flange i had my mate CNC machine for me |
09-05-2009, 12:28 AM | #2190 |
No No Australia has to catch up with everyone else and use stainless steal you see that header above you its stainless and looks fucking awesome without being coated and will never rust. Mild steal might be cheaper but it will never be better the stainless
