Old 03-17-2016, 02:34 PM   #19411
kashira kureijii
kashira kureijii's Avatar
kashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-known
Originally Posted by Crazyced View Post
I'm fully aware that my car has a consult port. In fact here it is:
I can only assume the shit it's pact with is a mixture of dirt, road salts and fabric adhesive it gathered while it way laying on the floor. Last thing I want is continuity issues while flashing ROMs so if I can get my hands on a nice one I'll do that.
Originally Posted by bigs View Post
Just get a big sticker that says "copyright infringement"
kashira kureijii is offline   Reply With Quote
Old 03-17-2016, 02:41 PM   #19412
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
Originally Posted by S14kouki805 View Post
I got a reman S14 rack at my local Napa for like $240, you need to give them your core though. If that's too much idk what to tell you.
I called Napa, Orilley and Advanced. None of them even have racks for 240sx available.
Jorgs_7 is offline   Reply With Quote
Old 03-17-2016, 03:46 PM   #19413
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
Have you tried buyautoparts.com?
Javi802 is offline   Reply With Quote
Old 03-17-2016, 04:02 PM   #19414
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
I did. They were asking for around $340. I can't remember if that was with or without the core return.
SoundEfx is offline   Reply With Quote
Old 03-17-2016, 06:29 PM   #19415
S14kouki805
S14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud of
It was like 4 bills total, then I took the rack back for my core refund.
Why would you not have a rack to begin with though?
S14kouki805 is offline   Reply With Quote
Old 03-17-2016, 06:43 PM   #19416
AllThingsGravy
AllThingsGravy's Avatar
AllThingsGravy is making a name for him/her selfAllThingsGravy is making a name for him/her selfAllThingsGravy is making a name for him/her self
Quick Q:
I have the oem intake piping for the sr20, what do I do with the 2 nipples? I have a fmic with no nipple on the hot pipe. Should I plug them both up? I'm new to the SR world and lost at the moment..
AllThingsGravy is offline   Reply With Quote
Old 03-17-2016, 07:45 PM   #19417
Javi802
Javi802's Avatar
If im not mistaken, one hole is for a re-circulation valve, one is for the crankcase vent and im not sure what the small one is for. I just plugged the small one. If youre not recirculating your bov then you can plug that one.
Old 03-17-2016, 08:27 PM   #19418
AllThingsGravy
I just looked at my bov and I see what you're talking about thanks. Any idea where the Waste gate nipple goes to?
Old 03-17-2016, 08:43 PM   #19419
Javi802
Javi802's Avatar
The waste gate nipple needs to go to a boost source. I had a bung for a nipple fitting welded on my hot pipe. Ive heard of people using the nipple under the throttle body for the wastegate, but im unsure as to whether or not that is ideal. The intake manifold is obviously going to be pressurized so i dont see why it wouldnt work, but i like that my vacuum line only has to be run about 6 inches/
Old 03-17-2016, 08:49 PM   #19420
AllThingsGravy
Would this work or is it off? If so then I need to get a controller....
Old 03-17-2016, 09:07 PM   #19421
Javi802
Javi802's Avatar
The left nipple is what goes to the fpr. The right is what goes to the bov. At least thats how i have it. Not sure if it matters being as how both ports go in to the manifold. One nipple is larger though so that may change the amount of vacuum those sources see? Not sure.
You dont need a boost controller if you dont intend on on playing with your boost pressure, which i wouldnt. Either way you will still need a source for your wastgate.
Old 03-17-2016, 09:11 PM   #19422
AllThingsGravy
Yeah I don't plan on touching the boost pressure, so then can anyone confirm if I can run the WG to the TB?
Old 03-17-2016, 10:49 PM   #19423
derass
I would not do that for two reasons:
1) The wastegate diaphragm is not designed to experience vacuum. It may tear and no longer control boost pressure.
2) The length of that hose would be far too long and cause boost spike
You should either weld a nipple to the hot pipe, tap the compressor outlet pipe or use a "Quick-tap" from ATP
Old 03-17-2016, 10:53 PM   #19424
AllThingsGravy
Looks like I'll go with the quick tap, any idea which hose to tap into? Only one I can think of is the intake hose.
