#1771 |
Does anyone know where the pictures went in the S14 5 speed swap sticky in the FAQ section? I got everything through the auto removal and now I'm onto manual install. I come back from college to find out the pictures are no longer there. Difficult to do without seeing it, personally.. Would appreciate it if someone had saved it all..
#1772 | |
now i'm rollin again ![]() ![]() ![]() ![]()
SPEED KILLS!! Drive a Honda and live forever!! |
#1773 |
okay, i did some searching and found out that on courtesy nissan that the 95-98 240sx AC Compressor has the same part numbers as the 95-99 maxima's..their both 27630?? So does this means the maxima will bolt into the s14?
240sx- 274 Compressor :: Body Electrical :: Genuine Nissan Parts :: 240SX Parts (S14) 1995-1998 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com maxima- 274 Compressor :: Body Electrical :: Genuine Nissan Parts :: Maxima Parts (A32B) 1995-1999 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
#1776 |
#1779 |
so u gain top speed but lose acceleration?.. on mine it feels no different but i catch traction a whole lot quicker
#1781 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
im making my lower harness for my RB20 and im using a KADE lower harness.
seems like all the plug works for RB20 now i read a write up on how to convert RB20 harness to S13 it only says that i only need the oil pressure sending unit. it said that the yellow wire is all i need(unless i run an oil gauge) but where do i wire up the yellow wire on the lower KADE harness? can someone post a pic of their converted lower KADE harness for their RB20. also can you tell me where these plugs go. ![]() theres a 3 pin plug on along with the maf plug. where does the 3 pin plug go? (no pic yet) i know one of the plugs goes to a/c but i dont have a/c so i dont know which 1 it is. ![]() |
#1782 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
is there any Electrical reason why my auto tranny isnt engaging?...
![]() ![]() PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r ![]() |
#1783 | |
Pretty sure #1 is for a JDM chassis/electrical system.
#1784 |
So I searched and found quite a few topics about speedometers not working but none of them were similar to my problem soo..
The speedo in my 90 coupe is burried and just stays like that, sometimes it goes backwards...? What's up with that? I'm not swapped or anything, just a sohc. Any help would be awesome. |
#1785 |
Ok, so this might be a repeating & random question, so I do apologize in advance if it is so.
I was wondering if it is still possible to obtain/purchase GP Sport's Type R full body kit for a 180SX? ![]() ![]() Cheers! |
#1786 | |
Trader Rating: (24)
so can i just ignore these plugs and use the lower KA harness? for the oil pressure sending unit, can i hot wire it on the lower KA harness or i have to run a wire all the way to the cluster? |
#1787 |
![]() Join Date: Jul 2009
Trader Rating: (50)
![]() Feedback Score: 50 reviews
whats up guys.!
im thinking about doing an rb20 swap into my s14 my s14s automatic and i was wondering if i were to get s14 manual clutch lines and clutch master cylinder would they work with the rb.?
wtb s14 roof wing/spoiler! pm me |
#1788 | |
In any case, I'm no expert, and I am merely giving you information based on what I have been reading & researching on a RB20 swap - I also want to do an RB20 swap, but for an S13. Anyways, I hope that helped a bit. Cheers! |
#1791 |
anybody know the size of bolts that hold seats down in s13? thanks
not m8 or m10 . not 7/16 but close. diameter measure 9.84 mm pitch seem to be 1.25 about 29mm long home depot at least does not have it. ok, its m10. this stupid thread needs to be deleted. Last edited by surreybc; 06-02-2010 at 01:58 AM.. |
#1792 |
I'm trying to identify the deathly sound coming from my rear coil overs. It doesn't sound like coil bind, its more of a low pitch creeking sound. It only happens to my rears while I'm turning, even at low speeds and over bumps. My coils are stance gr+ pro ssd's and I have an s14. Ive had a few off road excursions so could it be dirt somewhere? I apologize ahead of time if this isn't the correct place to post this.
#1794 | |
street dancer. GLEAM |
#1795 | |
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
#1796 |
serious ques guys really in need of help, was driving on the highway doing about 80 the road was bad so the car was bouncing alot, i heard a noise like some preasure being release from somewhere, then the car started to loose power and run wierd as if it was misfiring, so much so that i had to slow down and pull over. i put it in nuetral and let it idle and it was fluctuating between 1.5 and 2.5 rpms, then it just shut off. i turned it on and reved and it reved like it was missing and there was alot of black smoke coming from the exhaust. i also noticed that the boost gauge went below zero when i was reving and would not biuld up at all, and it wasnt spooling because it didnt blow off no matter howmuch i reved, idk if it has something to do with the vacuum line. can anyone help out of ideas, its an sr20det in a 89 hatch
#1797 |
Answered my own question by searching on Stance's website... the top locking nut on an inverted coilover, it's ok to hit it with an impact on low setting.
#1799 |
![]() Join Date: May 2005
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
how many ounces do the s14 radiator over flow tanks hold.
mine is all cracked and i wanted to replace it with a custom one Last edited by blackalicious95; 06-02-2010 at 01:58 PM.. |
#1800 |
