Old 07-09-2010, 01:04 PM   #2161
ZX88
ZX88's Avatar
Originally Posted by wh0aitznic0 View Post
I believe they're regular open ended lugs you can get at any autozone/advance/napa.
REALY? cause mine are round on the bottom so they sit flush with the inside of the spacer.
like these pictured.
Old 07-09-2010, 03:18 PM   #2162
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
i have an S13 with RB20 with KA tranny sittin on R32 crossmember
i know that Stock S13 driveshaft will work but i think thats with RB20 motor and tranny.
in my situation i have RB20 and KA tranny and the stock S13 driveshaft is short like an inch short.
anyone in this situation? or had this problem before?
can i just put a custom made spacer or is there any other driveshaft that will work?
cuz the mckinney is $415 not including the shipping and tax yet.
killer240 is offline   Reply With Quote
Old 07-09-2010, 04:33 PM   #2163
240sxfamily
240sxfamily is an unknown quantity at this point
KA/SR/RB trans are the same. You need to get a real driveshaft.
240sxfamily is offline   Reply With Quote
Old 07-09-2010, 04:42 PM   #2164
nyrojas21
nyrojas21 is an unknown quantity at this point
ok so my window hasnt worked since i got the car a few months ago,the amp clicks so i thought it was the motor,took the motor out cleaned alittle bit,tried it and it worked for a sec after jiggleing the plug to the amp,then stoped .so then i took the motor and pluged it to the passenger side and it works fine. so my question is if the amp clicks is it bad?? and if my amp is bad can i bypass it or do i need the amp?? o yeah i have a 95 s14
nyrojas21 is offline   Reply With Quote
Old 07-09-2010, 06:08 PM   #2165
stance
stance is an unknown quantity at this point
Your amp is bad. Idk if it's possible to bypass it. But I'm using an s13 one on my s14. Just had to switch brackets
stance is offline   Reply With Quote
Old 07-09-2010, 06:41 PM   #2166
dizguy
dizguy's Avatar
dizguy is an unknown quantity at this point
Send a message via AIM to dizguy
Originally Posted by heavenboundkevin View Post
totally didnt realize someone posted the same idea with a football. my bad.
Its cool man, im a fan of football. not much into basketball
Originally Posted by s13 @ fullboost View Post
good idea guys Have you done this and does it actually work ?? because I can get a suction cup on it and it will pull it out but when I release in snaps right back in. I think the pull might have weakened the metal so even if I do get it out it will just go right back from the slightest touch I need someone to chime in who know exactly what I am talking about because I know alot of others have gotten this exact same dent. Pick a random page on the wheel fitment whore thread and your likely to see one I can post pics of it if necessary I JUST WANT IT GONE! haha it hurts to look at
and thanks for the input guys appreciate I will try your methods also
I have done the football method twice. They were slight dents though, yours sounds bigger. In that case you need to heat and shrink the metal around the dent as you pull it, but its all on feel and you would need to strip the paint.
dizguy is offline   Reply With Quote
Old 07-09-2010, 07:22 PM   #2167
95_S14
95_S14's Avatar
Trader Rating: (108)
95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future
Feedback Score: 108 reviews
I've tryed looking for it but will a tranny from a 90 s13 fit a 93 s13 ones the sohc and the other is a dohc thanks
95_S14 is offline   Reply With Quote
Old 07-09-2010, 07:29 PM   #2168
killer240
killer240's Avatar
Trader Rating: (24)
its short. i already tried it. and wen i called mckinney he said someone had the same problems
Old 07-09-2010, 07:53 PM   #2169
Corbic
Corbic's Avatar
How the hell do i get the Diff back in?? I'm told i don't have to pull my half-shafts out.. but I've been wiggling that crap for an hour and can't figure out the trick thanks to the nubs on the half-shafts needing to go into the diff's output flanges and argh!!!
Old 07-10-2010, 12:14 AM   #2170
killer240
killer240's Avatar
Trader Rating: (24)
so i dont have my driveshaft connected to the diff..
im tryin to tighten up the crank pulley bolt.
how will i do it without rotating the engine? or opening the oil pan and stickin a wood in there.?
Old 07-10-2010, 12:22 AM   #2171
I LUV MY S13
I LUV MY S13's Avatar
ive always takin off the output shafts, just do that it will be alot easier
dont stick wood in there
are you unable to connect the driveshaft? anyways just put the tranny in 5th gear
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 07-10-2010, 12:26 PM   #2172
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
I've got holes on the hatch of my S13 from the old spoiler, I want to get rid of the holes, how did you get rid of it? I was planning on just using putty to fill it in but my concern is what holds putty in place, if this is wrong let me know! lol I'm no body work savy.
Old 07-10-2010, 02:37 PM   #2173
dizguy
dizguy's Avatar
Gotta weld them shut. Either use round pieces of sheet metal or squared, dont really matter. Just make sure they are large enough to cover each hole. Place the pieces of metal from underneath the hatch and spot weld them from the top of the hatch, grind down the welds flush, then fill it in with putty. Careful not to heat the metal too much while you weld, use a wet rag to cool the area around so the metal doesnt warp. Thats what i did.