Old 03-18-2016, 10:40 PM   #19425
derass
The intake pipe won't work, it doesn't see boost pressure.
The ideal source for the wastegate signal is closest to the compressor housing so that it can respond quickly. I had my quicktap on the coupler between the compressor outlet pipe and hotpipe. Now, I have a fitting tapped into the compressor outlet pipe. It's cheaper, but more difficult to get right the first time of you're not experinced tapping curved surfaces.
Old 03-18-2016, 11:16 PM   #19426
AllThingsGravy
Alright I gotcha, I saw it would be good for the coupler between the hot pipe and the outlet pipe
Old 03-18-2016, 11:21 PM   #19427
AllThingsGravy
I have another question now... is this the oem red top outlet pipe? My hot pipe sits too high and the hood doesn't close. I Googled the oem one and it looks like the oem one sits more straight up.
Old 03-19-2016, 12:25 AM   #19428
Jibbberish
Jibbberish's Avatar
Jibbberish is an unknown quantity at this point
^Doesn't look stock. The stock one is shorter and sits almost vertical:
Originally Posted by dorkidori_s13 View Post
Originally Posted by Jibbberish View Post
So I've got a troubling problem. Running a pretty much stock blacktop sr. Just has FMIC, boost controller (that's turned off, so its just on wastegate pressure), t28, and that's about it. Atmospheric bov as well which comes with its own issues but shouldn't cause this.
Problem is it's going WAAAAY lean at idle, and too lean while cruising. At idle it'll go off the gauge on my AEM wideband, which means 18+. Cruising it was at like 16+, and wide open it was just fine in the high 11's to low 12's.
So I've got the crappy little AFC neo, and I had to go +50 (which is the max) at 500rpm, and +28 at 1000rpm to get the afr at idle to sit around 14.6. And sometimes the engine will shutter for a second and the afr will go down to like 11 then slowly climb back up. Values at other revs had to go to between like +5 and +8 to get cruising afr to high 14's, low 15's. All these settings were done at a local shop on a dyno, timing was checked in the process.
I don't seem to have any vacuum or boost leaks. Wide open it runs just fine. What's goin on here?
Few other symptoms:
-When letting the car decelerate in gear, often times there'll be a loud ass pop that kinda sounds like an intake backfire at 1500rpm. Always at 1500. I assume it's because I'm throwing so much fuel at it down there, but I thought that shouldn't matter off throttle?
-Also, if I clutch in and let the revs drop it'll drop to like 600 and shutter for a second then surge back up to idle. Not due to the bov because in this case i'm not gassing it before I put the clutch in.
-At super low throttle cruising (like 1-5%, when i'm just barely on the gas going downhill or something) it'll go rich as hell, like 12. Increase throttle to 8%ish and up and it'll go back to around 15.
Sorry if this is long winded as fuck lol trying to give a good description.
sounds like youre pulling air post MAF, pre turbo... are you using t-bolt clamps and thick couplers or screw clamps and paper thin couplers? you may also be leaking air at the intake manifold as well, get a torque wrench and check torque on all of the intake manifold bolts.
also, clean your MAF and check the MAF plug pins inside of the plug from the wiring harness.
The intake tube is stock. Thick couplers and screw hose clamps for post turbo piping. No extraneous vacuum lines. Everything is tight.
Cleaned the maf (looked fine though) and hooked a vacuum up to the intake while it was off the car, no leaks. The only thing post maf is the valve cover breather hose, but it comes that way stock so I wouldn't think that would cause issues right?
The sensor for the maf in the AFC Neo is set to "hot wire", then "In" 1, "Out" 1, then "In" single, "Out" single. I'm not sure where to verify that this is the correct setting, but I know if it was incorrect that'd cause problems so if anyone knows the proper setting let me know.
Jibbberish is offline   Reply With Quote
Old 03-19-2016, 01:44 PM   #19429
Kaiba
Kaiba's Avatar
Kaiba is an unknown quantity at this point
KA Timing chain fucked, oil in coolant. What do?
