05-05-2016, 03:17 PM | #19712 |
05-05-2016, 03:30 PM | #19713 |
Missing the two slim/long bolts that secure the head to the front oil pump cover (under the cam gears/CAS, not the ones that actually bolt the cam shaft down.) Anyone know what size they are? Was unable to find any information in the FSM. Redtop SR
05-05-2016, 05:38 PM | #19714 |
Any of you guys have recommendations for where I can purchase new or remanufactured (if there is such a thing) OEM A/C parts for a single cam S13 online?
Not sure if all A/C components should be purchased new if I want to get my exposed-to-the-atmosphere system back up and running properly again. I've been looking online here and there and haven't really came across much. Fuck the heat. Thanks. |
05-05-2016, 06:15 PM | #19715 |
Hey guys, I'm pretty close to finishing my semester and will have spare time and I wanna tackle my alignment specs. Here's a pic of current #s, im wondering how much I could do with just coilovers and adjustable inner outer tie rodsuploadfromtaptalk1462493738567.jpg
Sent from my SPH-L720T using Tapatalk
Skurr Skurr |
05-05-2016, 10:34 PM | #19716 |
Doc racing manifold; powering steering fitment issue.
Does anyone here run a doc racing top mount turbo manifold ? Sr20.. I'm having fitment issues with the power steering pump, not even close to clearing to get on the bracket lol anyone know of a possible solution or anything Ideas are welcome 😅
05-05-2016, 10:58 PM | #19717 |
I had to install the line rotated 90 degrees. So instead of the tang on the line fitting in the keyway on the pump, you hold the line so the tang faces the motor and tighten the banjo
05-06-2016, 08:32 AM | #19718 |
05-06-2016, 06:42 PM | #19720 |
Please, need the help asap so I can finish my build and get this 400hp Sr going !!
05-06-2016, 06:54 PM | #19721 |
05-06-2016, 10:04 PM | #19724 | |
05-06-2016, 10:53 PM | #19726 | |
These are a few issues Im trying to address. |
05-06-2016, 10:56 PM | #19727 |
Trader Rating: (24)
Feedback Score: 24 reviews
Well if you don't have adjustable arms in the back you just want to get it as good as you can with the eccentrics. Least amount of camber possible, maybe 0 to 1/16" of toe-in.
05-06-2016, 11:16 PM | #19728 | |
How do you reckon I check camber and toe w/ out exactly get an alignment. Rather pricey in my area. |
05-07-2016, 08:55 PM | #19735 |
Trader Rating: (32)
Feedback Score: 32 reviews
Does anyone know if you can run a dual vvl solenoid with the relocation block on a p12 head? instead of the p12 single vvl solenoid? any advice is helpful.
05-09-2016, 01:33 PM | #19736 |
Just checking to see if anyone else has run into this issue. I recently replaced my stock rear calipers with some re manufactured ones and at the same time I put on new pads and rotors.
Before I had no issues, now the brake pedal will hit a dead stop halfway through it's travel. It's a 100% stop, no squishyness, and it's immediate. If I crack the bleeder screws on either rear caliper or on the master cylinder the pedal falls to half way and stops. If I crack the bleeder on either front caliper the pedal falls all the way to the floor like it should. Stock s14 calipers, no abs, new hawk hp plus pads and new rotors. |
05-09-2016, 01:43 PM | #19737 |
Anyone have insight on removing door mouldings on S14? The trim that goes up and around the A-pillar, the quarter glass, and the trim near the driver/passenger door glass
05-09-2016, 03:47 PM | #19738 |
Where do I buy these transmission rebuild tools like:
ST23810001 adapter setting plate KV31100401 press stand ST22520000 (J26348) Wrench ST235440000 (J25689-A) pin punch ST30031000 (J22912-01) PUller I called Kent Moore but was told they do not make anything this old. |
05-10-2016, 02:21 PM | #19740 | ||||||
Trader Rating: (58)
Feedback Score: 58 reviews
You need the camber arms in the rear as you want to get it to -1.5ish and the stock junk won't get you there. The rear toe for the same reason, but maybe a half a degree total in. Front 0 toe, and the tension arms to help set caster....and because if you're on stock stuff and lowering it, you're gonna blow out the stockers in no time. Quote:
