07-01-2010, 06:22 PM | #2071 |
yeah im getting half and half reviews some with good and some with horrible so I have no idea whether i should order from them or not.. i was gona buy the silvia brick front clip with the red sr20det redtop 3gs shipped but i dont know if its gona be good or bad but thanks
07-01-2010, 06:37 PM | #2072 |
Hi, I'm having a bit of trouble with my sr20.. She idles decently but when you put a load on the engine, she wants to stall out. any ideas? didnt find a vacuum leak but I am goin to check the vacs numbers tonight, checked tps, cleaned maf, not sure on what else to check
YouTube - Sr20det problem
07-01-2010, 08:15 PM | #2073 |
help me
ok i got a few questions
1.my cluster does not light up except for the milage and the clock?dimmer swithc doesnt seem to be doing nothin 2.real nub question are the front side markers suppose to blink with the turn signal or are they just on with the headlight? 3.engine has a rattling sound is that the timeing chain guide that need to b replaced |
07-01-2010, 08:38 PM | #2074 |
Ive got an odd little question about the front 3 17mm nuts that also hold down the roll bar in the engine bay. I got two of the three off and now the third isnt rusted together it actually turns just simply isn't spiraling up?? It is turning.. why arent the threads pushing it up? I have tried looking from the bottom up but cant see it because of the stuff in the way that the last nut is holding on to.
07-02-2010, 01:45 AM | #2076 | ||
also, correct me if i'm wrong anyone, but when you do timing there is a process you go through with a "bible" or fsm. you have to count a certain number of ribs in the belt, line it up with a point of something, usually the point is the indicator of TDC so you dont have to manually crank it, and do some other stuff. i dont think you can just throw it on there, again, its something i wouldnt skimp out on and possible break a valve and fuck up my cylinder wall. some smart ass guy on this forum in xs042lol's thread about tricks said "that last thing you dont want to do when working on your car, do it first." listen to his ass, its a bitch but so is being lazy... end rant lol |
07-02-2010, 07:25 AM | #2078 | |
2. side markers don't blink, at least not on an s13. 3. maybe.
07-02-2010, 08:05 AM | #2079 | |
my bad its for an s14 and about the side markers what color wire is it sappose to be cause my harness pig tails were got off when i got it so maybe i didnt wire it rite. i wired it to a red/blue wire and they were on with the lights then both the side markers went out |
07-02-2010, 09:19 AM | #2080 |
Can someone point me in the right direction for buying one of these chin spoilers. I saw this picture and this is exactly what I'm looking for. I have no idea who makes it either.
http://www.nlmotoring.com/v/vspfiles...501_gal_09.jpg |
07-02-2010, 09:20 AM | #2081 | |
also ill have to do some research for the timing belt replacement then |
07-02-2010, 05:15 PM | #2082 | |
07-02-2010, 10:11 PM | #2083 |
07-03-2010, 12:52 AM | #2084 | ||
ka24e ka24de injector differences - Nissan Forums: Nissan Enthusiast Forum altima engine is the same, i believe |
07-03-2010, 01:04 AM | #2086 |
Ok i need a little help I just got my s13 sr20det red top running a couple hours ago and i let it idle for about 5 minutes, so i thought ok cool everything is ok wrong.... when i accelerate i get like a fuel cut only when i press on the gas/throttle has anybody had the same problem i checked for vacuum leaks and everything seems fine what could it be?
07-03-2010, 01:05 AM | #2087 |
Trader Rating: (50)
Feedback Score: 50 reviews
what stock sr20 parts fit the ka24de.?
innjectors and side mount forsure what about the manifold,stock intercooler piping,turbo what else.?
wtb s14 roof wing/spoiler! pm me |
07-03-2010, 03:14 PM | #2089 |
07-03-2010, 04:52 PM | #2090 |
OK flamesuit on. Can someone please tell me if this is the correct ball joint for the s14 from control arm........MOOG-K9820 Front Lower Ball Joint Made By
Reason i ask i heard those have the wrong taper? Are they wrong? Or do they really have the wrong taper and i need to look somewhere else.
Nothing says racecar like a stock car with no interior. |
07-03-2010, 05:08 PM | #2091 | |
anybody has some input?
07-04-2010, 04:39 PM | #2094 |
Trader Rating: (38)
Feedback Score: 38 reviews
Whenever I'm braking moderately (daily driving) in my 240, my brake pedal shakes, is that normal? Or if there is something wrong? Is it the brake pedal?
07-04-2010, 08:15 PM | #2097 |
Trader Rating: (42)
Feedback Score: 42 reviews
does any one know what the stock inner and outer tierod length measure ments are i bent both of mine and it cant measure them im putting in tein inner and outers if any one has them thanks
07-04-2010, 10:27 PM | #2098 | |
Trader Rating: (38)
And just do it in an area with the least amount of dust, nobody is going to really see it so it'll be fine. hope this helps. |
