10-13-2016, 10:29 AM | #20342 |
10-13-2016, 11:35 AM | #20345 |
Does anyone else have trouble putting their car into reverse on a stock KA24DE motor and trans? As if the gate isn't opening, not allowing you to throw it into reverse.
10-13-2016, 12:30 PM | #20347 |
I'd say make sure you bled the system properly before considering your brand new head gasket faulty. I use Lisle Spill-Free Funnel and love it:
http://revlimiter.net/blog/2011/03/t...l-free-funnel/ |
10-13-2016, 08:39 PM | #20348 |
Ka24de. temp gauge goes all the way to *cool* it says when I turn on the heater on for a little when I turn it off, it *warms* up and goes back to the middle this happen to anyone else? Im just curious why this might happen. I did a quick search and couldn't find much
10-14-2016, 01:30 PM | #20349 | |
Sent from my SM-G930P |
10-17-2016, 11:31 PM | #20351 |
I know what the answer is, but i'm gonna ask anyways
1992 240sx with SR20 swap.
Car idles, then dies when you give it gas. Car won't idle with anything but starting fluid. Replace fuel filter fuel pump relay tests good Replace fuel pump check spark check injectors replace fuel pump fuel pump won't spin up. It's a ground, isn't it? Oh, God. It's a ground. Please help! |
10-17-2016, 11:36 PM | #20352 |
Trader Rating: (18)
Feedback Score: 18 reviews
Boost Junkyz
Any AZ peeps in here know if Boost Junkyz is still doing business? I noticed they haven't been active here for awhile.
DON'T BE UPSET WITH THE RESULTS YOU GET FROM THE WORK YOU DIDN'T DO. |
10-17-2016, 11:37 PM | #20353 | |||
GM2 (SW/AW)
Bad ground? Gauge grounding when switched on heat? Otherwise you may need to replace thermostat, the heater may be allowing a higher flow than the t-stat is. Rare signs of it failing Unless you're driving in cold ass weather. Mine would do that in the rare North Atlantic Florida winters when I used the heater it would suck the combustion warmpth right from the engine. Id have to turn the heater off on the interstate just to keep normal op temps. But double check with another gauge just to be sure it's not a cluster temp switch issue. Could be signs of low coolant in the engine or air bubbles since the KA has dual temp sensors.
KA-T for life! Current for sale advertisement |
10-18-2016, 08:49 AM | #20354 |
Any of you guys know much about rom tuning Nissan Ecus? I've found daughter boards online for s13 sr20/kas and s14 sr/ka but was curious about boards for the rbs/vg motors.
Im super in DIY and was thinking about doing some local tunes super cheap, can get a running tune going for half the price anywhere else. About 200 bucks with basic setups, if they want dyno/real time tuning I can use emulators instead of swapping out chips 24/7 |
10-18-2016, 11:17 AM | #20355 | ||
10-18-2016, 11:29 AM | #20356 |
SR guru's PLEASE read:
S13 SR in S13 vert (prior owner did swap/wiring) Motor will crank over but not start unless you give a shot of starting fluid OR bump starting the car in gear, It runs flawlessly when running. I have spark and fuel. Pulled plugs, CAS and fuel rail. I observe spark and injectors pulsing fuel while rotating the CAS. It has been re-timed properly. It runs and drives great and WOT pulls seem normal. Orange signal wire has 12v while cranking. Fuel pump has 12v with key on (not sure about constant 12v while cranking at this current time) ANY suggestions will help, (posting for a friend) |
10-18-2016, 04:21 PM | #20358 | |
I don't remember if it was short to 12V or ground though. Just remember I accidentally triggered it and thought my car was broken because the CEL was blinking erratically. Edit: the Wiring Specialties harness connects the check connector pin to the OBD2 connector. Shorting these two pins puts the ECU in diag mode: Last edited by LoSt180; 10-19-2016 at 06:07 AM.. |
10-19-2016, 04:31 AM | #20359 | |
10-19-2016, 08:56 PM | #20361 |
Trader Rating: (31)
Feedback Score: 31 reviews
Quick question. I have an s13 sr and want to hook up a charcoal canister to it. I see how it's hooked up per fsm( straight to TB) but my question is how is it regulated ? Is the usdm charcoal canister different from Jdm? On the KA it's regulated by the egr solenoid so I'm unsure how it will behave on the sr. Thanks in advance! Been searching and searching with no real answer
Sent from my iPhone using Tapatalk |
10-19-2016, 09:55 PM | #20362 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
why in gods name do you want to use a charcoal canister?! if youre thinking youre gonna pass smog legally with it by fooling the inspection on visual, its not gonna happen! the SR didnt use an EGR setup at all... the AIV inducts air into the 02 housing or downpipe (i cant remember which). oh, so youll also either need an OE downpipe/02 housing or to cut a hold and weld a bung in.
but if you MUST run one, I believe its setup mimics the USDM layout identically... though youre going to need an OE SR AIV and boost solenoid setup which are EXTREMELY hard to come by these days. SR AIV Setup (top part of circled): SR boost solenoid + mounting plate: SR Air Damper box: |
10-20-2016, 04:35 PM | #20363 |
Any suggestions for reliable daily cars in the 4-7k$ range? Considering picking up a 97 Honda Accord w/ 54k miles on it, and very few flaws*.
*major accident *qtr panel damage Lmao, carfax saved the day.
Skurr Skurr Last edited by DJTTon; 10-20-2016 at 05:07 PM.. |
10-20-2016, 07:02 PM | #20366 |
https://www.instagram.com/jdpowersport_/ |
10-20-2016, 07:11 PM | #20367 |
Trader Rating: (92)
Feedback Score: 92 reviews
I've been searching but all the links are dead , just bought a yashio factory temp gauge consult type. My question is all it reads is 1? I have a 91 coupe with sr engine and 62 ecu cookie cutter any one know how to operate this thing?
Can anyone help please ? I've search I've even translated the damn website and my shit still isn't working !! Sent from my iPhone using Tapatalk |
10-20-2016, 07:20 PM | #20368 | |
That or a volvo 240 haha, they're pretty reliable |
10-20-2016, 10:57 PM | #20369 |
What could cause hesitation at lower rpms on a ka? It only happens under light throttle and goes away after 4000 rpms. It's not that bad of a hesitation and it idles and drives fine just kinda annoying to drive in traffic
10-20-2016, 11:01 PM | #20370 |
4,000 rpm on a ka!!!! How!?
Little better description would help. What do you mean by "hesitation" Last edited by jared420sx; 10-20-2016 at 11:02 PM.. Reason: Spelling |