My single cam rattles when started and sometimes when idling. I figure it's the dreaded timing chain issue. It would also explain why my coolant keeps turning black, and my motor smells like it's burning all the time.
Is it worth trying fix all this shit? Or would it be more cost effective to just buy a new motor?
Kaiba is offline   Reply With Quote
Old 03-19-2016, 01:51 PM   #19430
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
its from an S14/S15/
Old 03-19-2016, 09:30 PM   #19431
Corbic
Corbic's Avatar
So my throw out bearing fucking exploded at 3am last week.
Right after like 10 fucking hours of wrenching and tuning to get it back on the street.
Joy.
Anyway, which clutch looks better or are they both toast.
My 6 year old Spec.
The Exeddy that came with the swap and I shelved 6 years ago since I already had a new Spec.
And the flywheel. 2 fucking bolts snapped like god damn pretzel sticks.
Old 03-19-2016, 09:37 PM   #19432
ProjectPanda13
ProjectPanda13 is an unknown quantity at this point
Send a message via AIM to ProjectPanda13
I am considering upgrading my springs on my Cusco Zero-2r, 7kg/5kg, to something like 9kg/7kg or even 10kg/8kg from Swift. Could the shock handle the stiffer spring rate? Does anyone know the diameter and length by chance. I haven't pulled .you coil overs off to measure.
Latez.
Sent from my SGH-T889 using Tapatalk
ProjectPanda13 is offline   Reply With Quote
Old 03-19-2016, 10:12 PM   #19433
kashira kureijii
not gonna act like a badass or anything, but the exedy looks like it has a lot more material left on it, whereas the material on the spec looks pretty worn.
so exedy clutch disk and pressure plate?
the oem style exedy clutches aren't supposed to be super badass or anything, so I don't know how much you could abuse or what power setup you run or whatever.
I have the same clutch for my sr, and I like it, it is very smooth engagement
Old 03-19-2016, 10:32 PM   #19434
derass
It looks like the Exedy disc looks like it has a bit more life. You can compare the two disc by checking their wear limits as shown below. The OEM spec might not be exact for those aftermarket discs, but it'll give you an idea of what Nissan considers worn out.
The surface rust on the Exedy pressure plate doesn't look great, but you could clean it up yourself with a sanding block, sand paper glued down to a table or take it to a machine shop and have them run it over a bench sander.
ps. It's interesting to see that your Exedy disc has some stray fibers around the outer diameter. When I replaced mine, it had the same thing, but much worse, chips of the material missing around the outer edge too. It had as much material thickness as the new disc I put in, but I suppose the shock of clutch kicking was too much. I only had 5-10 events on it.
Old 03-19-2016, 10:42 PM   #19435
Corbic
Corbic's Avatar
So the Exedy is the OEM clutch?
Old 03-19-2016, 10:48 PM   #19436
derass
I'm not sure. If your run that part number you'll see that it comes back as an "OEM Clutch Disc" for KA/SR. However, it might be an aftermarket replacement despite Exedy being the OEM for Nissan, meaning that your engine might not have come equipped with that clutch kit from the factory; that it was replaced at some point.
Old 03-19-2016, 10:53 PM   #19437
Corbic
Corbic's Avatar
I'll check tomorrow. I had just assume someone replaced the OEM clutch at some point since it had a bright purple cover.
Old 03-19-2016, 11:00 PM   #19438
derass
I agree. If it were a Nissan part, I don't think the hub would be purple.
Old 03-20-2016, 07:55 AM   #19439
kashira kureijii
no it isn't, my sr had the original clutch in it, and the disk, and pressure plate will have nissan stamped on it.
did you keep the throwout bearing for the exedy? because all dat shit is different size throwout, between exedy and stock etc.
maybe even different size/style throwout between exedy and spec,
Old 03-20-2016, 08:41 AM   #19440
Corbic
Corbic's Avatar
SPEC did not come with a TOB.
I do not recall anything remarkable with the original TOB in the trans 6 years ago.