Old 07-10-2010, 05:33 PM   #2174
deuce40sxftw
deuce40sxftw is an unknown quantity at this point
when i put mine on i had my old exhaust on, you dont so it will be easier. you jack it up high enough so just the male nubs of the axles will fit into the cup. usually you have to do one side first and then slide over and pull the axle (they do compress somewhat, like about 2 inches) pull it as hard as you can and then slide it over. have someone help cause i almost dropped it on my head. pretty much it should be like this
`]__[' the brackets are the cups and the apostrophe and other thing are the male nubs. you just need to get it to slide onto the flat part and not into the hole, then just jacking it up the rest
the hardest part after that is getting the bolts to line up in the back, make a new post when your there lol
good luck
deuce40sxftw is offline   Reply With Quote
Old 07-10-2010, 06:01 PM   #2175
deuce40sxftw
heres my question... who wants me to make a right up about relocating your fender harness into the bay?
i wanna know if there is an interest because i don't want to waste my time taking pictures and writing it all out if every1 is just going to bitch about there already being one (which i havent found)
Old 07-10-2010, 10:45 PM   #2176
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
Anyone ever Separated 2 peice Wheels?
want to paint my BLITZ wheels (faces only) that are on their way.are they just a bolt on affair or like maybe a 3 piece wheel using sealant too???
Should line back up being a reputable Company like Blitz right?
Anyone Guess the torque Specs on the bolts?
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 07-11-2010, 06:01 PM   #2177
KA24sleeper
KA24sleeper's Avatar
KA24sleeper is an unknown quantity at this point
Nagisa XNS0070 Shakitto Shock Tower Plate S13
Has anyone used these or know one who has, have never seen it before. Plus is it really worth having also?
SUSPENSION>Power
KA24sleeper is offline   Reply With Quote
Old 07-11-2010, 06:42 PM   #2178
Nick_04K
Nick_04K's Avatar
Nick_04K is an unknown quantity at this point
Originally Posted by ineedfire View Post
What offset can I go safely without touching suspension etc on enkei rpf1 17x9 and 17x10?
Looking at +35 f and +38 b. Will this fit with/without spacers?
Also let me know if these have a really bad shape (concave/convex etc.)
I've googled heaps but can't really get a good grasp on them.
With a 17x9 you can easily go down ten or fifteen MM on the offset and still clear stock fenders. 35 will not clear though.. I think maybe 30 or 25 is the highest you can go with a 9j. 17x10 38 wont fit either, im guessing you will need at least ten mm spacer
Nick_04K is offline   Reply With Quote
Old 07-11-2010, 08:12 PM   #2179
saleaf
saleaf's Avatar
saleaf is an unknown quantity at this point
Anyone have a full write up on replacing a Diff on s13?? step by step? so i dont spend all day messin with it.
saleaf is offline   Reply With Quote
Old 07-11-2010, 10:02 PM   #2180
Mesarina
Mesarina's Avatar
Mesarina is an unknown quantity at this point
Are these bbs rs?
Mesarina is offline   Reply With Quote
Old 07-11-2010, 11:40 PM   #2181
95_S14
95_S14's Avatar
Originally Posted by Mesarina View Post
Are these bbs rs?
Yes they are I have the same size and offset but the 5x120 I need to get them redrilled
Old 07-12-2010, 03:52 AM   #2182
ayuaddict
ayuaddict's Avatar
What is the quietest 2.5" inlet muffler i can buy?
Old 07-12-2010, 03:01 PM   #2183
Kwonza Says
Kwonza Says's Avatar
Kwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the rough
What brands of tires are good for stretching? What brands are not so great?
Weeee!~Coupe love <3
Kwonza Says is offline   Reply With Quote
Old 07-12-2010, 03:14 PM   #2184
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 07-12-2010, 09:04 PM   #2185
zooopreme
Trader Rating: (38)
can anybody take a picture of their brake pedal where the switch is? the rubber bushing/stopper broke off and i need to know where to put the replacing stopper thing. If you need to know why, my brake lights are staying on.
Old 07-12-2010, 11:31 PM   #2186
madd ocx
madd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymore
what are the pro's/cons of running 17 inch wheels front and 18inch wheels in the rear? im thinking of doing it but just wanted to know if there any drawbacks, thanks
madd ocx is offline   Reply With Quote
Old 07-13-2010, 08:20 AM   #2187
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
For one, you won't be able to rotate wheels/tires.
Maiku240sxS14 is offline   Reply With Quote
Old 07-13-2010, 08:39 AM   #2188
madd ocx
really? why is that? don't they rotate each seperatly?
Old 07-13-2010, 09:40 AM   #2189
Z33dori
Z33dori's Avatar
you can still rotate the tires, you will just have to dismount them.
Old 07-13-2010, 09:46 AM   #2190
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
All S13 open ended lugs I've seen there look cone tapered at the bottom like that. Even the ones I see by the parts counter.
Check the "wheel aisle" first if they have any that'll match and then check the parts counter for the stock ones. Buy one for like 20 cents and then see if it'll work.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
